AW: [PATCH 0/3] [rtems-libbsd] [backport] Fix compilation issue for
Jan.Sommer at dlr.de
Fri Mar 6 21:24:44 UTC 2020
Please ignore this patch set.
We managed to get the e1000 driver working, today.
I will submit an updated version with it included next week.
Best regards,
Jan
> -----Ursprüngliche Nachricht-----
> Von: Sommer, Jan
> Gesendet: Freitag, 6. März 2020 11:09
> An: devel at rtems.org
> Cc: Sommer, Jan
> Betreff: [PATCH 0/3] [rtems-libbsd] [backport] Fix compilation issue for
> This is the backport for the 5-freebsd-12 branch to make rtems-libbsd
> compile for i386 again:
> - Currently compilation only works with dev_nic_e1000 = off
> - It also introduces path-mappings to waf_libbsd.py as introduced here:
> https://lists.rtems.org/pipermail/devel/2020-February/057457.html
> Best regards,
> Jan
> Jan Sommer (3):
> i386: Add missing files from FreeBSD
> i386: Update build system
> i386: Port to RTEMS
> freebsd/sbin/sysctl/sysctl.c | 8 +
> freebsd/sys/dev/pci/pci_pci.c | 2 +
> freebsd/sys/i386/include/machine/cpufunc.h | 2 +
> .../sys/x86/include/machine/intr_machdep.h | 180 +++
> .../{i386 => x86}/include/machine/legacyvar.h | 26 +-
> freebsd/sys/{i386/i386 => x86/x86}/legacy.c | 77 +-
> libbsd.py | 14 +-
> rtemsbsd/i386/include/machine/clock.h | 2 +
> rtemsbsd/include/x86/legacyvar.h | 1 +
> rtemsbsd/include/x86/specialreg.h | 1074 +++++++++++++++++
> rtemsbsd/include/x86/x86_var.h | 156 +++
> waf_libbsd.py | 13 +-
> 12 files changed, 1516 insertions(+), 39 deletions(-)
> create mode 100644 freebsd/sys/x86/include/machine/intr_machdep.h
> rename freebsd/sys/{i386 => x86}/include/machine/legacyvar.h (76%)
> rename freebsd/sys/{i386/i386 => x86/x86}/legacy.c (89%)
> create mode 100644 rtemsbsd/i386/include/machine/clock.h
> create mode 100644 rtemsbsd/include/x86/legacyvar.h
> create mode 100644 rtemsbsd/include/x86/specialreg.h
> create mode 100644 rtemsbsd/include/x86/x86_var.h
> 2.17.1
