Any short projects available?
Christian Mauderer list at c-mauderer.de
Tue Mar 10 21:49:27 UTC 2020
Hello Niteesh,
currently the release process for 5.1 is very active. Maybe you want to
take a look whether you can support some small tasks there:
https://devel.rtems.org/query?status=assigned&status=accepted&status=reopened&group=status&milestone=5.1
https://devel.rtems.org/query?status=new&group=status&milestone=5.1
For example:
Testing the patch I added here: https://devel.rtems.org/ticket/3903
Or adding a test: https://devel.rtems.org/ticket/3889 or
https://devel.rtems.org/ticket/3890
Best regards
Christian
On 10/03/2020 18:32, G. S. Niteesh wrote:
> Hii,
> I interested in taking up small tasks/projects as a primer for GSoC.
> I am mostly interested in drivers, build system, core (Schedulers, MPU, etc)
> part of RTEMS.
> I am also okay with large projects if small ones aren't available. I'll
> start learning
> about them and will start working after GSoC.
> Thank you,
> Niteesh.
