[PATCH 1/2] Start converting tests to pytest.
Amar Takhar amar at rtems.org
Fri Mar 13 23:48:48 UTC 2020
On 2020-03-13 17:28 -0600, Gedare Bloom wrote:
> License/file header?
Oh, right I forgot about that, thank you.
> pydoc?
I've never added pydoc to this as it's a generic test class the documentation is
in the test names eg, test_.*().  You can add a string above to add more
verbosity if required but anything for the test class which is just a generic
harness doesn't make sense.
> line length
Yes thank you.
> Add another blank line
Okay.
Amar.
