[PATCH 09/20] c-user: Move "Filesystem Configuration"
Mon Mar 9 09:02:52 UTC 2020
Update #3836.
 c-user/config/filesystem-config.rst | 547 ++++++++++++++++++++++++++++++++++++
 c-user/config/index.rst             | 545 +----------------------------------
 2 files changed, 548 insertions(+), 544 deletions(-)
 create mode 100644 c-user/config/filesystem-config.rst
diff --git a/c-user/config/filesystem-config.rst b/c-user/config/filesystem-config.rst
new file mode 100644
index 0000000..063a8c3
--- /dev/null
+++ b/c-user/config/filesystem-config.rst
@@ -0,0 +1,547 @@
+.. SPDX-License-Identifier: CC-BY-SA-4.0
+.. Copyright (C) 1988, 2008 On-Line Applications Research Corporation (OAR)
+Filesystem Configuration
+By default, the In-Memory Filesystem (IMFS) is used as the base filesystem (also
+known as root filesystem).  In order to save some memory for your application,
+you can disable the filesystem support with the
+:ref:`CONFIGURE_APPLICATION_DISABLE_FILESYSTEM` configuration option.
+Alternatively, you can strip down the features of the base filesystem with the
+:ref:`CONFIGURE_USE_MINIIMFS_AS_BASE_FILESYSTEM` and
+:ref:`CONFIGURE_USE_DEVFS_AS_BASE_FILESYSTEM` configuration options.  These
+three configuration options are mutually exclusive.  They are intended for an
+advanced application configuration.
+Features of the IMFS can be disabled and enabled with the following
+configuration options:
+* :ref:`CONFIGURE_IMFS_DISABLE_CHMOD`
+* :ref:`CONFIGURE_IMFS_DISABLE_CHOWN`
+* :ref:`CONFIGURE_IMFS_DISABLE_LINK`
+* :ref:`CONFIGURE_IMFS_DISABLE_MKNOD`
+* :ref:`CONFIGURE_IMFS_DISABLE_MKNOD_FILE`
+* :ref:`CONFIGURE_IMFS_DISABLE_MOUNT`
+* :ref:`CONFIGURE_IMFS_DISABLE_READDIR`
+* :ref:`CONFIGURE_IMFS_DISABLE_READLINK`
+* :ref:`CONFIGURE_IMFS_DISABLE_RENAME`
+* :ref:`CONFIGURE_IMFS_DISABLE_RMNOD`
+* :ref:`CONFIGURE_IMFS_DISABLE_SYMLINK`
+* :ref:`CONFIGURE_IMFS_DISABLE_UNMOUNT`
+* :ref:`CONFIGURE_IMFS_DISABLE_UTIME`
+* :ref:`CONFIGURE_IMFS_ENABLE_MKFIFO`
+.. index:: CONFIGURE_APPLICATION_DISABLE_FILESYSTEM
+.. _CONFIGURE_APPLICATION_DISABLE_FILESYSTEM:
+CONFIGURE_APPLICATION_DISABLE_FILESYSTEM
+CONSTANT:
+    ``CONFIGURE_APPLICATION_DISABLE_FILESYSTEM``
+DATA TYPE:
+    Boolean feature macro.
+RANGE:
+    Defined or undefined.
+DEFAULT VALUE:
+    This is not defined by default. If no other root file system configuration
+    parameters are specified, the IMFS will be used as the root file system.
+DESCRIPTION:
+    This configuration parameter is defined if the application dose not intend
+    to use any kind of filesystem support. This include the device
+    infrastructure necessary to support ``printf()``.
+NOTES:
+    None.
+.. index:: CONFIGURE_IMFS_ENABLE_MKFIFO
+.. _CONFIGURE_IMFS_ENABLE_MKFIFO:
+CONFIGURE_IMFS_ENABLE_MKFIFO
+CONSTANT:
+    ``CONFIGURE_IMFS_ENABLE_MKFIFO``
+DATA TYPE:
+RANGE:
+DEFAULT VALUE:
+DESCRIPTION:
+    In case this configuration option is defined, then the support to make FIFOs
+    is enabled in the root IMFS.
