[PATCH 13/20] c-user: Move "General Scheduler Configuration"
Sebastian Huber
Mon Mar 9 09:02:56 UTC 2020
Update #3836.
c-user/config/general-sched-config.rst | 389 +++++++++++++++++++++++++++++++++
c-user/config/index.rst | 387 +-------------------------------
2 files changed, 390 insertions(+), 386 deletions(-)
create mode 100644 c-user/config/general-sched-config.rst
diff --git a/c-user/config/general-sched-config.rst b/c-user/config/general-sched-config.rst
new file mode 100644
index 0000000..05fce6e
--- /dev/null
+++ b/c-user/config/general-sched-config.rst
@@ -0,0 +1,389 @@
+.. SPDX-License-Identifier: CC-BY-SA-4.0
+.. Copyright (C) 2010 Gedare Bloom
+.. Copyright (C) 1988, 2008 On-Line Applications Research Corporation (OAR)
+General Scheduler Configuration
+This section defines the configuration parameters related to selecting a
+scheduling algorithm for an application. A scheduler configuration is optional
+and only necessary in very specific circumstances. A normal application
+configuration does not need any of the configuration options described in this
+section. By default, the :ref:`Deterministic Priority Scheduler
+<SchedulerPriority>` algorithm is used in uniprocessor configurations. In case
+SMP is enabled and the configured maximum processors
+(:ref:`CONFIGURE_MAXIMUM_PROCESSORS <CONFIGURE_MAXIMUM_PROCESSORS>`) is greater
+than one, then the :ref:`Earliest Deadline First (EDF) SMP Scheduler
+<SchedulerSMPEDF>` is selected as the default scheduler algorithm.
+For the :ref:`schedulers built into
+RTEMS <SchedulingConcepts>`, the configuration is straightforward. All that is
+required is to define the configuration macro which specifies which scheduler
+you want for in your application.
+The pluggable scheduler interface also enables the user to provide their own
+scheduling algorithm. If you choose to do this, you must define multiple
+configuration macros.
+.. index:: CONFIGURE_SCHEDULER_CBS
+.. _CONFIGURE_SCHEDULER_CBS:
+CONFIGURE_SCHEDULER_CBS
+CONSTANT:
+ ``CONFIGURE_SCHEDULER_CBS``
+DATA TYPE:
+ Boolean feature macro.
+RANGE:
+ Defined or undefined.
+DEFAULT VALUE:
+ This is not defined by default.
+DESCRIPTION:
+ If defined, then the :ref:`Constant Bandwidth Server (CBS) Scheduler
+ <SchedulerCBS>` algorithm is made available to the application.
+NOTES:
+ This scheduler configuration option is an advanced configuration option.
+ Think twice before you use it.
+ In case no explicit :ref:`clustered scheduler configuration
+ <ConfigurationSchedulersClustered>` is present, then it is used as the
+ scheduler for exactly one processor.
+.. index:: CONFIGURE_SCHEDULER_EDF
+.. _CONFIGURE_SCHEDULER_EDF:
+CONFIGURE_SCHEDULER_EDF
+CONSTANT:
+ ``CONFIGURE_SCHEDULER_EDF``
+DATA TYPE:
+RANGE:
+DEFAULT VALUE:
+DESCRIPTION:
+ If defined, then the :ref:`Earliest Deadline First (EDF) Scheduler
+ <SchedulerEDF>` algorithm is made available to the application.
+NOTES:
+.. index:: CONFIGURE_SCHEDULER_EDF_SMP
+.. _CONFIGURE_SCHEDULER_EDF_SMP:
+CONFIGURE_SCHEDULER_EDF_SMP
+CONSTANT:
+ ``CONFIGURE_SCHEDULER_EDF_SMP``
+DATA TYPE:
+RANGE:
+DEFAULT VALUE:
+DESCRIPTION:
+ If defined, then the :ref:`Earliest Deadline First (EDF) SMP Scheduler
+ <SchedulerSMPEDF>` algorithm is made available to the application.
+NOTES:
+ This scheduler algorithm is only available when RTEMS is built with SMP
+ support enabled.
+ scheduler for up to 32 processors.
+ This scheduler algorithm is the default in SMP configurations if
+ :ref:`CONFIGURE_MAXIMUM_PROCESSORS <CONFIGURE_MAXIMUM_PROCESSORS>` is
+ greater than one.
