[PATCH 08/20] c-user: Move "Message Queue Buffer Configuration"
    Sebastian Huber
    Mon Mar  9 09:02:51 UTC 2020
Update #3836.
 c-user/config/index.rst              | 91 +----------------------------------
 c-user/config/msgq-buffer-config.rst | 93 ++++++++++++++++++++++++++++++++++++
 2 files changed, 94 insertions(+), 90 deletions(-)
 create mode 100644 c-user/config/msgq-buffer-config.rst
diff --git a/c-user/config/index.rst b/c-user/config/index.rst
index c99a3cf..5f5d3c1 100644
--- a/c-user/config/index.rst
+++ b/c-user/config/index.rst
@@ -18,96 +18,7 @@ Configuring a System
     posix-api-config
     posix-init-thread-config
     stack-alloc-config
-Message Queue Buffer Configuration
-This section describes the configuration parameters related to specifying the
-amount of memory reserved for message queue message buffers.  See
-:ref:`CONFIGURE_MAXIMUM_MESSAGE_QUEUES` and
-:ref:`CONFIGURE_MAXIMUM_POSIX_MESSAGE_QUEUES`.
-.. index:: CONFIGURE_MESSAGE_BUFFER_MEMORY
-.. index:: configure message queue buffer memory
-.. _CONFIGURE_MESSAGE_BUFFER_MEMORY:
-CONFIGURE_MESSAGE_BUFFER_MEMORY
-CONSTANT:
-    ``CONFIGURE_MESSAGE_BUFFER_MEMORY``
-DATA TYPE:
-    integer summation macro
-RANGE:
-    undefined (zero) or calculation resulting in a positive integer
-DEFAULT VALUE:
-    This is not defined by default, and zero (0) memory is reserved.
-DESCRIPTION:
-    This macro is set to the number of bytes the application requires to be
-    reserved for pending Classic API Message Queue buffers.
-NOTES:
-    The following illustrates how the help macro
-    :ref:`CONFIGURE_MESSAGE_BUFFERS_FOR_QUEUE` can be used to assist in
-    calculating the message buffer memory required.  In this example, there are
-    two message queues used in this application.  The first message queue has
-    maximum of 24 pending messages with the message structure defined by the
-    type ``one_message_type``.  The other message queue has maximum of 500
-    pending messages with the message structure defined by the type
-    ``other_message_type``.
-    .. code-block:: c
-        #define CONFIGURE_MESSAGE_BUFFER_MEMORY \
-                    (CONFIGURE_MESSAGE_BUFFERS_FOR_QUEUE( \
-                         24, sizeof(one_message_type) \
-                     CONFIGURE_MESSAGE_BUFFERS_FOR_QUEUE( \
-                         500, sizeof(other_message_type) \
-.. index:: CONFIGURE_MESSAGE_BUFFERS_FOR_QUEUE
-.. index:: memory for a single message queue's buffers
-.. _CONFIGURE_MESSAGE_BUFFERS_FOR_QUEUE:
-CONFIGURE_MESSAGE_BUFFERS_FOR_QUEUE
-CONSTANT:
-    ``CONFIGURE_MESSAGE_BUFFERS_FOR_QUEUE(max_messages, size_per)``
-DATA TYPE:
-    Unsigned integer (``size_t``).
-RANGE:
-    Positive.
-DEFAULT VALUE:
-    The default value is None.
-DESCRIPTION:
-    This is a helper macro which is used to assist in computing the total
-    amount of memory required for message buffers.  Each message queue will
-    have its own configuration with maximum message size and maximum number of
-    pending messages.
-    The interface for this macro is as follows:
-    .. code-block:: c
-        CONFIGURE_MESSAGE_BUFFERS_FOR_QUEUE(max_messages, size_per)
-    Where ``max_messages`` is the maximum number of pending messages and
-    ``size_per`` is the size in bytes of the user message.
-NOTES:
-    This macro is only used in support of :ref:`CONFIGURE_MESSAGE_BUFFER_MEMORY`.
+    msgq-buffer-config
 Filesystem Configuration
diff --git a/c-user/config/msgq-buffer-config.rst b/c-user/config/msgq-buffer-config.rst
new file mode 100644
index 0000000..8d40149
--- /dev/null
+++ b/c-user/config/msgq-buffer-config.rst
@@ -0,0 +1,93 @@
+.. SPDX-License-Identifier: CC-BY-SA-4.0
+.. Copyright (C) 1988, 2008 On-Line Applications Research Corporation (OAR)
+Message Queue Buffer Configuration
+This section describes the configuration parameters related to specifying the
+amount of memory reserved for message queue message buffers.  See
+:ref:`CONFIGURE_MAXIMUM_MESSAGE_QUEUES` and
+:ref:`CONFIGURE_MAXIMUM_POSIX_MESSAGE_QUEUES`.
+.. index:: CONFIGURE_MESSAGE_BUFFER_MEMORY
+.. index:: configure message queue buffer memory
+.. _CONFIGURE_MESSAGE_BUFFER_MEMORY:
+CONFIGURE_MESSAGE_BUFFER_MEMORY
+CONSTANT:
+    ``CONFIGURE_MESSAGE_BUFFER_MEMORY``
+DATA TYPE:
+    integer summation macro
+RANGE:
+    undefined (zero) or calculation resulting in a positive integer
+DEFAULT VALUE:
+    This is not defined by default, and zero (0) memory is reserved.
+DESCRIPTION:
+    This macro is set to the number of bytes the application requires to be
+    reserved for pending Classic API Message Queue buffers.
+NOTES:
+    The following illustrates how the help macro
+    :ref:`CONFIGURE_MESSAGE_BUFFERS_FOR_QUEUE` can be used to assist in
+    calculating the message buffer memory required.  In this example, there are
+    two message queues used in this application.  The first message queue has
+    maximum of 24 pending messages with the message structure defined by the
+    type ``one_message_type``.  The other message queue has maximum of 500
+    pending messages with the message structure defined by the type
+    ``other_message_type``.
+    .. code-block:: c
+        #define CONFIGURE_MESSAGE_BUFFER_MEMORY \
+                    (CONFIGURE_MESSAGE_BUFFERS_FOR_QUEUE( \
+                         24, sizeof(one_message_type) \
+                     CONFIGURE_MESSAGE_BUFFERS_FOR_QUEUE( \
+                         500, sizeof(other_message_type) \
+.. index:: CONFIGURE_MESSAGE_BUFFERS_FOR_QUEUE
+.. index:: memory for a single message queue's buffers
+.. _CONFIGURE_MESSAGE_BUFFERS_FOR_QUEUE:
+CONFIGURE_MESSAGE_BUFFERS_FOR_QUEUE
+CONSTANT:
+    ``CONFIGURE_MESSAGE_BUFFERS_FOR_QUEUE(max_messages, size_per)``
+DATA TYPE:
+    Unsigned integer (``size_t``).
+RANGE:
+    Positive.
+DEFAULT VALUE:
+    The default value is None.
+DESCRIPTION:
+    This is a helper macro which is used to assist in computing the total
+    amount of memory required for message buffers.  Each message queue will
+    have its own configuration with maximum message size and maximum number of
+    pending messages.
+    The interface for this macro is as follows:
+    .. code-block:: c
+        CONFIGURE_MESSAGE_BUFFERS_FOR_QUEUE(max_messages, size_per)
+    Where ``max_messages`` is the maximum number of pending messages and
+    ``size_per`` is the size in bytes of the user message.
+NOTES:
+    This macro is only used in support of :ref:`CONFIGURE_MESSAGE_BUFFER_MEMORY`.
2.16.4