+.. index:: CONFIGURE_IMFS_DISABLE_CHMOD
+.. _CONFIGURE_IMFS_DISABLE_CHMOD:
+CONFIGURE_IMFS_DISABLE_CHMOD
+CONSTANT:
+    ``CONFIGURE_IMFS_DISABLE_CHMOD``
+DATA TYPE:
+RANGE:
+DEFAULT VALUE:
+DESCRIPTION:
+    In case this configuration option is defined, then the support to change
+    the mode is disabled in the root IMFS.
+.. index:: CONFIGURE_IMFS_DISABLE_CHOWN
+.. _CONFIGURE_IMFS_DISABLE_CHOWN:
+CONFIGURE_IMFS_DISABLE_CHOWN
+CONSTANT:
+    ``CONFIGURE_IMFS_DISABLE_CHOWN``
+DATA TYPE:
+RANGE:
+DEFAULT VALUE:
+DESCRIPTION:
+    the owner is disabled in the root IMFS.
+.. index:: CONFIGURE_IMFS_DISABLE_LINK
+.. _CONFIGURE_IMFS_DISABLE_LINK:
+CONFIGURE_IMFS_DISABLE_LINK
+CONSTANT:
+    ``CONFIGURE_IMFS_DISABLE_LINK``
+DATA TYPE:
+RANGE:
+DEFAULT VALUE:
+DESCRIPTION:
+    In case this configuration option is defined, then the support to create
+    hard links is disabled in the root IMFS.
+.. index:: CONFIGURE_IMFS_DISABLE_MKNOD
+.. _CONFIGURE_IMFS_DISABLE_MKNOD:
+CONFIGURE_IMFS_DISABLE_MKNOD
+CONSTANT:
+    ``CONFIGURE_IMFS_DISABLE_MKNOD``
+DATA TYPE:
+RANGE:
+DEFAULT VALUE:
+DESCRIPTION:
+    directories, devices, regular files and FIFOs is disabled in the root IMFS.
+.. index:: CONFIGURE_IMFS_DISABLE_MKNOD_FILE
+.. _CONFIGURE_IMFS_DISABLE_MKNOD_FILE:
+CONFIGURE_IMFS_DISABLE_MKNOD_FILE
+CONSTANT:
+    ``CONFIGURE_IMFS_DISABLE_MKNOD_FILE``
+DATA TYPE:
+RANGE:
+DEFAULT VALUE:
+DESCRIPTION:
+    regular files is disabled in the root IMFS.
+.. index:: CONFIGURE_IMFS_DISABLE_MOUNT
+.. _CONFIGURE_IMFS_DISABLE_MOUNT:
+CONFIGURE_IMFS_DISABLE_MOUNT
+CONSTANT:
+    ``CONFIGURE_IMFS_DISABLE_MOUNT``
+DATA TYPE:
+RANGE:
+DEFAULT VALUE:
+DESCRIPTION:
+    In case this configuration option is defined, then the support to mount
+    other file systems is disabled in the root IMFS.
+.. index:: CONFIGURE_IMFS_DISABLE_READDIR
+.. _CONFIGURE_IMFS_DISABLE_READDIR:
+CONFIGURE_IMFS_DISABLE_READDIR
+CONSTANT:
+    ``CONFIGURE_IMFS_DISABLE_READDIR``
+DATA TYPE:
+RANGE:
+DEFAULT VALUE:
+DESCRIPTION:
+    In case this configuration option is defined, then the support to read a
+    directory is disabled in the root IMFS.  It is still possible to open nodes
+    in a directory.
+.. index:: CONFIGURE_IMFS_DISABLE_READLINK
+.. _CONFIGURE_IMFS_DISABLE_READLINK:
+CONFIGURE_IMFS_DISABLE_READLINK
+CONSTANT:
+    ``CONFIGURE_IMFS_DISABLE_READLINK``
+DATA TYPE:
+RANGE:
+DEFAULT VALUE:
+DESCRIPTION:
+    symbolic links is disabled in the root IMFS.
+.. index:: CONFIGURE_IMFS_DISABLE_RENAME
+.. _CONFIGURE_IMFS_DISABLE_RENAME:
+CONFIGURE_IMFS_DISABLE_RENAME
+CONSTANT:
+    ``CONFIGURE_IMFS_DISABLE_RENAME``
+DATA TYPE:
+RANGE:
+DEFAULT VALUE:
+DESCRIPTION:
+    In case this configuration option is defined, then the support to rename
+    nodes is disabled in the root IMFS.
