[PATCH 06/20] c-user: Move "POSIX Initialization Thread Configuration"
Sebastian Huber
Mon Mar 9 09:02:49 UTC 2020
Update #3836.
c-user/config/index.rst | 103 +---------------------------
c-user/config/posix-init-thread-config.rst | 105 +++++++++++++++++++++++++++++
2 files changed, 106 insertions(+), 102 deletions(-)
create mode 100644 c-user/config/posix-init-thread-config.rst
diff --git a/c-user/config/index.rst b/c-user/config/index.rst
index fc76fca..4333495 100644
--- a/c-user/config/index.rst
+++ b/c-user/config/index.rst
@@ -16,108 +16,7 @@ Configuring a System
classic-api-config
classic-init-task-config
posix-api-config
-POSIX Initialization Thread Configuration
-The ``<rtems/confdefs.h>`` configuration system can automatically generate a
-POSIX Initialization Threads Table named ``POSIX_Initialization_threads`` with
-a single entry. The following parameters control the generation of that table.
-.. index:: CONFIGURE_POSIX_INIT_THREAD_ENTRY_POINT
-.. _CONFIGURE_POSIX_INIT_THREAD_ENTRY_POINT:
-CONFIGURE_POSIX_INIT_THREAD_ENTRY_POINT
-CONSTANT:
- ``CONFIGURE_POSIX_INIT_THREAD_ENTRY_POINT``
-DATA TYPE:
- POSIX thread function pointer (``void *(*entry_point)(void *)``).
-RANGE:
- Undefined or a valid POSIX thread function pointer.
-DEFAULT VALUE:
- The default value is ``POSIX_Init``.
-DESCRIPTION:
- ``CONFIGURE_POSIX_INIT_THREAD_ENTRY_POINT`` is the entry point
- (a.k.a. function name) of the single initialization thread defined by the
- POSIX API Initialization Threads Table.
-NOTES:
- The user must implement the function ``POSIX_Init`` or the function name
- provided in this configuration parameter.
-.. index:: CONFIGURE_POSIX_INIT_THREAD_STACK_SIZE
-.. _CONFIGURE_POSIX_INIT_THREAD_STACK_SIZE:
-CONFIGURE_POSIX_INIT_THREAD_STACK_SIZE
-CONSTANT:
- ``CONFIGURE_POSIX_INIT_THREAD_STACK_SIZE``
-DATA TYPE:
- Unsigned integer (``size_t``).
-RANGE:
- Zero or positive.
-DEFAULT VALUE:
- The default value is 2 \* RTEMS_MINIMUM_STACK_SIZE.
-DESCRIPTION:
- ``CONFIGURE_POSIX_INIT_THREAD_STACK_SIZE`` is the stack size of the single
- initialization thread defined by the POSIX API Initialization Threads
- Table.
-NOTES:
- If the stack size specified is greater than the configured minimum, it must
- be accounted for in ``CONFIGURE_EXTRA_TASK_STACKS``. See :ref:`Reserve
- Task/Thread Stack Memory Above Minimum` for more information about
- ``CONFIGURE_EXTRA_TASK_STACKS``.
-.. index:: CONFIGURE_POSIX_INIT_THREAD_TABLE
-.. _CONFIGURE_POSIX_INIT_THREAD_TABLE:
-CONFIGURE_POSIX_INIT_THREAD_TABLE
-CONSTANT:
- ``CONFIGURE_POSIX_INIT_THREAD_TABLE``
-DATA TYPE:
- Boolean feature macro.
-RANGE:
- Defined or undefined.
-DEFAULT VALUE:
- This field is not defined by default, as the user MUST select their own API
- for initialization tasks.
-DESCRIPTION:
- ``CONFIGURE_POSIX_INIT_THREAD_TABLE`` is defined if the user wishes to use
- a POSIX API Initialization Threads Table. The table built by
- ``<rtems/confdefs.h>`` specifies the parameters for a single thread. This
- is sufficient for applications which initialization the system from a
- single task.
- By default, this field is not defined as the user MUST select their own API
-NOTES:
- The application may choose to use the initialization tasks or threads table
- from another API.
