[PATCH 05/20] c-user: Move "POSIX API Configuration"
Sebastian Huber
Mon Mar 9 09:02:48 UTC 2020
Update #3836.
c-user/config/index.rst | 250 +-----------------------------------
c-user/config/posix-api-config.rst | 252 +++++++++++++++++++++++++++++++++++++
2 files changed, 253 insertions(+), 249 deletions(-)
create mode 100644 c-user/config/posix-api-config.rst
diff --git a/c-user/config/index.rst b/c-user/config/index.rst
index 254deed..fc76fca 100644
--- a/c-user/config/index.rst
+++ b/c-user/config/index.rst
@@ -15,255 +15,7 @@ Configuring a System
general-config
classic-api-config
classic-init-task-config
-POSIX API Configuration
-The parameters in this section are used to configure resources for the POSIX
-API supported by RTEMS. Most POSIX API objects are available by default since
-RTEMS 5.1. The queued signals and timers are only available if RTEMS was built
-with the ``--enable-posix`` build configuration option.
-.. index:: CONFIGURE_MAXIMUM_POSIX_KEYS
-.. _CONFIGURE_MAXIMUM_POSIX_KEYS:
-CONFIGURE_MAXIMUM_POSIX_KEYS
-CONSTANT:
- ``CONFIGURE_MAXIMUM_POSIX_KEYS``
-DATA TYPE:
- Unsigned integer (``uint32_t``).
-RANGE:
- Zero or positive.
-DEFAULT VALUE:
- The default value is 0.
-DESCRIPTION:
- ``CONFIGURE_MAXIMUM_POSIX_KEYS`` is the maximum number of POSIX API Keys
- that can be concurrently active.
-NOTES:
- This object class can be configured in unlimited allocation mode.
-.. index:: CONFIGURE_MAXIMUM_POSIX_KEY_VALUE_PAIRS
-.. _CONFIGURE_MAXIMUM_POSIX_KEY_VALUE_PAIRS:
-CONFIGURE_MAXIMUM_POSIX_KEY_VALUE_PAIRS
-CONSTANT:
- ``CONFIGURE_MAXIMUM_POSIX_KEY_VALUE_PAIRS``
-DATA TYPE:
-RANGE:
- Zero or positive.
-DEFAULT VALUE:
- :ref:`CONFIGURE_MAXIMUM_POSIX_KEYS <CONFIGURE_MAXIMUM_POSIX_KEYS>` *
- :ref:`CONFIGURE_MAXIMUM_TASKS <CONFIGURE_MAXIMUM_TASKS>` +
- :ref:`CONFIGURE_MAXIMUM_POSIX_THREADS <CONFIGURE_MAXIMUM_POSIX_THREADS>`.
-DESCRIPTION:
- ``CONFIGURE_MAXIMUM_POSIX_KEY_VALUE_PAIRS`` is the maximum number of key
- value pairs used by POSIX API Keys that can be concurrently active.
-NOTES:
- A key value pair is created by :c:func:`pthread_setspecific` if the value
- is not :c:macro:`NULL`, otherwise it is deleted.
-.. index:: CONFIGURE_MAXIMUM_POSIX_MESSAGE_QUEUES
-.. _CONFIGURE_MAXIMUM_POSIX_MESSAGE_QUEUES:
-CONFIGURE_MAXIMUM_POSIX_MESSAGE_QUEUES
-CONSTANT:
- ``CONFIGURE_MAXIMUM_POSIX_MESSAGE_QUEUES``
-DATA TYPE:
-RANGE:
- Zero or positive.
-DEFAULT VALUE:
-DESCRIPTION:
- ``CONFIGURE_MAXIMUM_POSIX_MESSAGE_QUEUES`` is the maximum number of POSIX
- API Message Queues that can be concurrently active.
-NOTES:
- This object class can be configured in unlimited allocation mode. You have
- to account for the memory used to store the messages of each message queue,
- see :ref:`CONFIGURE_MESSAGE_BUFFER_MEMORY`.
-.. index:: CONFIGURE_MAXIMUM_POSIX_QUEUED_SIGNALS
-.. _CONFIGURE_MAXIMUM_POSIX_QUEUED_SIGNALS:
-CONFIGURE_MAXIMUM_POSIX_QUEUED_SIGNALS
-CONSTANT:
- ``CONFIGURE_MAXIMUM_POSIX_QUEUED_SIGNALS``
-DATA TYPE:
-RANGE:
- Zero or positive.