+.. index:: CONFIGURE_SCHEDULER_NAME
+.. _CONFIGURE_SCHEDULER_NAME:
+CONFIGURE_SCHEDULER_NAME
+CONSTANT:
+ ``CONFIGURE_SCHEDULER_NAME``
+DATA TYPE:
+ RTEMS Name (``rtems_name``).
+RANGE:
+ Any value.
+DEFAULT VALUE:
+ The default name is
+ - ``"MEDF"`` for the :ref:`EDF SMP Scheduler <SchedulerSMPEDF>`,
+ - ``"MPA "`` for the :ref:`Arbitrary Processor Affinity Priority SMP Scheduler <SchedulerSMPPriorityAffinity>`,
+ - ``"MPD "`` for the :ref:`Deterministic Priority SMP Scheduler <SchedulerSMPPriority>`,
+ - ``"MPS "`` for the :ref:`Simple Priority SMP Scheduler <SchedulerSMPPrioritySimple>`,
+ - ``"UCBS"`` for the :ref:`Uniprocessor CBS Scheduler <SchedulerCBS>`,
+ - ``"UEDF"`` for the :ref:`Uniprocessor EDF Scheduler <SchedulerEDF>`,
+ - ``"UPD "`` for the :ref:`Uniprocessor Deterministic Priority Scheduler <SchedulerPriority>`, and
+ - ``"UPS "`` for the :ref:`Uniprocessor Simple Priority Scheduler <SchedulerPrioritySimple>`.
+DESCRIPTION:
+ Schedulers can be identified via ``rtems_scheduler_ident``. The name of
+ the scheduler is determined by the configuration.
+NOTES:
+.. index:: CONFIGURE_SCHEDULER_PRIORITY
+.. _CONFIGURE_SCHEDULER_PRIORITY:
+CONFIGURE_SCHEDULER_PRIORITY
+CONSTANT:
+ ``CONFIGURE_SCHEDULER_PRIORITY``
+DATA TYPE:
+RANGE:
+DEFAULT VALUE:
+ This is defined by default. This is the default scheduler and specifying
+ this configuration parameter is redundant.
+DESCRIPTION:
+ If defined, then the :ref:`Deterministic Priority Scheduler
+ <SchedulerPriority>` algorithm is made available to the application.
+NOTES:
+ This scheduler algorithm is the default when
+ exactly one.
+ The memory allocated for this scheduler depends on the
+ :ref:`CONFIGURE_MAXIMUM_PRIORITY` configuration option.
+.. index:: CONFIGURE_SCHEDULER_PRIORITY_AFFINITY_SMP
+.. _CONFIGURE_SCHEDULER_PRIORITY_AFFINITY_SMP:
+CONFIGURE_SCHEDULER_PRIORITY_AFFINITY_SMP
+CONSTANT:
+ ``CONFIGURE_SCHEDULER_PRIORITY_AFFINITY_SMP``
+DATA TYPE:
+RANGE:
+DEFAULT VALUE:
+DESCRIPTION:
+ If defined, then the :ref:`Arbitrary Processor Affinity SMP Scheduler
+ <SchedulerSMPPriorityAffinity>` algorithm is made available to the
+ application.
+NOTES:
+ support enabled.
+.. index:: CONFIGURE_SCHEDULER_PRIORITY_SMP
+.. _CONFIGURE_SCHEDULER_PRIORITY_SMP:
+CONFIGURE_SCHEDULER_PRIORITY_SMP
+CONSTANT:
+ ``CONFIGURE_SCHEDULER_PRIORITY_SMP``
+DATA TYPE:
+RANGE:
+DEFAULT VALUE:
+DESCRIPTION:
+ If defined, then the :ref:`Deterministic Priority SMP Scheduler
+ <SchedulerSMPPriority>` algorithm is made available to the application.
+NOTES:
+ support enabled.
+.. index:: CONFIGURE_SCHEDULER_SIMPLE
+.. _CONFIGURE_SCHEDULER_SIMPLE:
+CONFIGURE_SCHEDULER_SIMPLE
+CONSTANT:
+ ``CONFIGURE_SCHEDULER_SIMPLE``
+DATA TYPE:
+RANGE:
+DEFAULT VALUE:
+DESCRIPTION:
+ If defined, then the :ref:`Simple Priority Scheduler
+ <SchedulerPrioritySimple>` algorithm is made available to the application.
