[PATCH 12/20] c-user: Move "Idle Task Configuration"
Mon Mar 9 09:02:55 UTC 2020
Update #3836.
 c-user/config/idle-task-config | 96 ++++++++++++++++++++++++++++++++++++++++++
 c-user/config/index.rst        | 94 +----------------------------------------
 2 files changed, 97 insertions(+), 93 deletions(-)
 create mode 100644 c-user/config/idle-task-config
diff --git a/c-user/config/idle-task-config b/c-user/config/idle-task-config
new file mode 100644
index 0000000..ef8b192
--- /dev/null
+++ b/c-user/config/idle-task-config
@@ -0,0 +1,96 @@
+.. SPDX-License-Identifier: CC-BY-SA-4.0
+.. Copyright (C) 1988, 2008 On-Line Applications Research Corporation (OAR)
+Idle Task Configuration
+This section defines the IDLE task related configuration parameters supported
+by ``<rtems/confdefs.h>``.
+.. index:: CONFIGURE_IDLE_TASK_BODY
+.. _CONFIGURE_IDLE_TASK_BODY:
+CONFIGURE_IDLE_TASK_BODY
+CONSTANT:
+    ``CONFIGURE_IDLE_TASK_BODY``
+DATA TYPE:
+    Function pointer.
+RANGE:
+    Undefined or valid function pointer.
+DEFAULT VALUE:
+    This is not defined by default.
+DESCRIPTION:
+    ``CONFIGURE_IDLE_TASK_BODY`` is set to the function name corresponding to
+    the application specific IDLE thread body.  If not specified, the BSP or
+    RTEMS default IDLE thread body will be used.
+NOTES:
+    None.
+.. index:: CONFIGURE_IDLE_TASK_INITIALIZES_APPLICATION
+.. _CONFIGURE_IDLE_TASK_INITIALIZES_APPLICATION:
+CONFIGURE_IDLE_TASK_INITIALIZES_APPLICATION
+CONSTANT:
+    ``CONFIGURE_IDLE_TASK_INITIALIZES_APPLICATION``
+DATA TYPE:
+    Boolean feature macro.
+RANGE:
+    Defined or undefined.
+DEFAULT VALUE:
+    This is not defined by default, the user is assumed to provide one or more
+    initialization tasks.
+DESCRIPTION:
+    ``CONFIGURE_IDLE_TASK_INITIALIZES_APPLICATION`` is set to indicate that the
+    user has configured *NO* user initialization tasks or threads and that the
+    user provided IDLE task will perform application initialization and then
+    transform itself into an IDLE task.
+NOTES:
+    If you use this option be careful, the user IDLE task *CANNOT* block at all
+    during the initialization sequence.  Further, once application
+    initialization is complete, it must make itself preemptible and enter an
+    IDLE body loop.
+    The IDLE task must run at the lowest priority of all tasks in the system.
+.. index:: CONFIGURE_IDLE_TASK_STACK_SIZE
+.. _CONFIGURE_IDLE_TASK_STACK_SIZE:
+CONFIGURE_IDLE_TASK_STACK_SIZE
+CONSTANT:
+    ``CONFIGURE_IDLE_TASK_STACK_SIZE``
+DATA TYPE:
+    Unsigned integer (``size_t``).
+RANGE:
+    Undefined or positive.
+DEFAULT VALUE:
+    The default value is RTEMS_MINIMUM_STACK_SIZE.
+DESCRIPTION:
+    ``CONFIGURE_IDLE_TASK_STACK_SIZE`` is set to the desired stack size for the
+    IDLE task.
+NOTES:
+    None.
diff --git a/c-user/config/index.rst b/c-user/config/index.rst
index 821263d..ca10d4a 100644
--- a/c-user/config/index.rst
+++ b/c-user/config/index.rst
@@ -22,99 +22,7 @@ Configuring a System
     filesystem-config
     bdbuf-config
     bsp-config
-Idle Task Configuration
-This section defines the IDLE task related configuration parameters supported
-by ``<rtems/confdefs.h>``.
-.. index:: CONFIGURE_IDLE_TASK_BODY
-.. _CONFIGURE_IDLE_TASK_BODY:
-CONFIGURE_IDLE_TASK_BODY
-CONSTANT:
-    ``CONFIGURE_IDLE_TASK_BODY``
-DATA TYPE:
-    Function pointer.
-RANGE:
-    Undefined or valid function pointer.
-DEFAULT VALUE:
-    This is not defined by default.
-DESCRIPTION:
-    ``CONFIGURE_IDLE_TASK_BODY`` is set to the function name corresponding to
-    the application specific IDLE thread body.  If not specified, the BSP or
-    RTEMS default IDLE thread body will be used.
-NOTES:
-    None.
-.. index:: CONFIGURE_IDLE_TASK_INITIALIZES_APPLICATION
-.. _CONFIGURE_IDLE_TASK_INITIALIZES_APPLICATION:
-CONFIGURE_IDLE_TASK_INITIALIZES_APPLICATION
-CONSTANT:
-    ``CONFIGURE_IDLE_TASK_INITIALIZES_APPLICATION``
-DATA TYPE:
-    Boolean feature macro.
-RANGE:
-    Defined or undefined.
-DEFAULT VALUE:
-    This is not defined by default, the user is assumed to provide one or more
-    initialization tasks.
-DESCRIPTION:
-    ``CONFIGURE_IDLE_TASK_INITIALIZES_APPLICATION`` is set to indicate that the
-    user has configured *NO* user initialization tasks or threads and that the
-    user provided IDLE task will perform application initialization and then
-    transform itself into an IDLE task.
-NOTES:
-    If you use this option be careful, the user IDLE task *CANNOT* block at all
-    during the initialization sequence.  Further, once application
-    initialization is complete, it must make itself preemptible and enter an
-    IDLE body loop.
-    The IDLE task must run at the lowest priority of all tasks in the system.
-.. index:: CONFIGURE_IDLE_TASK_STACK_SIZE
-.. _CONFIGURE_IDLE_TASK_STACK_SIZE:
-CONFIGURE_IDLE_TASK_STACK_SIZE
-CONSTANT:
-    ``CONFIGURE_IDLE_TASK_STACK_SIZE``
-DATA TYPE:
-    Unsigned integer (``size_t``).
-RANGE:
-    Undefined or positive.
-DEFAULT VALUE:
-    The default value is RTEMS_MINIMUM_STACK_SIZE.
-DESCRIPTION:
-    ``CONFIGURE_IDLE_TASK_STACK_SIZE`` is set to the desired stack size for the
-    IDLE task.
-NOTES:
-    None.
+    idle-task-config
 General Scheduler Configuration
2.16.4