-DEFAULT VALUE:
-DESCRIPTION:
- ``CONFIGURE_MAXIMUM_POSIX_QUEUED_SIGNALS`` is the maximum number of POSIX
- API Queued Signals that can be concurrently active.
-NOTES:
- Unlimited objects are not available for queued signals.
- Queued signals are only available if RTEMS was built with the
- ``--enable-posix`` build configuration option.
-.. index:: CONFIGURE_MAXIMUM_POSIX_SEMAPHORES
-.. _CONFIGURE_MAXIMUM_POSIX_SEMAPHORES:
-CONFIGURE_MAXIMUM_POSIX_SEMAPHORES
-CONSTANT:
- ``CONFIGURE_MAXIMUM_POSIX_SEMAPHORES``
-DATA TYPE:
-RANGE:
- Zero or positive.
-DEFAULT VALUE:
-DESCRIPTION:
- ``CONFIGURE_MAXIMUM_POSIX_SEMAPHORES`` is the maximum number of POSIX API
- Named Semaphores that can be concurrently active.
-NOTES:
- Named semaphores are created with ``sem_open()``. Semaphores initialized
- with ``sem_init()`` are not affected by this configuration option since the
- storage space for these semaphores is user-provided.
-.. index:: CONFIGURE_MAXIMUM_POSIX_TIMERS
-.. _CONFIGURE_MAXIMUM_POSIX_TIMERS:
-CONFIGURE_MAXIMUM_POSIX_TIMERS
-CONSTANT:
- ``CONFIGURE_MAXIMUM_POSIX_TIMERS``
-DATA TYPE:
-RANGE:
- Zero or positive.
-DEFAULT VALUE:
-DESCRIPTION:
- ``CONFIGURE_MAXIMUM_POSIX_TIMERS`` is the maximum number of POSIX API
- Timers that can be concurrently active.
-NOTES:
- Timers are only available if RTEMS was built with the
-.. index:: CONFIGURE_MAXIMUM_POSIX_THREADS
-.. _CONFIGURE_MAXIMUM_POSIX_THREADS:
-CONFIGURE_MAXIMUM_POSIX_THREADS
-CONSTANT:
- ``CONFIGURE_MAXIMUM_POSIX_THREADS``
-DATA TYPE:
-RANGE:
- Zero or positive.
-DEFAULT VALUE:
-DESCRIPTION:
- ``CONFIGURE_MAXIMUM_POSIX_THREADS`` is the maximum number of POSIX API
- Threads that can be concurrently active.
-NOTES:
- This calculations for the required memory in the RTEMS Workspace for
- threads assume that each thread has a minimum stack size and has floating
- point support enabled. The configuration parameter
- ``CONFIGURE_EXTRA_TASK_STACKS`` is used to specify thread stack
- requirements *ABOVE* the minimum size required. See :ref:`Reserve
- Task/Thread Stack Memory Above Minimum` for more information about
- ``CONFIGURE_EXTRA_TASK_STACKS``.
- The maximum number of Classic API Tasks is specified by
- :ref:`CONFIGURE_MAXIMUM_TASKS <CONFIGURE_MAXIMUM_TASKS>`.
- All POSIX threads have floating point enabled.
-.. index:: CONFIGURE_MINIMUM_POSIX_THREAD_STACK_SIZE
-.. index:: minimum POSIX thread stack size
-.. _CONFIGURE_MINIMUM_POSIX_THREAD_STACK_SIZE:
-CONFIGURE_MINIMUM_POSIX_THREAD_STACK_SIZE
-CONSTANT:
- ``CONFIGURE_MINIMUM_POSIX_THREAD_STACK_SIZE``
-DATA TYPE:
- Unsigned integer (``size_t``).
-RANGE:
- Positive.
-DEFAULT VALUE:
- The default value is two times the value of
- :ref:`CONFIGURE_MINIMUM_TASK_STACK_SIZE <CONFIGURE_MINIMUM_TASK_STACK_SIZE>`.
-DESCRIPTION:
- This configuration parameter defines the minimum stack size in bytes for
- every POSIX thread in the system.
