[PATCH 2/3] rtems: Add rtems_put_char()
Sebastian Huber
Fri Mar 13 12:02:03 UTC 2020
Update #3904.
cpukit/Makefile.am | 1 +
cpukit/include/rtems/bspIo.h | 10 +++++++++
cpukit/libcsupport/src/rtems_put_char.c | 38 +++++++++++++++++++++++++++++++++
cpukit/libcsupport/src/vprintk.c | 7 +-----
4 files changed, 50 insertions(+), 6 deletions(-)
create mode 100644 cpukit/libcsupport/src/rtems_put_char.c
diff --git a/cpukit/Makefile.am b/cpukit/Makefile.am
index 968c52fe44..633f063b7d 100644
--- a/cpukit/Makefile.am
+++ b/cpukit/Makefile.am
@@ -219,6 +219,7 @@ librtemscpu_a_SOURCES += libcsupport/src/rtems_heap_null_extend.c
librtemscpu_a_SOURCES += libcsupport/src/rtems_memalign.c
librtemscpu_a_SOURCES += libcsupport/src/rtems_mkdir.c
librtemscpu_a_SOURCES += libcsupport/src/rtems_putc.c
+librtemscpu_a_SOURCES += libcsupport/src/rtems_put_char.c
librtemscpu_a_SOURCES += libcsupport/src/setegid.c
librtemscpu_a_SOURCES += libcsupport/src/seteuid.c
librtemscpu_a_SOURCES += libcsupport/src/setgid.c
diff --git a/cpukit/include/rtems/bspIo.h b/cpukit/include/rtems/bspIo.h
index c906a9a33b..facd953389 100644
--- a/cpukit/include/rtems/bspIo.h
+++ b/cpukit/include/rtems/bspIo.h
@@ -135,6 +135,16 @@ extern int putk(const char *s);
extern void rtems_putc(char c);
+ * @brief Puts the character via rtems_putc().
+ * This is a compatibility function to support an internal APIs.
+ * @param c The character to put.
+ * @param arg Ignored.
+void rtems_put_char( int c, void *arg );
#ifdef __cplusplus
diff --git a/cpukit/libcsupport/src/rtems_put_char.c b/cpukit/libcsupport/src/rtems_put_char.c
new file mode 100644
index 0000000000..1c141f106b
--- /dev/null
+++ b/cpukit/libcsupport/src/rtems_put_char.c
@@ -0,0 +1,38 @@
+ * Copyright (C) 2020 embedded brains GmbH (http://www.embedded-brains.de)
+ * are met:
+ * notice, this list of conditions and the following disclaimer.
+ * notice, this list of conditions and the following disclaimer in the
+ * documentation and/or other materials provided with the distribution.
+#if HAVE_CONFIG_H
+#include "config.h"
+#endif
+#include <rtems/bspIo.h>
+ (void) arg;
+ rtems_putc( (char) c );
diff --git a/cpukit/libcsupport/src/vprintk.c b/cpukit/libcsupport/src/vprintk.c
index 09b6f0f006..b5842fbea3 100644
--- a/cpukit/libcsupport/src/vprintk.c
+++ b/cpukit/libcsupport/src/vprintk.c
@@ -26,12 +26,7 @@
#include <rtems/score/io.h>
-static void vprintk_putchar( int c, void *arg )
- rtems_putc((char) c);
int vprintk( const char *fmt, va_list ap )
- return _IO_Vprintf( vprintk_putchar, NULL, fmt, ap );
+ return _IO_Vprintf( rtems_put_char, NULL, fmt, ap );
2.16.4