+NOTES:
+.. index:: CONFIGURE_SCHEDULER_SIMPLE_SMP
+.. _CONFIGURE_SCHEDULER_SIMPLE_SMP:
+CONFIGURE_SCHEDULER_SIMPLE_SMP
+CONSTANT:
+ ``CONFIGURE_SCHEDULER_SIMPLE_SMP``
+DATA TYPE:
+RANGE:
+DEFAULT VALUE:
+DESCRIPTION:
+ If defined, then the :ref:`Simple Priority SMP Scheduler
+ <SchedulerSMPPrioritySimple>` algorithm is made available to the
+ application.
+NOTES:
+ support enabled.
+.. index:: CONFIGURE_SCHEDULER_USER
+.. _CONFIGURE_SCHEDULER_USER:
+CONFIGURE_SCHEDULER_USER
+CONSTANT:
+ ``CONFIGURE_SCHEDULER_USER``
+DATA TYPE:
+RANGE:
+DEFAULT VALUE:
+DESCRIPTION:
+ RTEMS allows the application to provide its own task/thread scheduling
+ algorithm. In order to do this, one must define
+ ``CONFIGURE_SCHEDULER_USER`` to indicate the application provides its own
+ scheduling algorithm. If ``CONFIGURE_SCHEDULER_USER`` is defined then the
+ following additional macros must be defined:
+ - ``CONFIGURE_SCHEDULER`` must be defined to a static definition of
+ the scheduler data structures of the user scheduler.
+ - ``CONFIGURE_SCHEDULER_TABLE_ENTRIES`` must be defined to a scheduler
+ table entry initializer for the user scheduler.
+ - ``CONFIGURE_SCHEDULER_USER_PER_THREAD`` must be defined to the type of
+ the per-thread information of the user scheduler.
+NOTES:
+ At this time, the mechanics and requirements for writing a new scheduler
+ are evolving and not fully documented. It is recommended that you look at
+ the existing Deterministic Priority Scheduler in
+ ``cpukit/score/src/schedulerpriority*.c`` for guidance. For guidance on
+ the configuration macros, please examine ``cpukit/sapi/include/confdefs.h``
+ for how these are defined for the Deterministic Priority Scheduler.
diff --git a/c-user/config/index.rst b/c-user/config/index.rst
index ca10d4a..5f9ccd5 100644
--- a/c-user/config/index.rst
+++ b/c-user/config/index.rst
@@ -1,6 +1,5 @@
-.. Copyright (C) 2010 Gedare Bloom
.. index:: configuring a system
@@ -23,391 +22,7 @@ Configuring a System
bdbuf-config
bsp-config
idle-task-config
-General Scheduler Configuration
-This section defines the configuration parameters related to selecting a
-scheduling algorithm for an application. A scheduler configuration is optional
-and only necessary in very specific circumstances. A normal application
-configuration does not need any of the configuration options described in this
-section. By default, the :ref:`Deterministic Priority Scheduler
-<SchedulerPriority>` algorithm is used in uniprocessor configurations. In case
-SMP is enabled and the configured maximum processors
-(:ref:`CONFIGURE_MAXIMUM_PROCESSORS <CONFIGURE_MAXIMUM_PROCESSORS>`) is greater
-than one, then the :ref:`Earliest Deadline First (EDF) SMP Scheduler
-<SchedulerSMPEDF>` is selected as the default scheduler algorithm.
-For the :ref:`schedulers built into
-RTEMS <SchedulingConcepts>`, the configuration is straightforward. All that is
-required is to define the configuration macro which specifies which scheduler
-you want for in your application.
-The pluggable scheduler interface also enables the user to provide their own
-scheduling algorithm. If you choose to do this, you must define multiple
-configuration macros.
-.. index:: CONFIGURE_SCHEDULER_CBS
-.. _CONFIGURE_SCHEDULER_CBS:
-CONFIGURE_SCHEDULER_CBS
-CONSTANT:
- ``CONFIGURE_SCHEDULER_CBS``
-DATA TYPE:
- Boolean feature macro.