- A compile time error will be generated if the user does not configure any
- initialization tasks or threads.
+ posix-init-thread-config
Task Stack Allocator Configuration
diff --git a/c-user/config/posix-init-thread-config.rst b/c-user/config/posix-init-thread-config.rst
new file mode 100644
index 0000000..04027fa
--- /dev/null
+++ b/c-user/config/posix-init-thread-config.rst
@@ -0,0 +1,105 @@
+.. SPDX-License-Identifier: CC-BY-SA-4.0
+.. Copyright (C) 1988, 2008 On-Line Applications Research Corporation (OAR)
+POSIX Initialization Thread Configuration
+The ``<rtems/confdefs.h>`` configuration system can automatically generate a
+POSIX Initialization Threads Table named ``POSIX_Initialization_threads`` with
+a single entry. The following parameters control the generation of that table.
+.. index:: CONFIGURE_POSIX_INIT_THREAD_ENTRY_POINT
+.. _CONFIGURE_POSIX_INIT_THREAD_ENTRY_POINT:
+CONFIGURE_POSIX_INIT_THREAD_ENTRY_POINT
+CONSTANT:
+ ``CONFIGURE_POSIX_INIT_THREAD_ENTRY_POINT``
+DATA TYPE:
+ POSIX thread function pointer (``void *(*entry_point)(void *)``).
+RANGE:
+ Undefined or a valid POSIX thread function pointer.
+DEFAULT VALUE:
+ The default value is ``POSIX_Init``.
+DESCRIPTION:
+ ``CONFIGURE_POSIX_INIT_THREAD_ENTRY_POINT`` is the entry point
+ (a.k.a. function name) of the single initialization thread defined by the
+ POSIX API Initialization Threads Table.
+NOTES:
+ The user must implement the function ``POSIX_Init`` or the function name
+ provided in this configuration parameter.
+.. index:: CONFIGURE_POSIX_INIT_THREAD_STACK_SIZE
+.. _CONFIGURE_POSIX_INIT_THREAD_STACK_SIZE:
+CONFIGURE_POSIX_INIT_THREAD_STACK_SIZE
+CONSTANT:
+ ``CONFIGURE_POSIX_INIT_THREAD_STACK_SIZE``
+DATA TYPE:
+ Unsigned integer (``size_t``).
+RANGE:
+ Zero or positive.
+DEFAULT VALUE:
+ The default value is 2 \* RTEMS_MINIMUM_STACK_SIZE.
+DESCRIPTION:
+ ``CONFIGURE_POSIX_INIT_THREAD_STACK_SIZE`` is the stack size of the single
+ initialization thread defined by the POSIX API Initialization Threads
+ Table.
+NOTES:
+ If the stack size specified is greater than the configured minimum, it must
+ be accounted for in ``CONFIGURE_EXTRA_TASK_STACKS``. See :ref:`Reserve
+ Task/Thread Stack Memory Above Minimum` for more information about
+ ``CONFIGURE_EXTRA_TASK_STACKS``.
+.. index:: CONFIGURE_POSIX_INIT_THREAD_TABLE
+.. _CONFIGURE_POSIX_INIT_THREAD_TABLE:
+CONFIGURE_POSIX_INIT_THREAD_TABLE
+CONSTANT:
+ ``CONFIGURE_POSIX_INIT_THREAD_TABLE``
+DATA TYPE:
+ Boolean feature macro.
+RANGE:
+ Defined or undefined.
+DEFAULT VALUE:
+ This field is not defined by default, as the user MUST select their own API
+ for initialization tasks.
+DESCRIPTION:
+ ``CONFIGURE_POSIX_INIT_THREAD_TABLE`` is defined if the user wishes to use
+ a POSIX API Initialization Threads Table. The table built by
+ ``<rtems/confdefs.h>`` specifies the parameters for a single thread. This
+ is sufficient for applications which initialization the system from a
+ single task.
+ By default, this field is not defined as the user MUST select their own API
+NOTES:
+ The application may choose to use the initialization tasks or threads table
+ from another API.
+ A compile time error will be generated if the user does not configure any
+ initialization tasks or threads.
2.16.4