+.. index:: CONFIGURE_IMFS_DISABLE_RMNOD
+.. _CONFIGURE_IMFS_DISABLE_RMNOD:
+CONFIGURE_IMFS_DISABLE_RMNOD
+CONSTANT:
+    ``CONFIGURE_IMFS_DISABLE_RMNOD``
+DATA TYPE:
+RANGE:
+DEFAULT VALUE:
+DESCRIPTION:
+    In case this configuration option is defined, then the support to remove
+.. index:: CONFIGURE_IMFS_DISABLE_SYMLINK
+.. _CONFIGURE_IMFS_DISABLE_SYMLINK:
+CONFIGURE_IMFS_DISABLE_SYMLINK
+CONSTANT:
+    ``CONFIGURE_IMFS_DISABLE_SYMLINK``
+DATA TYPE:
+RANGE:
+DEFAULT VALUE:
+DESCRIPTION:
+.. index:: CONFIGURE_IMFS_DISABLE_UNMOUNT
+.. _CONFIGURE_IMFS_DISABLE_UNMOUNT:
+CONFIGURE_IMFS_DISABLE_UNMOUNT
+CONSTANT:
+    ``CONFIGURE_IMFS_DISABLE_UNMOUNT``
+DATA TYPE:
+RANGE:
+DEFAULT VALUE:
+DESCRIPTION:
+    In case this configuration option is defined, then the support to unmount
+    file systems is disabled in the root IMFS.
+.. index:: CONFIGURE_IMFS_DISABLE_UTIME
+.. _CONFIGURE_IMFS_DISABLE_UTIME:
+CONFIGURE_IMFS_DISABLE_UTIME
+CONSTANT:
+    ``CONFIGURE_IMFS_DISABLE_UTIME``
+DATA TYPE:
+RANGE:
+DEFAULT VALUE:
+DESCRIPTION:
+    times is disabled in the root IMFS.
+.. index:: CONFIGURE_IMFS_MEMFILE_BYTES_PER_BLOCK
+.. _CONFIGURE_IMFS_MEMFILE_BYTES_PER_BLOCK:
+CONFIGURE_IMFS_MEMFILE_BYTES_PER_BLOCK
+CONSTANT:
+    ``CONFIGURE_IMFS_MEMFILE_BYTES_PER_BLOCK``
+DATA TYPE:
+RANGE:
+    Valid values for this configuration parameter are a power of two (2)
+    between 16 and 512 inclusive.  In other words, valid values are 16, 32, 64,
+    128, 256,and 512.
+DEFAULT VALUE:
+    The default IMFS block size is 128 bytes.
+DESCRIPTION:
+    This configuration parameter specifies the block size for in-memory files
+    managed by the IMFS. The configured block size has two impacts. The first
+    is the average amount of unused memory in the last block of each file. For
+    example, when the block size is 512, on average one-half of the last block
+    of each file will remain unused and the memory is wasted. In contrast, when
+    the block size is 16, the average unused memory per file is only 8
+    bytes. However, it requires more allocations for the same size file and
+    thus more overhead per block for the dynamic memory management.
+    Second, the block size has an impact on the maximum size file that can be
+    stored in the IMFS. With smaller block size, the maximum file size is
+    correspondingly smaller. The following shows the maximum file size possible
+    based on the configured block size:
+    - when the block size is 16 bytes, the maximum file size is 1,328 bytes.
+    - when the block size is 32 bytes, the maximum file size is 18,656 bytes.
+    - when the block size is 64 bytes, the maximum file size is 279,488 bytes.
+    - when the block size is 128 bytes, the maximum file size is 4,329,344 bytes.
+    - when the block size is 256 bytes, the maximum file size is 68,173,568 bytes.
+    - when the block size is 512 bytes, the maximum file size is 1,082,195,456
+      bytes.
+.. index:: CONFIGURE_MAXIMUM_DEVICES
+.. _CONFIGURE_MAXIMUM_DEVICES:
+CONFIGURE_MAXIMUM_DEVICES
+CONSTANT:
+    ``CONFIGURE_MAXIMUM_DEVICES``
+DATA TYPE:
+    Unsigned integer (``uint32_t``).
+RANGE:
+    Positive.
