[PATCH] Bump rtems-tools to get mkimage.py into the bin/ directory.
Amar Takhar amar at rtems.org
Sun Mar 8 22:10:10 UTC 2020
 rtems/config/tools/rtems-tools-5-1.cfg | 4 ++--
 1 file changed, 2 insertions(+), 2 deletions(-)
diff --git a/rtems/config/tools/rtems-tools-5-1.cfg b/rtems/config/tools/rtems-tools-5-1.cfg
index cf097c4..e7f6183 100644
--- a/rtems/config/tools/rtems-tools-5-1.cfg
+++ b/rtems/config/tools/rtems-tools-5-1.cfg
@@ -10,14 +10,14 @@
  %define rtems_tools_source rtems-tools-%{rtems_tools_version}
  %define rtems_tools_ext xz
 %else
- %define rtems_tools_version 763f10232f001516afeca6e063dee87f77949427
+ %define rtems_tools_version bae873a5f93ca8746df66045dd265742587e83be
  %define rtems_tools_ext bz2
 %endif
 %source set rtems-tools https://git.rtems.org/rtems-tools/snapshot/%{rtems_tools_source}.tar.%{rtems_tools_ext}
 %hash   sha512 rtems-tools-%{rtems_tools_version}.tar.bz2 \
-         d8648bd766972402d9cba5a59e203e4cab38ea4117c59dac0a3a107679cfe59c0afc42c9967835729f45c05904bed7a64c19bf8c1b3174effd12680b4264f4a9
+         c4fcc1b285ef741cf4e6afe41d1262488677903cb6210fdc16a5ce821ac380e7ac9eb9f83b2c8c0e54ca12a9a5efe2ccc775392260ab56cb947f7075b0ebf47d
 # Optionally enable/disable building the RTEMS Tools via the command line.
2.25.0