-RANGE:
- Defined or undefined.
-DEFAULT VALUE:
- This is not defined by default.
-DESCRIPTION:
- If defined, then the :ref:`Constant Bandwidth Server (CBS) Scheduler
- <SchedulerCBS>` algorithm is made available to the application.
-NOTES:
- This scheduler configuration option is an advanced configuration option.
- Think twice before you use it.
- In case no explicit :ref:`clustered scheduler configuration
- <ConfigurationSchedulersClustered>` is present, then it is used as the
- scheduler for exactly one processor.
-.. index:: CONFIGURE_SCHEDULER_EDF
-.. _CONFIGURE_SCHEDULER_EDF:
-CONFIGURE_SCHEDULER_EDF
-CONSTANT:
- ``CONFIGURE_SCHEDULER_EDF``
-DATA TYPE:
-RANGE:
-DEFAULT VALUE:
-DESCRIPTION:
- If defined, then the :ref:`Earliest Deadline First (EDF) Scheduler
- <SchedulerEDF>` algorithm is made available to the application.
-NOTES:
-.. index:: CONFIGURE_SCHEDULER_EDF_SMP
-.. _CONFIGURE_SCHEDULER_EDF_SMP:
-CONFIGURE_SCHEDULER_EDF_SMP
-CONSTANT:
- ``CONFIGURE_SCHEDULER_EDF_SMP``
-DATA TYPE:
-RANGE:
-DEFAULT VALUE:
-DESCRIPTION:
- If defined, then the :ref:`Earliest Deadline First (EDF) SMP Scheduler
- <SchedulerSMPEDF>` algorithm is made available to the application.
-NOTES:
- This scheduler algorithm is only available when RTEMS is built with SMP
- support enabled.
- scheduler for up to 32 processors.
- This scheduler algorithm is the default in SMP configurations if
- :ref:`CONFIGURE_MAXIMUM_PROCESSORS <CONFIGURE_MAXIMUM_PROCESSORS>` is
- greater than one.
-.. index:: CONFIGURE_SCHEDULER_NAME
-.. _CONFIGURE_SCHEDULER_NAME:
-CONFIGURE_SCHEDULER_NAME
-CONSTANT:
- ``CONFIGURE_SCHEDULER_NAME``
-DATA TYPE:
- RTEMS Name (``rtems_name``).
-RANGE:
- Any value.
-DEFAULT VALUE:
- The default name is
- - ``"MEDF"`` for the :ref:`EDF SMP Scheduler <SchedulerSMPEDF>`,
- - ``"MPA "`` for the :ref:`Arbitrary Processor Affinity Priority SMP Scheduler <SchedulerSMPPriorityAffinity>`,
- - ``"MPD "`` for the :ref:`Deterministic Priority SMP Scheduler <SchedulerSMPPriority>`,
- - ``"MPS "`` for the :ref:`Simple Priority SMP Scheduler <SchedulerSMPPrioritySimple>`,
- - ``"UCBS"`` for the :ref:`Uniprocessor CBS Scheduler <SchedulerCBS>`,
- - ``"UEDF"`` for the :ref:`Uniprocessor EDF Scheduler <SchedulerEDF>`,
- - ``"UPD "`` for the :ref:`Uniprocessor Deterministic Priority Scheduler <SchedulerPriority>`, and
- - ``"UPS "`` for the :ref:`Uniprocessor Simple Priority Scheduler <SchedulerPrioritySimple>`.
-DESCRIPTION:
- Schedulers can be identified via ``rtems_scheduler_ident``. The name of
- the scheduler is determined by the configuration.
-NOTES:
-.. index:: CONFIGURE_SCHEDULER_PRIORITY
-.. _CONFIGURE_SCHEDULER_PRIORITY:
-CONFIGURE_SCHEDULER_PRIORITY
-CONSTANT:
- ``CONFIGURE_SCHEDULER_PRIORITY``
-DATA TYPE:
-RANGE:
-DEFAULT VALUE:
- This is defined by default. This is the default scheduler and specifying
- this configuration parameter is redundant.
-DESCRIPTION:
- If defined, then the :ref:`Deterministic Priority Scheduler
- <SchedulerPriority>` algorithm is made available to the application.
-NOTES:
- This scheduler algorithm is the default when
- exactly one.
