Hello world and query about a project availability
Gedare Bloom
gedare at rtems.org
Thu Mar 12 19:23:59 UTC 2020
On Thu, Mar 12, 2020 at 1:23 PM Gedare Bloom <gedare at rtems.org> wrote:
> Hi Richi,
> Welcome. The "Improve the SMP Scheduler" will require strong C
> programming skills before the summer. You will be expected to
> demonstrate that during the proposal period. I'm the only likely
> mentor for that project this year, and I haven't decided if I will
> mentor any projects, or which project I might mentor if I do. So it
> can be a bit risky to pursue that project, but if you are passionate
> about it and have the required capabilities, then you should start to
> prepare a proposal and convince me that I should mentor you :).
> The project itself is a straightforward implementation from the
> current skeleton of the scheduler. So you will want to also include
> some "extension" activities in case you complete the scheduler
> quickly.
> You should add yourself to https://devel.rtems.org/wiki/GSoC/2020
PS: thanks for the screenshot, please send your patch as well.
> Gedare
> On Thu, Mar 12, 2020 at 1:04 PM Richi Dubey <richidubey at gmail.com> wrote:
> > Hey everyone,
> > Could someone please tell me if this project
> > (https://devel.rtems.org/ticket/2510) titled
> > "Improve the SMP scheduler with arbitrary processor affinity support"
> > still open? I went through the mpi-sws paper and I found the concept
> > of implementing
> > task's affinity to a processor to increase its efficiency really
> > interesting. Can someone please help me with this?
> > Thanks,
> > Richi.
> > devel mailing list
> > devel at rtems.org
