Hello world and query about a project availability
Richi Dubey
richidubey at gmail.com
Fri Mar 13 20:04:39 UTC 2020
Dear Dr. Bloom,
Please find my patch given below :-
>From 296fa828fec7c3f99231b377c57ca20411564703 Mon Sep 17 00:00:00 2001
Date: Sat, 14 Mar 2020 01:33:02 +0530
Subject: [PATCH 2/2] Changed the hello world file
testsuites/samples/hello/init.c | 43 +++++++++++----------------------
1 file changed, 14 insertions(+), 29 deletions(-)
diff --git a/testsuites/samples/hello/init.c b/testsuites/samples/hello/init.c
index 34ded37c55..e29306e7c9 100644
--- a/testsuites/samples/hello/init.c
+++ b/testsuites/samples/hello/init.c
@@ -1,44 +1,29 @@
- * COPYRIGHT (c) 1989-2012.
- * On-Line Applications Research Corporation (OAR).
- * The license and distribution terms for this file may be
- * found in the file LICENSE in this distribution or at
- * http://www.rtems.org/license/LICENSE.
-#ifdef HAVE_CONFIG_H
-#include "config.h"
-#endif
-#include <tmacros.h>
+#include <stdlib.h>
+#include <stdio.h>
-const char rtems_test_name[] = "HELLO WORLD";
-static rtems_task Init(
+rtems_task Init(
rtems_task_argument ignored
- rtems_print_printer_fprintf_putc(&rtems_test_printer);
- TEST_BEGIN();
- printf( "Hello World\n" );
- TEST_END();
- rtems_test_exit( 0 );
+ printf( "\n\n*** Hello RTEMS 2020! Let's do something new :) ***\n" );
+ printf( "Hello Everyone\n" );
+ printf( "*** Bubyee ***\n" );
+ exit( 0 );
+/* configuration information */
+#include <bsp.h>
/* NOTICE: the clock driver is explicitly disabled */
#define CONFIGURE_APPLICATION_DOES_NOT_NEED_CLOCK_DRIVER
-#define CONFIGURE_APPLICATION_NEEDS_SIMPLE_CONSOLE_DRIVER
-#define CONFIGURE_MAXIMUM_TASKS 1
+#define CONFIGURE_APPLICATION_NEEDS_CONSOLE_DRIVER
+#define CONFIGURE_USE_DEVFS_AS_BASE_FILESYSTEM
#define CONFIGURE_RTEMS_INIT_TASKS_TABLE
-#define CONFIGURE_INIT_TASK_ATTRIBUTES RTEMS_FLOATING_POINT
-#define CONFIGURE_INITIAL_EXTENSIONS RTEMS_TEST_INITIAL_EXTENSION
+#define CONFIGURE_MAXIMUM_TASKS 1
#include <rtems/confdefs.h>
+/* end of file */
2.17.1
On Fri, Mar 13, 2020 at 12:54 AM Gedare Bloom <gedare at rtems.org> wrote:
> On Thu, Mar 12, 2020 at 1:23 PM Gedare Bloom <gedare at rtems.org> wrote:
> > Hi Richi,
> > Welcome. The "Improve the SMP Scheduler" will require strong C
> > programming skills before the summer. You will be expected to
> > demonstrate that during the proposal period. I'm the only likely
> > mentor for that project this year, and I haven't decided if I will
> > mentor any projects, or which project I might mentor if I do. So it
> > can be a bit risky to pursue that project, but if you are passionate
> > about it and have the required capabilities, then you should start to
> > prepare a proposal and convince me that I should mentor you :).
> > The project itself is a straightforward implementation from the
> > current skeleton of the scheduler. So you will want to also include
> > some "extension" activities in case you complete the scheduler
> > quickly.
> > You should add yourself to https://devel.rtems.org/wiki/GSoC/2020
> PS: thanks for the screenshot, please send your patch as well.
> > Gedare
> > On Thu, Mar 12, 2020 at 1:04 PM Richi Dubey <richidubey at gmail.com> wrote:
> > > Hey everyone,
> > > Could someone please tell me if this project
> > > (https://devel.rtems.org/ticket/2510) titled
> > > "Improve the SMP scheduler with arbitrary processor affinity support"
> > > still open? I went through the mpi-sws paper and I found the concept
> > > of implementing
> > > task's affinity to a processor to increase its efficiency really
> > > interesting. Can someone please help me with this?
> > > Thanks,
> > > Richi.
> > > _______________________________________________
> > > devel mailing list
> > > devel at rtems.org
> > > http://lists.rtems.org/mailman/listinfo/devel
