[PATCH 1/2] Start converting tests to pytest.
Amar Takhar
amar at rtems.org
Mon Mar 16 16:19:37 UTC 2020
On 2020-03-16 09:40 +0100, Sebastian Huber wrote:
> I work currently on a draft for the Python development guidelines for the
> engineering manual. I hope to have something ready for review in the next days.
> Documenting the tests with with pydoc strings in general would be overkill from
> my point of view.
Yes, typically the test names themselves are self-explanatory. If they aren't
then larger tests should be broken into smaller one with descriptive names.
Documentation should be in the source code itself. Documenting it twice is a
longterm nightmare as eventually either-or will deviate from each other while
the documentation doesn't change.
Only in rare cases when a test does something non-obvious should there be any
documentation and even then that's usually not at the function level but above
the code snippet.
Amar.
