[PATCH] Bump rtems-tools to get mkimage.py into the bin/ directory.
Chris Johns
chrisj at rtems.org
Sun Mar 8 22:14:29 UTC 2020
OK to push. Thank you for including the update to the tools with the tools change.
On 9/3/20 9:10 am, Amar Takhar wrote:
> rtems/config/tools/rtems-tools-5-1.cfg | 4 ++--
> 1 file changed, 2 insertions(+), 2 deletions(-)
> diff --git a/rtems/config/tools/rtems-tools-5-1.cfg b/rtems/config/tools/rtems-tools-5-1.cfg
> index cf097c4..e7f6183 100644
> --- a/rtems/config/tools/rtems-tools-5-1.cfg
> +++ b/rtems/config/tools/rtems-tools-5-1.cfg
> @@ -10,14 +10,14 @@
> %define rtems_tools_source rtems-tools-%{rtems_tools_version}
> %define rtems_tools_ext xz
> %else
> - %define rtems_tools_version 763f10232f001516afeca6e063dee87f77949427
> + %define rtems_tools_version bae873a5f93ca8746df66045dd265742587e83be
> %define rtems_tools_ext bz2
> %endif
> %source set rtems-tools https://git.rtems.org/rtems-tools/snapshot/%{rtems_tools_source}.tar.%{rtems_tools_ext}
> %hash sha512 rtems-tools-%{rtems_tools_version}.tar.bz2 \
> - d8648bd766972402d9cba5a59e203e4cab38ea4117c59dac0a3a107679cfe59c0afc42c9967835729f45c05904bed7a64c19bf8c1b3174effd12680b4264f4a9
> + c4fcc1b285ef741cf4e6afe41d1262488677903cb6210fdc16a5ce821ac380e7ac9eb9f83b2c8c0e54ca12a9a5efe2ccc775392260ab56cb947f7075b0ebf47d
> # Optionally enable/disable building the RTEMS Tools via the command line.
