[PATCH v6] tests for fenv.h functions
Eshan Dhawan eshandhawan51 at gmail.com
Fri Mar 20 18:49:19 UTC 2020
Hello Everyone,
I had sent this patch a few days ago to add tests of fenv.h to psxtests.
If you all could look into it and tell if it could be merged or requires
any more changes.
thanks,
Eshan Dhawan
On Sun, Mar 8, 2020 at 10:32 PM Eshan Dhawan <eshandhawan51 at gmail.com>
wrote:
> I have compiled as well as executed it for RISC V architecture function
> Fegetround() returns error for all rounding directions other the default
> "FETONEAREST" I asked about it on devel to which dr Joel told that it is
> due to soft-float.
> So I have added its test case but they won't work on emulators.
> thanks
> -Eshan
> On Sun, Mar 8, 2020 at 7:55 PM Gedare Bloom <gedare at rtems.org> wrote:
>> Hi Eshan,
>> This is looking good. Did you compile it? Execute it?  How was the output?
>> On Sat, Mar 7, 2020 at 6:51 AM Eshan dhawan <eshandhawan51 at gmail.com>
>> wrote:
>> >  testsuites/psxtests/psxfenv01/init.c | 89 ++++++++++++++++++++++------
>> >  1 file changed, 71 insertions(+), 18 deletions(-)
>> > diff --git a/testsuites/psxtests/psxfenv01/init.c
>> b/testsuites/psxtests/psxfenv01/init.c
>> > index cdb0fa596e..6d71463465 100644
>> > --- a/testsuites/psxtests/psxfenv01/init.c
>> > +++ b/testsuites/psxtests/psxfenv01/init.c
>> > @@ -46,11 +46,12 @@
>> >  #include <string.h>
>> >  #include <rtems/test.h>
>> >  #include <tmacros.h>
>> > +#include <float.h>
>> >  const char rtems_test_name[] = "PSXFENV 01";
>> >  /* forward declarations to avoid warnings */
>> > -rtems_task Init(rtems_task_argument ignored);
>> > +rtems_task Init( rtems_task_argument ignored );
>> >  /* Test Function Begins */
>> > @@ -62,28 +63,31 @@ rtems_task Init(rtems_task_argument ignored)
>> >     * 'FE_ALL_EXCEPT' will be defined only when 'feclearexcept()',
>> > -   * 'fegetexceptflag()', 'feraiseexcept()', 'fesetexceptflag()' and
>> > -   * 'fetestexcept()' functions are supported by the architecture.
>> > +   * fegetexceptflag() , feraiseexcept(), fesetexceptflag() and
>> > +   * fetestexcept() functions are supported by the architecture.
>> >     * Hence their testcases can be wrapped under #ifdef and #endif.
>> >    #ifdef FE_ALL_EXCEPT /* floating-point exceptions */
>> >      puts( "fesetenv(FE_DFL_ENV)." );
>> > -    r = fesetenv(FE_DFL_ENV);
>> > -    if (r)
>> > +    r = fesetenv ( FE_DFL_ENV );
>> > +    if ( r ) {
>> >        printf("fesetenv ==> %d\n", r);
>> > -    rtems_test_assert( r == 0 );
>> > +    rtems_test_assert ( r == 0 );
>> > -    /* Test 'feclearexcept()' and 'fetestexcept()' in one go. */
>> > -    puts( "feclearexcept(FE_ALL_EXCEPT)." );
>> > -    r = feclearexcept(FE_ALL_EXCEPT);
>> > -    if (r)
>> > +    /* Test feclearexcept() and fetestexcept() in one go. */
>> > +    puts( "feclearexcept(FE_ALL_EXCEPT)" );
>> > +    r = feclearexcept ( FE_ALL_EXCEPT );
>> > +    if ( r ) {
>> >        printf("feclearexcept ==> 0x%x\n", r);
>> > -    r = fetestexcept( FE_ALL_EXCEPT );
>> > -    if (r)
>> > +    r = fetestexcept ( FE_ALL_EXCEPT );
>> > +    if ( r ) {
>> >        printf("fetestexcept ==> 0x%x\n", r);
>> >      /* Test 'FE_DIVBYZERO' */
>> >      puts( "Divide by zero and confirm fetestexcept()" );
>> > @@ -91,11 +95,60 @@ rtems_task Init(rtems_task_argument ignored)
>> >      b = 1.0;
>> >      c = b/a;
>> >      (void) c;
>> > -    fegetexceptflag(&excepts,FE_ALL_EXCEPT);
>> > +    /* Test fegetexceptflag() and fesetexceptflag() */
>> > +    r = fegetexceptflag ( &excepts, FE_ALL_EXCEPT );
>> > +    if ( r ) {
>> > +      printf("fegetexceptflag ==> 0x%x\n", r);
>> > +    r = fesetexceptflag ( &excepts, FE_ALL_EXCEPT );
>> > +    if ( r ) {
>> > +      printf("fesetexceptflag ==> 0x%x\n", r);
>> > +    /* Test for fegetround() and fesetround()
>> > +     * They have four main macros to be tested separated by ifdef
>> > +     * Since not all architectures support them
>> > +     * The test case gets and sets the rounding directions */
>> > +#ifdef FE_TONEAREST
>> > +    rtems_test_assert ( fegetround() == FE_TONEAREST ) ;
>> > +#endif
>> > +#ifdef FE_TOWARDZERO
>> > +  r = fesetround ( FE_TOWARDZERO ) ;
>> > +  if ( r ) {
>> > +      printf("fesetround ==> 0x%x\n", r);
>> > +  rtems_test_assert ( r == 0 ) ;
>> > +  rtems_test_assert ( fegetround() == FE_TOWARDZERO ) ;
>> > +#endif
>> > +#ifdef FE_DOWNWARD
>> > +  r = fesetround ( FE_DOWNWARD );
>> > +  if ( r ) {
>> > +  rtems_test_assert ( fegetround() == FE_DOWNWARD ) ;
>> > +#endif
>> > +#ifdef FE_UPWARD
>> > +  r = fesetround ( FE_UPWARD );
>> > +  if ( r ) {
>> > +  rtems_test_assert ( fegetround() == FE_UPWARD ) ;
>> > +#endif
>> > +  r = fesetround ( FE_TONEAREST );
>> > +  if ( r ) {
>> > +#endif
>> >  #ifdef FE_DIVBYZERO
>> > -    r = feraiseexcept(FE_DIVBYZERO);
>> > +    r = feraiseexcept ( FE_DIVBYZERO ) ;
>> >      rtems_test_assert( fetestexcept( FE_DIVBYZERO ) );
>> >  #endif
>> > 2.17.1
>> > _______________________________________________
>> > devel mailing list
>> > devel at rtems.org
>> > http://lists.rtems.org/mailman/listinfo/devel
URL: <http://lists.rtems.org/pipermail/devel/attachments/20200321/7b37a18d/attachment-0001.html>