+DEFAULT VALUE:
+    If ``BSP_MAXIMUM_DEVICES`` is defined, then the default value is
+    ``BSP_MAXIMUM_DEVICES``, otherwise the default value is 4.
+DESCRIPTION:
+    ``CONFIGURE_MAXIMUM_DEVICES`` is defined to the number of individual
+    devices that may be registered in the device file system (devFS).
+NOTES:
+    This option is specific to the device file system (devFS) and should not be
+    confused with the ``CONFIGURE_MAXIMUM_DRIVERS`` option.  This parameter
+    only impacts the devFS and thus is only used by ``<rtems/confdefs.h>`` when
+    ``CONFIGURE_USE_DEVFS_AS_BASE_FILESYSTEM`` is specified.
+.. index:: CONFIGURE_USE_DEVFS_AS_BASE_FILESYSTEM
+.. _CONFIGURE_USE_DEVFS_AS_BASE_FILESYSTEM:
+CONFIGURE_USE_DEVFS_AS_BASE_FILESYSTEM
+CONSTANT:
+DATA TYPE:
+RANGE:
+DEFAULT VALUE:
+DESCRIPTION:
+    This configuration parameter is defined if the application wishes to use
+    the device-only filesytem as the root file system.
+NOTES:
+    The device-only filesystem supports only device nodes and is smaller in
+    executable code size than the full IMFS and miniIMFS.
+    The devFS is comparable in functionality to the pseudo-filesystem name
+    space provided before RTEMS release 4.5.0.
+.. index:: CONFIGURE_USE_MINIIMFS_AS_BASE_FILESYSTEM
+.. _CONFIGURE_USE_MINIIMFS_AS_BASE_FILESYSTEM:
+CONFIGURE_USE_MINIIMFS_AS_BASE_FILESYSTEM
+CONSTANT:
+    ``CONFIGURE_USE_MINIIMFS_AS_BASE_FILESYSTEM``
+DATA TYPE:
+RANGE:
+DEFAULT VALUE:
+DESCRIPTION:
+    In case this configuration option is defined, then the following
+    configuration options will be defined as well
+    - ``CONFIGURE_IMFS_DISABLE_CHMOD``,
+    - ``CONFIGURE_IMFS_DISABLE_CHOWN``,
+    - ``CONFIGURE_IMFS_DISABLE_UTIME``,
+    - ``CONFIGURE_IMFS_DISABLE_LINK``,
+    - ``CONFIGURE_IMFS_DISABLE_SYMLINK``,
+    - ``CONFIGURE_IMFS_DISABLE_READLINK``,
+    - ``CONFIGURE_IMFS_DISABLE_RENAME``, and
+    - ``CONFIGURE_IMFS_DISABLE_UNMOUNT``.
diff --git a/c-user/config/index.rst b/c-user/config/index.rst
index 5f5d3c1..1d559e6 100644
--- a/c-user/config/index.rst
+++ b/c-user/config/index.rst
@@ -19,550 +19,7 @@ Configuring a System
     posix-init-thread-config
     stack-alloc-config
     msgq-buffer-config
-Filesystem Configuration
-By default, the In-Memory Filesystem (IMFS) is used as the base filesystem (also
-known as root filesystem).  In order to save some memory for your application,
-you can disable the filesystem support with the
-:ref:`CONFIGURE_APPLICATION_DISABLE_FILESYSTEM` configuration option.
-Alternatively, you can strip down the features of the base filesystem with the
-:ref:`CONFIGURE_USE_MINIIMFS_AS_BASE_FILESYSTEM` and
-:ref:`CONFIGURE_USE_DEVFS_AS_BASE_FILESYSTEM` configuration options.  These
-three configuration options are mutually exclusive.  They are intended for an
-advanced application configuration.
