[PATCH] rtems: Add support for building with Clang/LLVM
Hesham Almatary Hesham.Almatary at cl.cam.ac.uk
Sun Mar 15 15:56:36 UTC 2020
 rtems.py | 85 +++++++++++++++++++++++++++++++++++++++++---------------
 1 file changed, 62 insertions(+), 23 deletions(-)
diff --git a/rtems.py b/rtems.py
index ffb386f..f1ef4de 100644
--- a/rtems.py
+++ b/rtems.py
@@ -1,4 +1,5 @@
+# Copyright 2020 Hesham Almatary
 # Copyright 2012-2016 Chris Johns (chrisj at rtems.org)
 # Redistribution and use in source and binary forms, with or without
@@ -63,6 +64,10 @@ def options(opt):
                    default = 'all',
                    dest = 'rtems_bsps',
                    help = 'List of BSPs to build.')
+    opt.add_option('--rtems-compiler',
+                   default = 'gcc',
+                   dest = 'rtems_compiler',
+                   help = 'RTEMS compiler to use available options are clang and gcc (defaults to gcc).')
     opt.add_option('--show-commands',
                    action = 'store_true',
                    default = False,
@@ -104,15 +109,17 @@ def init(ctx, filters = None, version = None, long_commands = False, bsp_init =
         # Check the tools, architectures and bsps.
-        rtems_version, rtems_path, rtems_tools, archs, arch_bsps = \
+        rtems_compiler, rtems_version, rtems_path, rtems_tools, archs, arch_bsps = \
             check_options(ctx,
                           env.options['prefix'],
+                          env.options['rtems_compiler'],
                           env.options['rtems_tools'],
                           env.options['rtems_path'],
                           env.options['rtems_version'],
                           env.options['rtems_archs'],
                           env.options['rtems_bsps'])
+        print("RTEMS Compiler is " + rtems_compiler)
         # Update the contexts for all the bsps.
@@ -176,9 +183,10 @@ def configure(conf, bsp_configure = None):
     else:
         long_commands = 'no'
         check_options(conf,
                       conf.options.prefix,
+                      conf.options.rtems_compiler,
                       conf.options.rtems_tools,
                       conf.options.rtems_path,
                       conf.options.rtems_version,
@@ -222,13 +230,19 @@ def configure(conf, bsp_configure = None):
         conf.env.RTEMS_ARCH_RTEMS = arch
         conf.env.RTEMS_BSP = bsp
-        tools = _find_tools(conf, arch, rtems_tools, tools)
+        tools = _find_tools(conf, arch, rtems_compiler, rtems_tools, tools)
         for t in tools[arch]:
             conf.env[t] = tools[arch][t]
-        conf.load('gcc')
-        conf.load('g++')
-        conf.load('gas')
+        if rtems_compiler == 'gcc':
+            conf.load('gcc')
+            conf.load('g++')
+            conf.load('gas')
+        elif rtems_compiler == 'clang':
+            conf.load('clang')
+            conf.load('clang++')
+        else:
+            conf.fatal('Unknown RTEMS compiler: ' + rtems_compiler)
         # Get the version of the tools being used.
@@ -388,7 +402,7 @@ def tweaks(conf, arch_bsp):
     if '-ffunction-sections' in conf.env.CFLAGS:
       conf.env.LINKFLAGS += ['-Wl,--gc-sections']
-def check_options(ctx, prefix, rtems_tools, rtems_path, rtems_version, rtems_archs, rtems_bsps):
+def check_options(ctx, prefix, rtems_compiler, rtems_tools, rtems_path, rtems_version, rtems_archs, rtems_bsps):
     # Set defaults
@@ -406,6 +420,12 @@ def check_options(ctx, prefix, rtems_tools, rtems_path, rtems_version, rtems_arc
     if rtems_tools is None:
         rtems_tools = rtems_path
+    # Check the compiler option is valid.
+    if rtems_compiler not in ['gcc', 'clang']:
+        ctx.fatal('Valid RTEMS compilers are gcc or clang')