-NOTES:
- None.
+ posix-api-config
POSIX Initialization Thread Configuration
diff --git a/c-user/config/posix-api-config.rst b/c-user/config/posix-api-config.rst
new file mode 100644
index 0000000..da5c0ba
--- /dev/null
+++ b/c-user/config/posix-api-config.rst
@@ -0,0 +1,252 @@
+.. SPDX-License-Identifier: CC-BY-SA-4.0
+.. Copyright (C) 1988, 2008 On-Line Applications Research Corporation (OAR)
+POSIX API Configuration
+The parameters in this section are used to configure resources for the POSIX
+API supported by RTEMS. Most POSIX API objects are available by default since
+RTEMS 5.1. The queued signals and timers are only available if RTEMS was built
+with the ``--enable-posix`` build configuration option.
+.. index:: CONFIGURE_MAXIMUM_POSIX_KEYS
+.. _CONFIGURE_MAXIMUM_POSIX_KEYS:
+CONFIGURE_MAXIMUM_POSIX_KEYS
+CONSTANT:
+ ``CONFIGURE_MAXIMUM_POSIX_KEYS``
+DATA TYPE:
+ Unsigned integer (``uint32_t``).
+RANGE:
+ Zero or positive.
+DEFAULT VALUE:
+ The default value is 0.
+DESCRIPTION:
+ ``CONFIGURE_MAXIMUM_POSIX_KEYS`` is the maximum number of POSIX API Keys
+ that can be concurrently active.
+NOTES:
+ This object class can be configured in unlimited allocation mode.
+.. index:: CONFIGURE_MAXIMUM_POSIX_KEY_VALUE_PAIRS
+.. _CONFIGURE_MAXIMUM_POSIX_KEY_VALUE_PAIRS:
+CONFIGURE_MAXIMUM_POSIX_KEY_VALUE_PAIRS
+CONSTANT:
+ ``CONFIGURE_MAXIMUM_POSIX_KEY_VALUE_PAIRS``
+DATA TYPE:
+RANGE:
+ Zero or positive.
+DEFAULT VALUE:
+ :ref:`CONFIGURE_MAXIMUM_POSIX_KEYS <CONFIGURE_MAXIMUM_POSIX_KEYS>` *
+ :ref:`CONFIGURE_MAXIMUM_TASKS <CONFIGURE_MAXIMUM_TASKS>` +
+ :ref:`CONFIGURE_MAXIMUM_POSIX_THREADS <CONFIGURE_MAXIMUM_POSIX_THREADS>`.
+DESCRIPTION:
+ ``CONFIGURE_MAXIMUM_POSIX_KEY_VALUE_PAIRS`` is the maximum number of key
+ value pairs used by POSIX API Keys that can be concurrently active.
+NOTES:
+ A key value pair is created by :c:func:`pthread_setspecific` if the value
+ is not :c:macro:`NULL`, otherwise it is deleted.
+.. index:: CONFIGURE_MAXIMUM_POSIX_MESSAGE_QUEUES
+.. _CONFIGURE_MAXIMUM_POSIX_MESSAGE_QUEUES:
+CONFIGURE_MAXIMUM_POSIX_MESSAGE_QUEUES
+CONSTANT:
+ ``CONFIGURE_MAXIMUM_POSIX_MESSAGE_QUEUES``
+DATA TYPE:
+RANGE:
+ Zero or positive.
+DEFAULT VALUE:
+DESCRIPTION:
+ ``CONFIGURE_MAXIMUM_POSIX_MESSAGE_QUEUES`` is the maximum number of POSIX
+ API Message Queues that can be concurrently active.
+NOTES:
+ This object class can be configured in unlimited allocation mode. You have
+ to account for the memory used to store the messages of each message queue,
+ see :ref:`CONFIGURE_MESSAGE_BUFFER_MEMORY`.
+.. index:: CONFIGURE_MAXIMUM_POSIX_QUEUED_SIGNALS
+.. _CONFIGURE_MAXIMUM_POSIX_QUEUED_SIGNALS:
+CONFIGURE_MAXIMUM_POSIX_QUEUED_SIGNALS
+CONSTANT:
+ ``CONFIGURE_MAXIMUM_POSIX_QUEUED_SIGNALS``
+DATA TYPE:
+RANGE:
+ Zero or positive.
