[PATCH] Hello World
John kongtcheu
johnkongtcheu at gmail.com
Tue Mar 10 21:18:06 UTC 2020
Thank you for the information. I've been doing some research into the CAN
support and I think that it would definitely be a project that I would be
interested in. I am just a little curious though if there would be any
available mentors for this project, and if so would I have the green light
to start working on the first draft of the project?
Thanks again
On Mon, Mar 9, 2020 at 11:37 AM Gedare Bloom <gedare at rtems.org> wrote:
> Hi John,
> Thanks. Regarding BeagleBone Black (BBB) you should demonstrate that
> you can run RTEMS on the BBB during your proposal prep phase. You will
> need to dig to find out what remains to be done in this space. That
> said, there is a student with a proposal to advance Flattened Device
> Tree support so you would want to avoid that area. It's not clear to
> me what else remains to be done that is sufficiently interesting. I'd
> like to see if we can support the BBB with RTEMS "legacy" network
> stack and lwIP, then it could be a handy board for us as a project to
> use to test the networking infrastructure. This is related to
> https://devel.rtems.org/ticket/3850
> BBB is also a candidate for Controller Area Network (CAN) support (pun
> intended). Although we don't have active open project descriptions,
> that could be an area for expanding peripheral and library support. It
> does require some additional hardware to actually do any testing
> though. One can start with Qemu-emulated CAN support, which was added
> by a previous RTEMS GSoC student project.
> Gedare
> On Sun, Mar 8, 2020 at 11:30 AM John kongtcheu <johnkongtcheu at gmail.com>
> wrote:
> > ---------- Forwarded message ---------
> > From: John kongtcheu <johnkongtcheu at gmail.com>
> > Date: Sun, Feb 23, 2020 at 7:19 PM
> > Subject: Fwd: [PATCH] Hello World
> > To:
> > Cc: <devel at rtems.org>
> > Date: Sun, Feb 23, 2020, 6:53 PM
> > Subject: Re: [PATCH] Hello World
> > To: Gedare Bloom <gedare at rtems.org>, <joel at rtems.org>, <chrisj at rtems.org
> > Hello Gedare
> > I'm currently interested in the beagleboard black bsp project as of now.
> I'm interested in working with the peripherals regarding it.
> > Thank you,
> > On Sun, Feb 23, 2020 at 6:31 PM Gedare Bloom <gedare at rtems.org> wrote:
> >> Hi John,
> >> Thank you. If you're planning to apply for GSoC as a student, please
> >> also send me by email your screenshot, CC to joel at rtems.org and
> >> chrisj at rtems.org
> >> Begin to look through the Open Projects for what kinds of projects
> >> might interest you, and ask questions here about whether/which
> >> projects might be good for you to work on an application.
> >> Gedare
> >> On Sun, Feb 23, 2020 at 4:20 PM John Kongtcheu <johnkongtcheu at gmail.com>
> wrote:
> >> > testsuites/samples/hello/init.c | 2 +-
> >> > 1 file changed, 1 insertion(+), 1 deletion(-)
> >> > diff --git a/testsuites/samples/hello/init.c
> b/testsuites/samples/hello/init.c
> >> > index 34ded37c55..13aa377d95 100644
> >> > --- a/testsuites/samples/hello/init.c
> >> > +++ b/testsuites/samples/hello/init.c
> >> > @@ -22,7 +22,7 @@ static rtems_task Init(
> >> > rtems_print_printer_fprintf_putc(&rtems_test_printer);
> >> > TEST_BEGIN();
> >> > - printf( "Hello World\n" );
> >> > + printf( "This is John Kongtcheu's Hello World \n Welcome to RTEMS
> and Google Summer of Code 2020" );
> >> > TEST_END();
> >> > rtems_test_exit( 0 );
> >> > 2.17.1
> >> > _______________________________________________
> >> > devel mailing list
> >> > devel at rtems.org
> >> > http://lists.rtems.org/mailman/listinfo/devel
> > devel mailing list
> > devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20200310/8e469a16/attachment-0001.html>
