[PATCH 3/3] record: Add rtems_record_dump()
Sebastian Huber
Fri Mar 13 12:02:04 UTC 2020
Add rtems_record_dump_base64() and rtems_record_dump_zlib_base64().
Add CONFIGURE_RECORD_FATAL_DUMP_BASE64 and
CONFIGURE_RECORD_FATAL_DUMP_ZLIB_BASE64 configuration options.
Update #3904.
cpukit/Makefile.am | 5 +
cpukit/headers.am | 1 +
cpukit/include/rtems/confdefs/extensions.h | 18 ++-
cpukit/include/rtems/record.h | 32 +++---
cpukit/include/rtems/recorddump.h | 118 ++++++++++++++++++++
cpukit/libtrace/record/record-dump-base64.c | 110 ++++++++++++++++++
cpukit/libtrace/record/record-dump-fatal.c | 50 +++++++++
cpukit/libtrace/record/record-dump-zbase64.c | 160 +++++++++++++++++++++++++++
cpukit/libtrace/record/record-dump-zfatal.c | 52 +++++++++
cpukit/libtrace/record/record-dump.c | 108 ++++++++++++++++++
testsuites/libtests/Makefile.am | 1 +
testsuites/libtests/record02/init.c | 38 +++++--
12 files changed, 664 insertions(+), 29 deletions(-)
create mode 100644 cpukit/include/rtems/recorddump.h
create mode 100644 cpukit/libtrace/record/record-dump-base64.c
create mode 100644 cpukit/libtrace/record/record-dump-fatal.c
create mode 100644 cpukit/libtrace/record/record-dump-zbase64.c
create mode 100644 cpukit/libtrace/record/record-dump-zfatal.c
create mode 100644 cpukit/libtrace/record/record-dump.c
diff --git a/cpukit/Makefile.am b/cpukit/Makefile.am
index 633f063b7d..3af69bd615 100644
--- a/cpukit/Makefile.am
+++ b/cpukit/Makefile.am
@@ -471,6 +471,11 @@ librtemscpu_a_SOURCES += libstdthreads/thrd.c
librtemscpu_a_SOURCES += libstdthreads/tss.c
librtemscpu_a_SOURCES += libtrace/record/record.c
librtemscpu_a_SOURCES += libtrace/record/record-client.c
+librtemscpu_a_SOURCES += libtrace/record/record-dump.c
+librtemscpu_a_SOURCES += libtrace/record/record-dump-fatal.c
+librtemscpu_a_SOURCES += libtrace/record/record-dump-zfatal.c
+librtemscpu_a_SOURCES += libtrace/record/record-dump-base64.c
+librtemscpu_a_SOURCES += libtrace/record/record-dump-zbase64.c
librtemscpu_a_SOURCES += libtrace/record/record-server.c
librtemscpu_a_SOURCES += libtrace/record/record-sysinit.c
librtemscpu_a_SOURCES += libtrace/record/record-text.c
diff --git a/cpukit/headers.am b/cpukit/headers.am
index 4a93e7b224..fcf679f09d 100644
--- a/cpukit/headers.am
+++ b/cpukit/headers.am
@@ -139,6 +139,7 @@ include_rtems_HEADERS += include/rtems/rbtree.h
include_rtems_HEADERS += include/rtems/record.h
include_rtems_HEADERS += include/rtems/recordclient.h
include_rtems_HEADERS += include/rtems/recorddata.h
+include_rtems_HEADERS += include/rtems/recorddump.h
include_rtems_HEADERS += include/rtems/recordserver.h
include_rtems_HEADERS += include/rtems/ringbuf.h
include_rtems_HEADERS += include/rtems/rtc.h
diff --git a/cpukit/include/rtems/confdefs/extensions.h b/cpukit/include/rtems/confdefs/extensions.h
index cf53e0d573..3aa43973ea 100644
--- a/cpukit/include/rtems/confdefs/extensions.h
+++ b/cpukit/include/rtems/confdefs/extensions.h
@@ -79,7 +79,23 @@ extern "C" {
const User_extensions_Table _User_extensions_Initial_extensions[] = {
#if CONFIGURE_RECORD_PER_PROCESSOR_ITEMS > 0 \
&& defined(CONFIGURE_RECORD_EXTENSIONS_ENABLED)
- RECORD_EXTENSION,
+ _Record_Thread_create,
+ _Record_Thread_start,