+DEFAULT VALUE:
+DESCRIPTION:
+ ``CONFIGURE_MAXIMUM_POSIX_QUEUED_SIGNALS`` is the maximum number of POSIX
+ API Queued Signals that can be concurrently active.
+NOTES:
+ Unlimited objects are not available for queued signals.
+ Queued signals are only available if RTEMS was built with the
+ ``--enable-posix`` build configuration option.
+.. index:: CONFIGURE_MAXIMUM_POSIX_SEMAPHORES
+.. _CONFIGURE_MAXIMUM_POSIX_SEMAPHORES:
+CONFIGURE_MAXIMUM_POSIX_SEMAPHORES
+CONSTANT:
+ ``CONFIGURE_MAXIMUM_POSIX_SEMAPHORES``
+DATA TYPE:
+RANGE:
+ Zero or positive.
+DEFAULT VALUE:
+DESCRIPTION:
+ ``CONFIGURE_MAXIMUM_POSIX_SEMAPHORES`` is the maximum number of POSIX API
+ Named Semaphores that can be concurrently active.
+NOTES:
+ Named semaphores are created with ``sem_open()``. Semaphores initialized
+ with ``sem_init()`` are not affected by this configuration option since the
+ storage space for these semaphores is user-provided.
+.. index:: CONFIGURE_MAXIMUM_POSIX_TIMERS
+.. _CONFIGURE_MAXIMUM_POSIX_TIMERS:
+CONFIGURE_MAXIMUM_POSIX_TIMERS
+CONSTANT:
+ ``CONFIGURE_MAXIMUM_POSIX_TIMERS``
+DATA TYPE:
+RANGE:
+ Zero or positive.
+DEFAULT VALUE:
+DESCRIPTION:
+ ``CONFIGURE_MAXIMUM_POSIX_TIMERS`` is the maximum number of POSIX API
+ Timers that can be concurrently active.
+NOTES:
+ Timers are only available if RTEMS was built with the
+.. index:: CONFIGURE_MAXIMUM_POSIX_THREADS
+.. _CONFIGURE_MAXIMUM_POSIX_THREADS:
+CONFIGURE_MAXIMUM_POSIX_THREADS
+CONSTANT:
+ ``CONFIGURE_MAXIMUM_POSIX_THREADS``
+DATA TYPE:
+RANGE:
+ Zero or positive.
+DEFAULT VALUE:
+DESCRIPTION:
+ ``CONFIGURE_MAXIMUM_POSIX_THREADS`` is the maximum number of POSIX API
+ Threads that can be concurrently active.
+NOTES:
+ This calculations for the required memory in the RTEMS Workspace for
+ threads assume that each thread has a minimum stack size and has floating
+ point support enabled. The configuration parameter
+ ``CONFIGURE_EXTRA_TASK_STACKS`` is used to specify thread stack
+ requirements *ABOVE* the minimum size required. See :ref:`Reserve
+ Task/Thread Stack Memory Above Minimum` for more information about
+ ``CONFIGURE_EXTRA_TASK_STACKS``.
+ The maximum number of Classic API Tasks is specified by
+ :ref:`CONFIGURE_MAXIMUM_TASKS <CONFIGURE_MAXIMUM_TASKS>`.
+ All POSIX threads have floating point enabled.
+.. index:: CONFIGURE_MINIMUM_POSIX_THREAD_STACK_SIZE
+.. index:: minimum POSIX thread stack size
+.. _CONFIGURE_MINIMUM_POSIX_THREAD_STACK_SIZE:
+CONFIGURE_MINIMUM_POSIX_THREAD_STACK_SIZE
+CONSTANT:
+ ``CONFIGURE_MINIMUM_POSIX_THREAD_STACK_SIZE``
+DATA TYPE:
+ Unsigned integer (``size_t``).
+RANGE:
+ Positive.
+DEFAULT VALUE:
+ The default value is two times the value of
+ :ref:`CONFIGURE_MINIMUM_TASK_STACK_SIZE <CONFIGURE_MINIMUM_TASK_STACK_SIZE>`.
+DESCRIPTION:
+ This configuration parameter defines the minimum stack size in bytes for
+ every POSIX thread in the system.
+NOTES:
+ None.
2.16.4