-Features of the IMFS can be disabled and enabled with the following
-configuration options:
-* :ref:`CONFIGURE_IMFS_DISABLE_CHMOD`
-* :ref:`CONFIGURE_IMFS_DISABLE_CHOWN`
-* :ref:`CONFIGURE_IMFS_DISABLE_LINK`
-* :ref:`CONFIGURE_IMFS_DISABLE_MKNOD`
-* :ref:`CONFIGURE_IMFS_DISABLE_MKNOD_FILE`
-* :ref:`CONFIGURE_IMFS_DISABLE_MOUNT`
-* :ref:`CONFIGURE_IMFS_DISABLE_READDIR`
-* :ref:`CONFIGURE_IMFS_DISABLE_READLINK`
-* :ref:`CONFIGURE_IMFS_DISABLE_RENAME`
-* :ref:`CONFIGURE_IMFS_DISABLE_RMNOD`
-* :ref:`CONFIGURE_IMFS_DISABLE_SYMLINK`
-* :ref:`CONFIGURE_IMFS_DISABLE_UNMOUNT`
-* :ref:`CONFIGURE_IMFS_DISABLE_UTIME`
-* :ref:`CONFIGURE_IMFS_ENABLE_MKFIFO`
-.. index:: CONFIGURE_APPLICATION_DISABLE_FILESYSTEM
-.. _CONFIGURE_APPLICATION_DISABLE_FILESYSTEM:
-CONFIGURE_APPLICATION_DISABLE_FILESYSTEM
-CONSTANT:
-    ``CONFIGURE_APPLICATION_DISABLE_FILESYSTEM``
-DATA TYPE:
-    Boolean feature macro.
-RANGE:
-    Defined or undefined.
-DEFAULT VALUE:
-    This is not defined by default. If no other root file system configuration
-    parameters are specified, the IMFS will be used as the root file system.
-DESCRIPTION:
-    This configuration parameter is defined if the application dose not intend
-    to use any kind of filesystem support. This include the device
-    infrastructure necessary to support ``printf()``.
-NOTES:
-    None.
-.. index:: CONFIGURE_IMFS_ENABLE_MKFIFO
-.. _CONFIGURE_IMFS_ENABLE_MKFIFO:
-CONFIGURE_IMFS_ENABLE_MKFIFO
-CONSTANT:
-    ``CONFIGURE_IMFS_ENABLE_MKFIFO``
-DATA TYPE:
-RANGE:
-DEFAULT VALUE:
-DESCRIPTION:
-    In case this configuration option is defined, then the support to make FIFOs
-    is enabled in the root IMFS.
-.. index:: CONFIGURE_IMFS_DISABLE_CHMOD
-.. _CONFIGURE_IMFS_DISABLE_CHMOD:
-CONFIGURE_IMFS_DISABLE_CHMOD
-CONSTANT:
-DATA TYPE:
-RANGE:
-DEFAULT VALUE:
-DESCRIPTION:
-    In case this configuration option is defined, then the support to change
-    the mode is disabled in the root IMFS.
-.. index:: CONFIGURE_IMFS_DISABLE_CHOWN
-.. _CONFIGURE_IMFS_DISABLE_CHOWN:
-CONFIGURE_IMFS_DISABLE_CHOWN
-CONSTANT:
-DATA TYPE:
-RANGE:
-DEFAULT VALUE:
-DESCRIPTION:
-    the owner is disabled in the root IMFS.
-.. index:: CONFIGURE_IMFS_DISABLE_LINK
-.. _CONFIGURE_IMFS_DISABLE_LINK:
-CONFIGURE_IMFS_DISABLE_LINK
-CONSTANT:
-DATA TYPE:
-RANGE:
-DEFAULT VALUE:
-DESCRIPTION:
-    In case this configuration option is defined, then the support to create
-    hard links is disabled in the root IMFS.
-.. index:: CONFIGURE_IMFS_DISABLE_MKNOD
-.. _CONFIGURE_IMFS_DISABLE_MKNOD:
-CONFIGURE_IMFS_DISABLE_MKNOD
-CONSTANT:
-    ``CONFIGURE_IMFS_DISABLE_MKNOD``
-DATA TYPE:
-RANGE:
-DEFAULT VALUE:
-DESCRIPTION:
-    directories, devices, regular files and FIFOs is disabled in the root IMFS.
-.. index:: CONFIGURE_IMFS_DISABLE_MKNOD_FILE
-.. _CONFIGURE_IMFS_DISABLE_MKNOD_FILE:
-CONFIGURE_IMFS_DISABLE_MKNOD_FILE
-CONSTANT:
-    ``CONFIGURE_IMFS_DISABLE_MKNOD_FILE``
-DATA TYPE:
-RANGE:
-DEFAULT VALUE:
-DESCRIPTION:
-    regular files is disabled in the root IMFS.
