[PATCH 01/20] c-user: Split up configuring_a_system.rst
Sebastian Huber
Wed Mar 11 20:12:42 UTC 2020
On 11/03/2020 19:29, Chris Johns wrote:
> On 11/3/20 10:39 pm, Sebastian Huber wrote:
>> In this patch set please have a look at the new directory name "c-user/config"
>> for the application configuration options and the file names in this directory.
> Thank you for the heads up and for making the change. It looks good. I have one
> question ...
> Is the trailing `-config` in the file names needed, ie *-config.rst, as you end
> up with `config/*-config.rst? Is the config implied because you now have a
> config directory?
Yes, I asked myself this question when I look at the patch set today. I
will remove it to get shorter paths.