+ _Record_Thread_restart,
+ _Record_Thread_delete,
+ _Record_Thread_switch,
+ _Record_Thread_begin,
+ _Record_Thread_exitted,
+ #ifdef CONFIGURE_RECORD_FATAL_DUMP_ZLIB_BASE64
+ _Record_Fatal_dump_zlib_base64,
+ #elif defined(CONFIGURE_RECORD_FATAL_DUMP_BASE64)
+ _Record_Fatal_dump_base64,
+ #else
+ NULL,
+ #endif
+ _Record_Thread_terminate
#endif
#ifdef _CONFIGURE_ENABLE_NEWLIB_REENTRANCY
RTEMS_NEWLIB_EXTENSION,
diff --git a/cpukit/include/rtems/record.h b/cpukit/include/rtems/record.h
index 4e1c469173..7c57476c64 100644
--- a/cpukit/include/rtems/record.h
+++ b/cpukit/include/rtems/record.h
@@ -1,7 +1,7 @@
- * SPDX-License-Identifier: BSD-2-Clause
- * Copyright (C) 2018, 2019 embedded brains GmbH
+ * Copyright (C) 2018, 2020 embedded brains GmbH (http://www.embedded-brains.de)
* modification, are permitted provided that the following conditions
@@ -32,6 +32,7 @@
#include <rtems/score/atomic.h>
#include <rtems/score/cpu.h>
+#include <rtems/score/interr.h>
#include <rtems/counter.h>
@@ -95,23 +96,22 @@ void _Record_Thread_begin( struct _Thread_Control *executing );
void _Record_Thread_exitted( struct _Thread_Control *executing );
+void _Record_Fatal_dump_base64(
+ Internal_errors_Source source,
+ bool always_set_to_false,
+ Internal_errors_t code
+void _Record_Fatal_dump_zlib_base64(
void _Record_Thread_terminate(
-#define RECORD_EXTENSION \
- _Record_Thread_create, \
- _Record_Thread_start, \
- _Record_Thread_restart, \
- _Record_Thread_delete, \
- _Record_Thread_switch, \
- _Record_Thread_begin, \
- _Record_Thread_exitted, \
- NULL, \
- _Record_Thread_terminate \
RTEMS_INLINE_ROUTINE unsigned int _Record_Index(
const Record_Control *control,
unsigned int index
diff --git a/cpukit/include/rtems/recorddump.h b/cpukit/include/rtems/recorddump.h
new file mode 100644
index 0000000000..ad7039312b
--- /dev/null
+++ b/cpukit/include/rtems/recorddump.h
@@ -0,0 +1,118 @@
+ * Copyright (C) 2020 embedded brains GmbH (http://www.embedded-brains.de)
+ * are met:
+ * notice, this list of conditions and the following disclaimer.
+ * notice, this list of conditions and the following disclaimer in the
+ * documentation and/or other materials provided with the distribution.
+#ifndef _RTEMS_RECORDDUMP_H
+#define _RTEMS_RECORDDUMP_H
+#include <rtems/record.h>
+#include <zlib.h>
+#ifdef __cplusplus
+extern "C" {
+#endif /* __cplusplus */
+ * @addtogroup RTEMSRecord
+ * @brief Handler for record dumps to output a chunk of data.
+ * @param arg The argument passed to rtems_record_dump().
+ * @param data The begin of the data chunk.
+ * @param length The length in bytes of the data chunk.
+typedef void ( *rtems_record_dump_chunk )(
+ void *arg,
+ const void *data,
+ size_t length
+ * @brief Dumps the record header, the thread names, and all items of all
+ * processors.
+ * @param chunk Handler to dump a chunk of data.
+ * @param flush Handler to flush the data.
+ * @param arg The argument for the handlers.
+void rtems_record_dump(
+ rtems_record_dump_chunk chunk,
+ void *arg
+ * @brief Dumps the event records in base64 encoding.
+ * @param put_char The put char handler.
+ * @param arg The argument for the put char handler.
+ * @see rtems_record_dump().
