[PATCH 01/20] c-user: Split up configuring_a_system.rst
Wed Mar 11 18:29:00 UTC 2020
On 11/3/20 10:39 pm, Sebastian Huber wrote:
> In this patch set please have a look at the new directory name "c-user/config"
> for the application configuration options and the file names in this directory.
Thank you for the heads up and for making the change. It looks good. I have one
question ...
Is the trailing `-config` in the file names needed, ie *-config.rst, as you end
up with `config/*-config.rst? Is the config implied because you now have a
config directory?