- The memory allocated for this scheduler depends on the
- :ref:`CONFIGURE_MAXIMUM_PRIORITY` configuration option.
-.. index:: CONFIGURE_SCHEDULER_PRIORITY_AFFINITY_SMP
-.. _CONFIGURE_SCHEDULER_PRIORITY_AFFINITY_SMP:
-CONFIGURE_SCHEDULER_PRIORITY_AFFINITY_SMP
-CONSTANT:
- ``CONFIGURE_SCHEDULER_PRIORITY_AFFINITY_SMP``
-DATA TYPE:
-RANGE:
-DEFAULT VALUE:
-DESCRIPTION:
- If defined, then the :ref:`Arbitrary Processor Affinity SMP Scheduler
- <SchedulerSMPPriorityAffinity>` algorithm is made available to the
- application.
-NOTES:
- support enabled.
-.. index:: CONFIGURE_SCHEDULER_PRIORITY_SMP
-.. _CONFIGURE_SCHEDULER_PRIORITY_SMP:
-CONFIGURE_SCHEDULER_PRIORITY_SMP
-CONSTANT:
- ``CONFIGURE_SCHEDULER_PRIORITY_SMP``
-DATA TYPE:
-RANGE:
-DEFAULT VALUE:
-DESCRIPTION:
- If defined, then the :ref:`Deterministic Priority SMP Scheduler
- <SchedulerSMPPriority>` algorithm is made available to the application.
-NOTES:
- support enabled.
-.. index:: CONFIGURE_SCHEDULER_SIMPLE
-.. _CONFIGURE_SCHEDULER_SIMPLE:
-CONFIGURE_SCHEDULER_SIMPLE
-CONSTANT:
- ``CONFIGURE_SCHEDULER_SIMPLE``
-DATA TYPE:
-RANGE:
-DEFAULT VALUE:
-DESCRIPTION:
- If defined, then the :ref:`Simple Priority Scheduler
- <SchedulerPrioritySimple>` algorithm is made available to the application.
-NOTES:
-.. index:: CONFIGURE_SCHEDULER_SIMPLE_SMP
-.. _CONFIGURE_SCHEDULER_SIMPLE_SMP:
-CONFIGURE_SCHEDULER_SIMPLE_SMP
-CONSTANT:
- ``CONFIGURE_SCHEDULER_SIMPLE_SMP``
-DATA TYPE:
-RANGE:
-DEFAULT VALUE:
-DESCRIPTION:
- If defined, then the :ref:`Simple Priority SMP Scheduler
- <SchedulerSMPPrioritySimple>` algorithm is made available to the
- application.
-NOTES:
- support enabled.
-.. index:: CONFIGURE_SCHEDULER_USER
-.. _CONFIGURE_SCHEDULER_USER:
-CONFIGURE_SCHEDULER_USER
-CONSTANT:
- ``CONFIGURE_SCHEDULER_USER``
-DATA TYPE:
-RANGE:
-DEFAULT VALUE:
-DESCRIPTION:
- RTEMS allows the application to provide its own task/thread scheduling
- algorithm. In order to do this, one must define
- ``CONFIGURE_SCHEDULER_USER`` to indicate the application provides its own
- scheduling algorithm. If ``CONFIGURE_SCHEDULER_USER`` is defined then the
- following additional macros must be defined:
- - ``CONFIGURE_SCHEDULER`` must be defined to a static definition of
- the scheduler data structures of the user scheduler.
- - ``CONFIGURE_SCHEDULER_TABLE_ENTRIES`` must be defined to a scheduler
- table entry initializer for the user scheduler.
- - ``CONFIGURE_SCHEDULER_USER_PER_THREAD`` must be defined to the type of
- the per-thread information of the user scheduler.
-NOTES:
- At this time, the mechanics and requirements for writing a new scheduler
- are evolving and not fully documented. It is recommended that you look at
- the existing Deterministic Priority Scheduler in
- ``cpukit/score/src/schedulerpriority*.c`` for guidance. For guidance on
- the configuration macros, please examine ``cpukit/sapi/include/confdefs.h``
- for how these are defined for the Deterministic Priority Scheduler.
+ general-sched-config
.. _ConfigurationSchedulersClustered:
2.16.4