+void rtems_record_dump_base64( void ( *put_char )( int, void * ), void *arg );
+ * @brief The context for record dumps with zlib compression and base64
+ * encoding.
+typedef struct {
+ void ( *put_char )( int, void * );
+ void *arg;
+ int out;
+ unsigned char buf[ 57 ];
+ z_stream stream;
+ char *mem_begin;
+ size_t mem_available;
+ char mem[ 0x80000 ];
+} rtems_record_dump_zlib_base64_context;
+ * @brief Dumps the event records compressed with zlib in base64 encoding.
+ * @param ctx The context to perform the record dump with zlib compression and
+ * base64 encoding. This context is too large for normal stack sizes.
+void rtems_record_dump_zlib_base64(
+ rtems_record_dump_zlib_base64_context *ctx,
+ void ( *put_char )( int, void * ),
+ void *arg
+#ifdef __cplusplus
+#endif /* _RTEMS_RECORDDUMP_H */
diff --git a/cpukit/libtrace/record/record-dump-base64.c b/cpukit/libtrace/record/record-dump-base64.c
index 0000000000..618a00414e
--- /dev/null
+++ b/cpukit/libtrace/record/record-dump-base64.c
@@ -0,0 +1,110 @@
+ * are met:
+#if HAVE_CONFIG_H
+#include "config.h"
+#endif
+#include <rtems/recorddump.h>
+#include <rtems/score/io.h>
+#include <limits.h>
+#include <string.h>
+typedef struct {
+ IO_Put_char put_char;
+ void *arg;
+ int out;
+ size_t index;
+ char buf[ 57 ];
+} dump_context;
+static void put_char( int c, void *arg )
+ dump_context *ctx;
+ ctx = arg;
+ ( *ctx->put_char )( c, ctx->arg );
+ ++ctx->out;
+ if ( ctx->out >= 76 ) {
+ ctx->out = 0;
+ ( *ctx->put_char )( '\n', ctx->arg );
+static void chunk( void *arg, const void *data, size_t length )
+ size_t index;
+ const char *in;
+ const void *end;
+ ctx = arg;
+ index = ctx->index;
+ in = data;
+ end = in + length;
+ while ( in != end ) {
+ ctx->buf[ index ] = *in;
+ ++in;
+ if ( index == RTEMS_ARRAY_SIZE( ctx->buf ) - 1 ) {
+ index = 0;
+ _IO_Base64(
+ put_char,
+ ctx,
+ ctx->buf,
+ sizeof( ctx->buf ),
+ NULL,
+ INT_MAX
+ } else {
+ ++index;
+ ctx->index = index;
+static void flush( dump_context *ctx )
+ _IO_Base64( put_char, ctx, ctx->buf, ctx->index, NULL, INT_MAX );
+void rtems_record_dump_base64( IO_Put_char put_char, void *arg )
+ dump_context ctx;
+ memset( &ctx, 0, sizeof( ctx ) );
+ ctx.put_char = put_char;
+ ctx.arg = arg;
+ rtems_record_dump( chunk, &ctx );
+ flush( &ctx );
diff --git a/cpukit/libtrace/record/record-dump-fatal.c b/cpukit/libtrace/record/record-dump-fatal.c
index 0000000000..faadfeb201
--- /dev/null
+++ b/cpukit/libtrace/record/record-dump-fatal.c
@@ -0,0 +1,50 @@
+ * are met:
+#if HAVE_CONFIG_H
+#endif
+#include <rtems/bspIo.h>
+ rtems_record_produce_2(
+ RTEMS_RECORD_FATAL_SOURCE,
+ source,
+ RTEMS_RECORD_FATAL_CODE,
+ code
+ printk( "\n*** BEGIN OF BASE64 RECORDS ***\n" );
+ rtems_record_dump_base64( rtems_put_char, NULL );
+ printk( "\n*** END OF BASE64 RECORDS ***\n" );
diff --git a/cpukit/libtrace/record/record-dump-zbase64.c b/cpukit/libtrace/record/record-dump-zbase64.c
index 0000000000..937a2528c5
--- /dev/null
+++ b/cpukit/libtrace/record/record-dump-zbase64.c
