AW: [PATCH v2 3/3] i386: Port to RTEMS
Jan.Sommer at dlr.de
Tue Mar 10 08:12:57 UTC 2020
> -----Ursprüngliche Nachricht-----
> Von: Sommer, Jan
> Gesendet: Montag, 9. März 2020 16:11
> An: devel at rtems.org
> Cc: Sommer, Jan
> Betreff: [PATCH v2 3/3] i386: Port to RTEMS
> - Update imported files to compile rtems-libbsd for i386 based BSPs
> freebsd/sbin/sysctl/sysctl.c | 8 +
> freebsd/sys/dev/pci/pci_pci.c | 2 +
> freebsd/sys/i386/i386/legacy.c | 381 -------
> freebsd/sys/i386/include/machine/cpufunc.h | 2 +
> freebsd/sys/i386/include/machine/legacyvar.h | 63 -
> freebsd/sys/net/iflib.c | 26 +
> rtemsbsd/i386/include/machine/clock.h | 2 +
> rtemsbsd/include/rtems/bsd/local/opt_acpi.h | 0
> rtemsbsd/include/x86/legacyvar.h | 1 +
> rtemsbsd/include/x86/specialreg.h | 1074 ++++++++++++++++++
> rtemsbsd/include/x86/x86_var.h | 156 +++
> 11 files changed, 1271 insertions(+), 444 deletions(-)
> delete mode 100644 freebsd/sys/i386/i386/legacy.c
> delete mode 100644 freebsd/sys/i386/include/machine/legacyvar.h
> create mode 100644 rtemsbsd/i386/include/machine/clock.h
> create mode 100644 rtemsbsd/include/rtems/bsd/local/opt_acpi.h
> create mode 100644 rtemsbsd/include/x86/legacyvar.h
> create mode 100644 rtemsbsd/include/x86/specialreg.h
> create mode 100644 rtemsbsd/include/x86/x86_var.h
> diff --git a/freebsd/sys/net/iflib.c b/freebsd/sys/net/iflib.c
> index 89bc5e79..09282ac7 100644
> --- a/freebsd/sys/net/iflib.c
> +++ b/freebsd/sys/net/iflib.c
> @@ -1031,8 +1031,13 @@ iflib_netmap_txsync(struct netmap_kring *kring, int
> flags)
> if (!(ctx->ifc_flags & IFC_NETMAP_TX_IRQ))
> if (kring->nr_hwtail != nm_prev(kring->nr_hwcur, lim)) {
> +#ifndef __rtems__
> callout_reset_on(&txq->ift_timer, hz < 2000 ? 1 : hz /
> 1000,
> iflib_timer, txq, txq->ift_timer.c_cpu);
> +#else /* __rtems__ */
> + callout_reset_curcpu(&txq->ift_timer, hz < 2000 ? 1 : hz
> / 1000,
> + iflib_timer, txq);
I am not completely sure about all the side effects of replacing callout_reset_on with callout_reset_curcpu, but the struct callout has no "c_cpu" member in RTEMS.
If someone has a better idea, please tell me.
> +#endif /* __rtems__ */
> return (0);
