[PATCH 1/2] Start converting tests to pytest.
Chris Johns
chrisj at rtems.org
Sat Mar 14 00:12:46 UTC 2020
On 14/3/20 10:48 am, Amar Takhar wrote:
> On 2020-03-13 17:28 -0600, Gedare Bloom wrote:
>> pydoc?
> I've never added pydoc to this as it's a generic test class the documentation is
> in the test names eg, test_.*(). You can add a string above to add more
> verbosity if required but anything for the test class which is just a generic
> harness doesn't make sense.
I would like to hear what Sebastian is considering for the ESA work. I think we
should follow what will be done there and ends up in the engineering manual.