     # Check the paths are valid.
@@ -476,7 +496,7 @@ def check_options(ctx, prefix, rtems_tools, rtems_path, rtems_version, rtems_arc
     arch_bsps = filter(ctx, 'bsps', arch_bsps)
-    return rtems_version, rtems_path, tools, archs, arch_bsps
+    return rtems_compiler, rtems_version, rtems_path, tools, archs, arch_bsps
 def check_env(ctx, var):
     if var in ctx.env and len(ctx.env[var]) != 0:
@@ -682,22 +702,40 @@ def long_command_line():
             if hasattr(cls, 'hcode'):
                 derived_class.hcode = cls.hcode
-def _find_tools(conf, arch, paths, tools):
+def _find_tools(conf, arch, rtems_compiler, paths, tools):
     if arch not in tools:
         arch_tools = {}
-        arch_tools['CC']          = conf.find_program([arch + '-gcc'], path_list = paths)
-        arch_tools['CXX']         = conf.find_program([arch + '-g++'], path_list = paths)
-        arch_tools['LINK_CC']     = arch_tools['CC']
-        arch_tools['LINK_CXX']    = arch_tools['CXX']
-        arch_tools['AS']          = conf.find_program([arch + '-gcc'], path_list = paths)
-        arch_tools['LD']          = conf.find_program([arch + '-ld'],  path_list = paths)
-        arch_tools['AR']          = conf.find_program([arch + '-ar'], path_list = paths)
-        arch_tools['NM']          = conf.find_program([arch + '-nm'], path_list = paths)
-        arch_tools['OBJDUMP']     = conf.find_program([arch + '-objdump'], path_list = paths)
-        arch_tools['OBJCOPY']     = conf.find_program([arch + '-objcopy'], path_list = paths)
-        arch_tools['READELF']     = conf.find_program([arch + '-readelf'], path_list = paths)
-        arch_tools['STRIP']       = conf.find_program([arch + '-strip'], path_list = paths)
-        arch_tools['RANLIB']      = conf.find_program([arch + '-ranlib'], path_list = paths)
+            arch_tools['CC']          = conf.find_program([arch + '-gcc'], path_list = paths)
+            arch_tools['CXX']         = conf.find_program([arch + '-g++'], path_list = paths)
+            arch_tools['LINK_CC']     = arch_tools['CC']
+            arch_tools['LINK_CXX']    = arch_tools['CXX']
+            arch_tools['AS']          = conf.find_program([arch + '-gcc'], path_list = paths)
+            arch_tools['LD']          = conf.find_program([arch + '-ld'],  path_list = paths)
+            arch_tools['AR']          = conf.find_program([arch + '-ar'], path_list = paths)
+            arch_tools['NM']          = conf.find_program([arch + '-nm'], path_list = paths)
+            arch_tools['OBJDUMP']     = conf.find_program([arch + '-objdump'], path_list = paths)
+            arch_tools['OBJCOPY']     = conf.find_program([arch + '-objcopy'], path_list = paths)
+            arch_tools['READELF']     = conf.find_program([arch + '-readelf'], path_list = paths)
+            arch_tools['STRIP']       = conf.find_program([arch + '-strip'], path_list = paths)
+            arch_tools['RANLIB']      = conf.find_program([arch + '-ranlib'], path_list = paths)
+            arch_tools['CC']          = conf.find_program('clang')
+            arch_tools['CXX']         = conf.find_program('clang++')
+            arch_tools['AS']          = conf.find_program('clang')
+            arch_tools['LD']          = conf.find_program('lld')
+            arch_tools['AR']          = conf.find_program('llvm-ar')
+            arch_tools['NM']          = conf.find_program('llvm-nm')
+            arch_tools['OBJDUMP']     = conf.find_program('llvm-objdump')
+            arch_tools['OBJCOPY']     = conf.find_program('llvm-objcopy')
+            arch_tools['READELF']     = conf.find_program('llvm-readelf')
+            arch_tools['STRIP']       = conf.find_program('llvm-strip')
+            arch_tools['RANLIB']      = conf.find_program('llvm-ranlib')
+        else:
+            conf.fatal('Unknown RTEMS Compiler')
         arch_tools['RTEMS_LD']    = conf.find_program(['rtems-ld'], path_list = paths,
                                                       mandatory = False)
         arch_tools['RTEMS_TLD']   = conf.find_program(['rtems-tld'], path_list = paths,
@@ -837,7 +875,8 @@ def _filter_flags(label, flags, arch, rtems_path):
           { 'key': 'includes', 'path': True,  'flags': { '-I': 1, '-isystem': 2, '-sysroot': 2 } },
           { 'key': 'libpath',  'path': True,  'flags': { '-L': 1 } },
           { 'key': 'machines', 'path': True,  'flags': { '-O': 1, '-m': 1, '-f': 1, '-G':1, '-E':1 } },
-          { 'key': 'specs',    'path': True,  'flags': { '-q': 1, '-B': 2, '--specs': 2 } } ]
+          { 'key': 'specs',    'path': True,  'flags': { '-q': 1, '-B': 2, '--specs': 2 } },
+          { 'key': 'target',    'path': True,  'flags': { '--target': 1 } } ]
     flags = _strip_cflags(flags)
2.17.1