@@ -0,0 +1,160 @@
+ * are met:
+#if HAVE_CONFIG_H
+#endif
+static void *dump_zalloc( void *opaque, unsigned items, unsigned size )
+ rtems_record_dump_zlib_base64_context *ctx;
+ char *mem_begin;
+ ctx = opaque;
+ size *= items;
+ mem_available = ctx->mem_available;
+ if ( mem_available < size ) {
+ return NULL;
+ mem_begin = ctx->mem_begin;
+ ctx->mem_begin = mem_begin + size;
+ ctx->mem_available = mem_available - size;
+ return mem_begin;
+static void dump_zfree( void *opaque, void *ptr )
+ (void) opaque;
+ (void) ptr;
+ ctx = arg;
+ ++ctx->out;
+ ctx->out = 0;
+ ctx = arg;
+ ctx->stream.next_in = RTEMS_DECONST( void *, data );
+ ctx->stream.avail_in = length;
+ while ( ctx->stream.avail_in > 0 ) {
+ int err;
+ err = deflate( &ctx->stream, Z_NO_FLUSH );
+ if ( err != Z_OK ) {
+ return;
+ if ( ctx->stream.avail_out == 0 ) {
+ ctx->stream.next_out = &ctx->buf[ 0 ];
+ ctx->stream.avail_out = sizeof( ctx->buf );
+ _IO_Base64( put_char, ctx, ctx->buf, sizeof( ctx->buf ), NULL, INT_MAX );
+static void flush( rtems_record_dump_zlib_base64_context *ctx )
+ while ( true ) {
+ int err;
+ err = deflate( &ctx->stream, Z_FINISH );
+ break;
+ _IO_Base64(
+ put_char,
+ ctx,
+ ctx->buf,
+ sizeof( ctx->buf ) - ctx->stream.avail_out,
+ NULL,
+ INT_MAX
+ void *arg
+ int err;
+ ctx->put_char = put_char;
+ ctx->arg = arg;
+ ctx->out = 0;
+ ctx->stream.zalloc = dump_zalloc;
+ ctx->stream.zfree = dump_zfree;
+ ctx->stream.opaque = ctx;
+ ctx->mem_begin = &ctx->mem[ 0 ];
+ ctx->mem_available = sizeof( ctx->mem );
+ err = deflateInit( &ctx->stream, Z_BEST_COMPRESSION );
+ if (err != Z_OK) {
+ return;
+ rtems_record_dump( chunk, ctx );
+ flush( ctx );
+ deflateEnd( &ctx->stream );
diff --git a/cpukit/libtrace/record/record-dump-zfatal.c b/cpukit/libtrace/record/record-dump-zfatal.c
index 0000000000..7decf26b9e
--- /dev/null
+++ b/cpukit/libtrace/record/record-dump-zfatal.c
@@ -0,0 +1,52 @@
+ * are met:
+#if HAVE_CONFIG_H
+#endif
+static rtems_record_dump_zlib_base64_context context;
+ source,
+ code
+ printk( "\n*** BEGIN OF ZLIB BASE64 RECORDS ***\n" );
+ rtems_record_dump_zlib_base64( &context, rtems_put_char, NULL );
+ printk( "\n*** END OF ZLIB BASE64 RECORDS ***\n" );
diff --git a/cpukit/libtrace/record/record-dump.c b/cpukit/libtrace/record/record-dump.c
index 0000000000..b3c757226a
--- /dev/null
+++ b/cpukit/libtrace/record/record-dump.c
@@ -0,0 +1,108 @@
+ * are met:
+#if HAVE_CONFIG_H
+#endif
+#include <rtems/score/threadimpl.h>
+typedef struct {
+ rtems_record_dump_chunk chunk;
+ void *arg;
+} dump_context;
+static void dump_chunk( dump_context *ctx, const void *data, size_t length )
+ ( *ctx->chunk )( ctx->arg, data, length );
+static bool thread_names_visitor( rtems_tcb *tcb, void *arg )
+ char name[ 2 * THREAD_DEFAULT_MAXIMUM_NAME_SIZE ];
+ size_t n;
+ size_t i;
+ rtems_record_item item;
+ rtems_record_data data;
+ ctx = arg;
+ item.event = RTEMS_RECORD_THREAD_ID;
+ item.data = tcb->Object.id;
+ dump_chunk( ctx, &item, sizeof( item ) );
