AW: [PATCH v2 3/3] i386: Port to RTEMS
Fri Mar 20 11:53:37 UTC 2020
On 10/03/2020 09:12, Jan.Sommer at dlr.de wrote:
>> diff --git a/freebsd/sys/net/iflib.c b/freebsd/sys/net/iflib.c
>> index 89bc5e79..09282ac7 100644
>> --- a/freebsd/sys/net/iflib.c
>> +++ b/freebsd/sys/net/iflib.c
>> @@ -1031,8 +1031,13 @@ iflib_netmap_txsync(struct netmap_kring *kring, int
>> flags)
>>   	if (!(ctx->ifc_flags & IFC_NETMAP_TX_IRQ))
>>   		if (kring->nr_hwtail != nm_prev(kring->nr_hwcur, lim)) {
>> +#ifndef __rtems__
>>   			callout_reset_on(&txq->ift_timer, hz < 2000 ? 1 : hz /
>> 1000,
>>   			    iflib_timer, txq, txq->ift_timer.c_cpu);
>> +#else /* __rtems__ */
>> +			callout_reset_curcpu(&txq->ift_timer, hz < 2000 ? 1 : hz
>> / 1000,
>> +			    iflib_timer, txq);
> I am not completely sure about all the side effects of replacing callout_reset_on with callout_reset_curcpu, but the struct callout has no "c_cpu" member in RTEMS.
> If someone has a better idea, please tell me.
I would change the callout_reset_on() macro and don't change the caller.
#ifndef __rtems__
#define    callout_reset_on(c, to_ticks, fn, arg, cpu) \
     callout_reset_sbt_on((c), tick_sbt * (to_ticks), 0, (fn), (arg),    \
         (cpu), C_HARDCLOCK)
         -1, C_HARDCLOCK)
#endif /* __rtems__ */
URL: <http://lists.rtems.org/pipermail/devel/attachments/20200320/82502f93/attachment-0001.html>
