Project Query for #3855 (BSP Buildset for EPICS)
Mon Mar 9 15:46:55 UTC 2020
On Mon, Mar 9, 2020 at 7:31 AM Mritunjay Sharma
<mritunjaysharma394 at gmail.com> wrote:
> Thank you, Chris, for such a detailed description of my query.
> Yes, sure. I would be more than happy to help with this fantastic idea proposed by Joel. I think I need to reschedule a few things in my proposal now. So before things start looking cleaner in my proposal, can we discuss more on our Bonus Project? Also, do I have to modify the title of the proposal now on https://devel.rtems.org/wiki/GSoC/2020 ?
No you don't need to modify the title.
The bonus task would be to carry out similar activities:
* compile CFS by hand, create an RSB "recipe" to build it, then
integrate it with vertical buildset configuration.
* create vertical buildsets for PC, Raspberry Pi, and other boards.
** EPICS community uses many powerpc boards so adding something there
would be good.
** Adding buildsets for the commonly available simulators would be good.
My understanding is that building EPICS7 with RTEMS5 is currently
non-trivial. I have CC'd Heinz Junkes from EPICS community, and he has
agreed intention to co-mentor/advise this project. He is the main
person that has been doing work with EPICS7/RTEMS5 so this will be a
great resource to lean on.
> Thanks
> Mritunjay
> On Mon, Mar 9, 2020 at 3:43 AM Chris Johns <chrisj at rtems.org> wrote:
>> On 9/3/20 9:05 am, Joel Sherrill wrote:
>> > Do you think it is full summer of work? I am wondering about a bonus project if
>> > it gets done early. CFS vertical stack might be a good option if no one signs up
>> > for that.
>> I was wondering that myself so this is a fantastic idea.
>> Can we also look at extending the project to create support to generate a, PC,
>> BBB or RPi ready to run SD card image?
>> Chris
> devel mailing list
> devel at rtems.org
