Documentation of the Configuration Options
Fri Mar 13 13:05:18 UTC 2020
Hello,
I finished the work to reorganize the configuration options:
https://docs.rtems.org/branches/master/c-user/config/index.html
My next is now to parse the documentation source files and generate
specification items for the configuration options and groups. This is
similar to the glossary of terms:
https://git.rtems.org/sebh/rtems-qual.git/tree/spec/glos/term
Then I will write a script which reads the specification items and
generates the documentation sources. I would like to use new templates
for the options:
https://devel.rtems.org/ticket/3900
https://devel.rtems.org/ticket/3901
I would like to generate also a Doxygen header for the options. This
depends on:
https://devel.rtems.org/ticket/3899