-.. index:: CONFIGURE_IMFS_DISABLE_MOUNT
-.. _CONFIGURE_IMFS_DISABLE_MOUNT:
-CONFIGURE_IMFS_DISABLE_MOUNT
-CONSTANT:
-    ``CONFIGURE_IMFS_DISABLE_MOUNT``
-DATA TYPE:
-RANGE:
-DEFAULT VALUE:
-DESCRIPTION:
-    In case this configuration option is defined, then the support to mount
-    other file systems is disabled in the root IMFS.
-.. index:: CONFIGURE_IMFS_DISABLE_READDIR
-.. _CONFIGURE_IMFS_DISABLE_READDIR:
-CONFIGURE_IMFS_DISABLE_READDIR
-CONSTANT:
-    ``CONFIGURE_IMFS_DISABLE_READDIR``
-DATA TYPE:
-RANGE:
-DEFAULT VALUE:
-DESCRIPTION:
-    In case this configuration option is defined, then the support to read a
-    directory is disabled in the root IMFS.  It is still possible to open nodes
-    in a directory.
-.. index:: CONFIGURE_IMFS_DISABLE_READLINK
-.. _CONFIGURE_IMFS_DISABLE_READLINK:
-CONFIGURE_IMFS_DISABLE_READLINK
-CONSTANT:
-DATA TYPE:
-RANGE:
-DEFAULT VALUE:
-DESCRIPTION:
-    symbolic links is disabled in the root IMFS.
-.. index:: CONFIGURE_IMFS_DISABLE_RENAME
-.. _CONFIGURE_IMFS_DISABLE_RENAME:
-CONFIGURE_IMFS_DISABLE_RENAME
-CONSTANT:
-DATA TYPE:
-RANGE:
-DEFAULT VALUE:
-DESCRIPTION:
-    In case this configuration option is defined, then the support to rename
-    nodes is disabled in the root IMFS.
-.. index:: CONFIGURE_IMFS_DISABLE_RMNOD
-.. _CONFIGURE_IMFS_DISABLE_RMNOD:
-CONFIGURE_IMFS_DISABLE_RMNOD
-CONSTANT:
-    ``CONFIGURE_IMFS_DISABLE_RMNOD``
-DATA TYPE:
-RANGE:
-DEFAULT VALUE:
-DESCRIPTION:
-    In case this configuration option is defined, then the support to remove
-.. index:: CONFIGURE_IMFS_DISABLE_SYMLINK
-.. _CONFIGURE_IMFS_DISABLE_SYMLINK:
-CONFIGURE_IMFS_DISABLE_SYMLINK
-CONSTANT:
-DATA TYPE:
-RANGE:
-DEFAULT VALUE:
-DESCRIPTION:
-.. index:: CONFIGURE_IMFS_DISABLE_UNMOUNT
-.. _CONFIGURE_IMFS_DISABLE_UNMOUNT:
-CONFIGURE_IMFS_DISABLE_UNMOUNT
-CONSTANT:
-DATA TYPE:
-RANGE:
-DEFAULT VALUE:
-DESCRIPTION:
-    In case this configuration option is defined, then the support to unmount
-    file systems is disabled in the root IMFS.
-.. index:: CONFIGURE_IMFS_DISABLE_UTIME
-.. _CONFIGURE_IMFS_DISABLE_UTIME:
-CONFIGURE_IMFS_DISABLE_UTIME
-CONSTANT:
-DATA TYPE:
-RANGE:
-DEFAULT VALUE:
-DESCRIPTION:
-    times is disabled in the root IMFS.
-.. index:: CONFIGURE_IMFS_MEMFILE_BYTES_PER_BLOCK
-.. _CONFIGURE_IMFS_MEMFILE_BYTES_PER_BLOCK:
-CONFIGURE_IMFS_MEMFILE_BYTES_PER_BLOCK
-CONSTANT:
-    ``CONFIGURE_IMFS_MEMFILE_BYTES_PER_BLOCK``
-DATA TYPE:
-RANGE:
-    Valid values for this configuration parameter are a power of two (2)
-    between 16 and 512 inclusive.  In other words, valid values are 16, 32, 64,
-    128, 256,and 512.
-DEFAULT VALUE:
-    The default IMFS block size is 128 bytes.
