[PATCH v6] tests for fenv.h functions
Eshan Dhawan eshandhawan51 at gmail.com
Sun Mar 8 17:02:42 UTC 2020
I have compiled as well as executed it for RISC V architecture function
Fegetround() returns error for all rounding directions other the default
"FETONEAREST" I asked about it on devel to which dr Joel told that it is
due to soft-float.
So I have added its test case but they won't work on emulators.
thanks
-Eshan
On Sun, Mar 8, 2020 at 7:55 PM Gedare Bloom <gedare at rtems.org> wrote:
> Hi Eshan,
> This is looking good. Did you compile it? Execute it?  How was the output?
> On Sat, Mar 7, 2020 at 6:51 AM Eshan dhawan <eshandhawan51 at gmail.com>
> wrote:
> >  testsuites/psxtests/psxfenv01/init.c | 89 ++++++++++++++++++++++------
> >  1 file changed, 71 insertions(+), 18 deletions(-)
> > diff --git a/testsuites/psxtests/psxfenv01/init.c
> b/testsuites/psxtests/psxfenv01/init.c
> > index cdb0fa596e..6d71463465 100644
> > --- a/testsuites/psxtests/psxfenv01/init.c
> > +++ b/testsuites/psxtests/psxfenv01/init.c
> > @@ -46,11 +46,12 @@
> >  #include <string.h>
> >  #include <rtems/test.h>
> >  #include <tmacros.h>
> > +#include <float.h>
> >  const char rtems_test_name[] = "PSXFENV 01";
> >  /* forward declarations to avoid warnings */
> > -rtems_task Init(rtems_task_argument ignored);
> > +rtems_task Init( rtems_task_argument ignored );
> >  /* Test Function Begins */
> > @@ -62,28 +63,31 @@ rtems_task Init(rtems_task_argument ignored)
> >     * 'FE_ALL_EXCEPT' will be defined only when 'feclearexcept()',
> > -   * 'fegetexceptflag()', 'feraiseexcept()', 'fesetexceptflag()' and
> > -   * 'fetestexcept()' functions are supported by the architecture.
> > +   * fegetexceptflag() , feraiseexcept(), fesetexceptflag() and
> > +   * fetestexcept() functions are supported by the architecture.
> >     * Hence their testcases can be wrapped under #ifdef and #endif.
> >    #ifdef FE_ALL_EXCEPT /* floating-point exceptions */
> >      puts( "fesetenv(FE_DFL_ENV)." );
> > -    r = fesetenv(FE_DFL_ENV);
> > -    if (r)
> > +    r = fesetenv ( FE_DFL_ENV );
> > +    if ( r ) {
> >        printf("fesetenv ==> %d\n", r);
> > -    rtems_test_assert( r == 0 );
> > +    rtems_test_assert ( r == 0 );
> > -    /* Test 'feclearexcept()' and 'fetestexcept()' in one go. */
> > -    puts( "feclearexcept(FE_ALL_EXCEPT)." );
> > -    r = feclearexcept(FE_ALL_EXCEPT);
> > -    if (r)
> > +    /* Test feclearexcept() and fetestexcept() in one go. */
> > +    puts( "feclearexcept(FE_ALL_EXCEPT)" );
> > +    r = feclearexcept ( FE_ALL_EXCEPT );
> > +    if ( r ) {
> >        printf("feclearexcept ==> 0x%x\n", r);
> > -    r = fetestexcept( FE_ALL_EXCEPT );
> > -    if (r)
> > +    r = fetestexcept ( FE_ALL_EXCEPT );
> > +    if ( r ) {
> >        printf("fetestexcept ==> 0x%x\n", r);
> >      /* Test 'FE_DIVBYZERO' */
> >      puts( "Divide by zero and confirm fetestexcept()" );
> > @@ -91,11 +95,60 @@ rtems_task Init(rtems_task_argument ignored)
> >      b = 1.0;
> >      c = b/a;
> >      (void) c;
> > -    fegetexceptflag(&excepts,FE_ALL_EXCEPT);
> > +    /* Test fegetexceptflag() and fesetexceptflag() */
> > +    r = fegetexceptflag ( &excepts, FE_ALL_EXCEPT );
> > +    if ( r ) {
> > +      printf("fegetexceptflag ==> 0x%x\n", r);
> > +    r = fesetexceptflag ( &excepts, FE_ALL_EXCEPT );
> > +    if ( r ) {
> > +      printf("fesetexceptflag ==> 0x%x\n", r);
> > +    /* Test for fegetround() and fesetround()
> > +     * They have four main macros to be tested separated by ifdef
> > +     * Since not all architectures support them
> > +     * The test case gets and sets the rounding directions */
> > +#ifdef FE_TONEAREST
> > +    rtems_test_assert ( fegetround() == FE_TONEAREST ) ;
> > +#endif
> > +#ifdef FE_TOWARDZERO
> > +  r = fesetround ( FE_TOWARDZERO ) ;
> > +  if ( r ) {
> > +      printf("fesetround ==> 0x%x\n", r);
> > +  rtems_test_assert ( r == 0 ) ;
> > +  rtems_test_assert ( fegetround() == FE_TOWARDZERO ) ;
> > +#endif
> > +#ifdef FE_DOWNWARD
> > +  r = fesetround ( FE_DOWNWARD );
> > +  if ( r ) {
> > +  rtems_test_assert ( fegetround() == FE_DOWNWARD ) ;
> > +#endif
> > +#ifdef FE_UPWARD
> > +  r = fesetround ( FE_UPWARD );
> > +  if ( r ) {
> > +  rtems_test_assert ( fegetround() == FE_UPWARD ) ;
> > +#endif
> > +  r = fesetround ( FE_TONEAREST );
> > +  if ( r ) {
> > +#endif
> >  #ifdef FE_DIVBYZERO
> > -    r = feraiseexcept(FE_DIVBYZERO);
> > +    r = feraiseexcept ( FE_DIVBYZERO ) ;
> >      rtems_test_assert( fetestexcept( FE_DIVBYZERO ) );
> >  #endif
> > 2.17.1
> > devel mailing list
> > devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20200308/22e4bedf/attachment-0001.html>
