[PATCH 2/2] Add a message to run 'pytest' to run rest of test suite.
Amar Takhar amar at rtems.org
Fri Mar 13 21:35:11 UTC 2020
Also check for 'pytest' during configure if not installed print a warning
about installing it to run new test suite.
 wscript | 9 +++++++++
 1 file changed, 9 insertions(+)
diff --git a/wscript b/wscript
index bd7c54d..79ab78e 100644
--- a/wscript
+++ b/wscript
@@ -104,6 +104,8 @@ def configure(ctx):
     ctx.find_program('python', mandatory = False)
     ctx.find_program('python2', mandatory = False)
     ctx.find_program('python3', mandatory = False)
+    ctx.find_program('pytest', mandatory = False)
     # Installing the PYO,PYC seems broken on 1.8.19. The path is wrong.
@@ -186,3 +188,10 @@ def rtemstoolkit_tests(ctx):
                     ctx.end_msg('fail', color = 'RED')
     if failures:
         ctx.fatal('Test failures')
+    from waflib.Logs import pprint
+    if not ctx.env.PYTEST:
+        pprint("RED", "'pytest' binary not located during configure please install to run new test suite")
+    else:
+        pprint("RED", "Remember to run 'pytest' to run the new test suite!")
2.25.0