+ n = _Thread_Get_name( tcb, name, sizeof( name ) );
+ i = 0;
+ while ( i < n ) {
+ size_t j;
+ data = 0;
+ for ( j = 0; i < n && j < sizeof( data ); ++j ) {
+ rtems_record_data c;
+ c = (unsigned char) name[ i ];
+ data |= c << ( j * 8 );
+ ++i;
+ item.event = RTEMS_RECORD_THREAD_NAME;
+ item.data = data;
+ return false;
+static void drain_visitor(
+ const rtems_record_item *items,
+ size_t count,
+ void *arg
+ dump_chunk( arg, items, count * sizeof( *items ) );
+ void *arg
+ Record_Stream_header header;
+ size_t size;
+ dump_context ctx;
+ ctx.chunk = chunk;
+ ctx.arg = arg;
+ size = _Record_Stream_header_initialize( &header );
+ dump_chunk( &ctx, &header, size );
+ rtems_task_iterate( thread_names_visitor, &ctx );
+ rtems_record_drain( drain_visitor, &ctx );
diff --git a/testsuites/libtests/Makefile.am b/testsuites/libtests/Makefile.am
index 7917c98656..e493e3d8a8 100644
--- a/testsuites/libtests/Makefile.am
+++ b/testsuites/libtests/Makefile.am
@@ -1124,6 +1124,7 @@ lib_docs += record02/record02.doc
record02_SOURCES = record02/init.c
record02_CPPFLAGS = $(AM_CPPFLAGS) $(TEST_FLAGS_record02) \
$(support_includes)
+record02_LDADD = $(RTEMS_ROOT)cpukit/librtemscpu.a $(RTEMS_ROOT)cpukit/libz.a $(LDADD)
endif
if TEST_rtmonuse
diff --git a/testsuites/libtests/record02/init.c b/testsuites/libtests/record02/init.c
index 22671a7c0a..7f9608ea74 100644
--- a/testsuites/libtests/record02/init.c
+++ b/testsuites/libtests/record02/init.c
@@ -1,7 +1,7 @@
@@ -94,18 +94,11 @@ static void drain_visitor(
rtems_test_assert(cs == RTEMS_RECORD_CLIENT_SUCCESS);
-static void Init(rtems_task_argument arg)
+static void generate_events(void)
- test_context *ctx;
- Record_Stream_header header;
- size_t size;
- rtems_record_client_status cs;
int i;
uint32_t level;
- TEST_BEGIN();
- ctx = &test_instance;
for (i = 0; i < 10; ++i) {
rtems_task_wake_after(1);
@@ -160,6 +153,19 @@ static void Init(rtems_task_argument arg)
rtems_record_exit_10(RTEMS_RECORD_USER_4, 0, 1, 2, 3, 4, 5, 6, 7, 8, 9);
level = rtems_record_interrupt_disable();
rtems_record_interrupt_enable(level);
+static void Init(rtems_task_argument arg)
+ test_context *ctx;
+ size_t size;
+ rtems_record_client_status cs;
+ TEST_BEGIN();
+ ctx = &test_instance;
+ generate_events();
rtems_record_client_init(&ctx->client, client_handler, NULL);
size = _Record_Stream_header_initialize(&header);
@@ -168,6 +174,12 @@ static void Init(rtems_task_argument arg)
rtems_record_drain(drain_visitor, ctx);
rtems_record_client_destroy(&ctx->client);
+ _Record_Fatal_dump_base64(RTEMS_FATAL_SOURCE_APPLICATION, false, 123);
TEST_END();
rtems_test_exit(0);
@@ -182,10 +194,12 @@ static void Init(rtems_task_argument arg)
#define CONFIGURE_RTEMS_INIT_TASKS_TABLE
-#define CONFIGURE_RECORD_PER_PROCESSOR_ITEMS 256
+#define CONFIGURE_RECORD_PER_PROCESSOR_ITEMS 512
#define CONFIGURE_RECORD_EXTENSIONS_ENABLED
+#define CONFIGURE_RECORD_FATAL_DUMP_ZLIB_BASE64
#define CONFIGURE_INIT
#include <rtems/confdefs.h>
2.16.4
