[PATCH] Hello World
Gedare Bloom
gedare at rtems.org
Tue Mar 10 22:12:23 UTC 2020
I would be willing to mentor a CAN project. Perhaps another will come
along. If your proposal truly shines, a mentor may be found.
On Tue, Mar 10, 2020 at 3:18 PM John kongtcheu <johnkongtcheu at gmail.com> wrote:
> Thank you for the information. I've been doing some research into the CAN support and I think that it would definitely be a project that I would be interested in. I am just a little curious though if there would be any available mentors for this project, and if so would I have the green light to start working on the first draft of the project?
> Thanks again
> On Mon, Mar 9, 2020 at 11:37 AM Gedare Bloom <gedare at rtems.org> wrote:
>> Hi John,
>> Thanks. Regarding BeagleBone Black (BBB) you should demonstrate that
>> you can run RTEMS on the BBB during your proposal prep phase. You will
>> need to dig to find out what remains to be done in this space. That
>> said, there is a student with a proposal to advance Flattened Device
>> Tree support so you would want to avoid that area. It's not clear to
>> me what else remains to be done that is sufficiently interesting. I'd
>> like to see if we can support the BBB with RTEMS "legacy" network
>> stack and lwIP, then it could be a handy board for us as a project to
>> use to test the networking infrastructure. This is related to
>> https://devel.rtems.org/ticket/3850
>> BBB is also a candidate for Controller Area Network (CAN) support (pun
>> intended). Although we don't have active open project descriptions,
>> that could be an area for expanding peripheral and library support. It
>> does require some additional hardware to actually do any testing
>> though. One can start with Qemu-emulated CAN support, which was added
>> by a previous RTEMS GSoC student project.
>> Gedare
>> On Sun, Mar 8, 2020 at 11:30 AM John kongtcheu <johnkongtcheu at gmail.com> wrote:
>> > ---------- Forwarded message ---------
>> > From: John kongtcheu <johnkongtcheu at gmail.com>
>> > Date: Sun, Feb 23, 2020 at 7:19 PM
>> > Subject: Fwd: [PATCH] Hello World
>> > To:
>> > Cc: <devel at rtems.org>
>> > Date: Sun, Feb 23, 2020, 6:53 PM
>> > Subject: Re: [PATCH] Hello World
>> > To: Gedare Bloom <gedare at rtems.org>, <joel at rtems.org>, <chrisj at rtems.org>
>> > Hello Gedare
>> > I'm currently interested in the beagleboard black bsp project as of now. I'm interested in working with the peripherals regarding it.
>> > Thank you,
>> > On Sun, Feb 23, 2020 at 6:31 PM Gedare Bloom <gedare at rtems.org> wrote:
>> >> Hi John,
>> >> Thank you. If you're planning to apply for GSoC as a student, please
>> >> also send me by email your screenshot, CC to joel at rtems.org and
>> >> chrisj at rtems.org
>> >> Begin to look through the Open Projects for what kinds of projects
>> >> might interest you, and ask questions here about whether/which
>> >> projects might be good for you to work on an application.
>> >> Gedare
>> >> On Sun, Feb 23, 2020 at 4:20 PM John Kongtcheu <johnkongtcheu at gmail.com> wrote:
>> >> > testsuites/samples/hello/init.c | 2 +-
>> >> > 1 file changed, 1 insertion(+), 1 deletion(-)
>> >> > diff --git a/testsuites/samples/hello/init.c b/testsuites/samples/hello/init.c
>> >> > index 34ded37c55..13aa377d95 100644
>> >> > --- a/testsuites/samples/hello/init.c
>> >> > +++ b/testsuites/samples/hello/init.c
>> >> > @@ -22,7 +22,7 @@ static rtems_task Init(
>> >> > rtems_print_printer_fprintf_putc(&rtems_test_printer);
>> >> > TEST_BEGIN();
>> >> > - printf( "Hello World\n" );
>> >> > + printf( "This is John Kongtcheu's Hello World \n Welcome to RTEMS and Google Summer of Code 2020" );
>> >> > TEST_END();
>> >> > rtems_test_exit( 0 );
>> >> > 2.17.1
>> >> > _______________________________________________
>> >> > devel mailing list
>> >> > devel at rtems.org
>> >> > http://lists.rtems.org/mailman/listinfo/devel
>> > devel mailing list
>> > devel at rtems.org