-DESCRIPTION:
-    This configuration parameter specifies the block size for in-memory files
-    managed by the IMFS. The configured block size has two impacts. The first
-    is the average amount of unused memory in the last block of each file. For
-    example, when the block size is 512, on average one-half of the last block
-    of each file will remain unused and the memory is wasted. In contrast, when
-    the block size is 16, the average unused memory per file is only 8
-    bytes. However, it requires more allocations for the same size file and
-    thus more overhead per block for the dynamic memory management.
-    Second, the block size has an impact on the maximum size file that can be
-    stored in the IMFS. With smaller block size, the maximum file size is
-    correspondingly smaller. The following shows the maximum file size possible
-    based on the configured block size:
-    - when the block size is 16 bytes, the maximum file size is 1,328 bytes.
-    - when the block size is 32 bytes, the maximum file size is 18,656 bytes.
-    - when the block size is 64 bytes, the maximum file size is 279,488 bytes.
-    - when the block size is 128 bytes, the maximum file size is 4,329,344 bytes.
-    - when the block size is 256 bytes, the maximum file size is 68,173,568 bytes.
-    - when the block size is 512 bytes, the maximum file size is 1,082,195,456
-      bytes.
-.. index:: CONFIGURE_MAXIMUM_DEVICES
-.. _CONFIGURE_MAXIMUM_DEVICES:
-CONFIGURE_MAXIMUM_DEVICES
-CONSTANT:
-    ``CONFIGURE_MAXIMUM_DEVICES``
-DATA TYPE:
-    Unsigned integer (``uint32_t``).
-RANGE:
-    Positive.
-DEFAULT VALUE:
-    If ``BSP_MAXIMUM_DEVICES`` is defined, then the default value is
-    ``BSP_MAXIMUM_DEVICES``, otherwise the default value is 4.
-DESCRIPTION:
-    ``CONFIGURE_MAXIMUM_DEVICES`` is defined to the number of individual
-    devices that may be registered in the device file system (devFS).
-NOTES:
-    This option is specific to the device file system (devFS) and should not be
-    confused with the ``CONFIGURE_MAXIMUM_DRIVERS`` option.  This parameter
-    only impacts the devFS and thus is only used by ``<rtems/confdefs.h>`` when
-    ``CONFIGURE_USE_DEVFS_AS_BASE_FILESYSTEM`` is specified.
-.. index:: CONFIGURE_USE_DEVFS_AS_BASE_FILESYSTEM
-.. _CONFIGURE_USE_DEVFS_AS_BASE_FILESYSTEM:
-CONFIGURE_USE_DEVFS_AS_BASE_FILESYSTEM
-CONSTANT:
-DATA TYPE:
-RANGE:
-DEFAULT VALUE:
-DESCRIPTION:
-    This configuration parameter is defined if the application wishes to use
-    the device-only filesytem as the root file system.
-NOTES:
-    The device-only filesystem supports only device nodes and is smaller in
-    executable code size than the full IMFS and miniIMFS.
-    The devFS is comparable in functionality to the pseudo-filesystem name
-    space provided before RTEMS release 4.5.0.
-.. index:: CONFIGURE_USE_MINIIMFS_AS_BASE_FILESYSTEM
-.. _CONFIGURE_USE_MINIIMFS_AS_BASE_FILESYSTEM:
-CONFIGURE_USE_MINIIMFS_AS_BASE_FILESYSTEM
-CONSTANT:
-    ``CONFIGURE_USE_MINIIMFS_AS_BASE_FILESYSTEM``
-DATA TYPE:
-RANGE:
-DEFAULT VALUE:
-DESCRIPTION:
-    In case this configuration option is defined, then the following
-    configuration options will be defined as well
-    - ``CONFIGURE_IMFS_DISABLE_CHMOD``,
-    - ``CONFIGURE_IMFS_DISABLE_CHOWN``,
-    - ``CONFIGURE_IMFS_DISABLE_UTIME``,
-    - ``CONFIGURE_IMFS_DISABLE_LINK``,
-    - ``CONFIGURE_IMFS_DISABLE_SYMLINK``,
-    - ``CONFIGURE_IMFS_DISABLE_READLINK``,
-    - ``CONFIGURE_IMFS_DISABLE_RENAME``, and
-    - ``CONFIGURE_IMFS_DISABLE_UNMOUNT``.
+    filesystem-config
 Block Device Cache Configuration
2.16.4
