[PATCH] rtems: Add support for building with Clang/LLVM
Sun Mar 15 21:09:06 UTC 2020
Hi Hesham,
This is a great addition to rtems_waf, some comments below.
On 16/3/20 2:56 am, Hesham Almatary wrote:
>  rtems.py | 85 +++++++++++++++++++++++++++++++++++++++++---------------
>  1 file changed, 62 insertions(+), 23 deletions(-)
> diff --git a/rtems.py b/rtems.py
> index ffb386f..f1ef4de 100644
> --- a/rtems.py
> +++ b/rtems.py
> @@ -1,4 +1,5 @@
> +# Copyright 2020 Hesham Almatary
>  # Copyright 2012-2016 Chris Johns (chrisj at rtems.org)
>  # Redistribution and use in source and binary forms, with or without
> @@ -63,6 +64,10 @@ def options(opt):
>                     default = 'all',
>                     dest = 'rtems_bsps',
>                     help = 'List of BSPs to build.')
> +    opt.add_option('--rtems-compiler',
> +                   default = 'gcc',
> +                   dest = 'rtems_compiler',
> +                   help = 'RTEMS compiler to use available options are clang and gcc (defaults to gcc).')
>      opt.add_option('--show-commands',
>                     action = 'store_true',
>                     default = False,
> @@ -104,15 +109,17 @@ def init(ctx, filters = None, version = None, long_commands = False, bsp_init =
>          # Check the tools, architectures and bsps.
> -        rtems_version, rtems_path, rtems_tools, archs, arch_bsps = \
> +        rtems_compiler, rtems_version, rtems_path, rtems_tools, archs, arch_bsps = \
>              check_options(ctx,
>                            env.options['prefix'],
> +                          env.options['rtems_compiler'],
>                            env.options['rtems_tools'],
>                            env.options['rtems_path'],
>                            env.options['rtems_version'],
>                            env.options['rtems_archs'],
>                            env.options['rtems_bsps'])
> +        print("RTEMS Compiler is " + rtems_compiler)
Please use `conf.msg()`. See https://git.rtems.org/rtems_waf/tree/rtems.py#n248
>          # Update the contexts for all the bsps.
> @@ -176,9 +183,10 @@ def configure(conf, bsp_configure = None):
>      else:
>          long_commands = 'no'
>          check_options(conf,
>                        conf.options.prefix,
> +                      conf.options.rtems_compiler,
>                        conf.options.rtems_tools,
>                        conf.options.rtems_path,
>                        conf.options.rtems_version,
> @@ -222,13 +230,19 @@ def configure(conf, bsp_configure = None):
>          conf.env.RTEMS_ARCH_RTEMS = arch
>          conf.env.RTEMS_BSP = bsp
> -        tools = _find_tools(conf, arch, rtems_tools, tools)
> +        tools = _find_tools(conf, arch, rtems_compiler, rtems_tools, tools)
>          for t in tools[arch]:
>              conf.env[t] = tools[arch][t]
> -        conf.load('gcc')
> -        conf.load('g++')
> -        conf.load('gas')
> +        if rtems_compiler == 'gcc':
> +            conf.load('gcc')
> +            conf.load('g++')
> +            conf.load('gas')
> +        elif rtems_compiler == 'clang':
> +            conf.load('clang')
> +            conf.load('clang++')
> +        else:
> +            conf.fatal('Unknown RTEMS compiler: ' + rtems_compiler)
>          # Get the version of the tools being used.
> @@ -388,7 +402,7 @@ def tweaks(conf, arch_bsp):
>      if '-ffunction-sections' in conf.env.CFLAGS:
>        conf.env.LINKFLAGS += ['-Wl,--gc-sections']
> -def check_options(ctx, prefix, rtems_tools, rtems_path, rtems_version, rtems_archs, rtems_bsps):
> +def check_options(ctx, prefix, rtems_compiler, rtems_tools, rtems_path, rtems_version, rtems_archs, rtems_bsps):
>      # Set defaults
> @@ -406,6 +420,12 @@ def check_options(ctx, prefix, rtems_tools, rtems_path, rtems_version, rtems_arc
>      if rtems_tools is None:
>          rtems_tools = rtems_path
> +    # Check the compiler option is valid.
> +    if rtems_compiler not in ['gcc', 'clang']:
Key in compiler dict? See below.
> +        ctx.fatal('Valid RTEMS compilers are gcc or clang')
>      # Check the paths are valid.
> @@ -476,7 +496,7 @@ def check_options(ctx, prefix, rtems_tools, rtems_path, rtems_version, rtems_arc
>      arch_bsps = filter(ctx, 'bsps', arch_bsps)
> -    return rtems_version, rtems_path, tools, archs, arch_bsps
> +    return rtems_compiler, rtems_version, rtems_path, tools, archs, arch_bsps
>  def check_env(ctx, var):
>      if var in ctx.env and len(ctx.env[var]) != 0:
> @@ -682,22 +702,40 @@ def long_command_line():
>              if hasattr(cls, 'hcode'):
>                  derived_class.hcode = cls.hcode
> -def _find_tools(conf, arch, paths, tools):
> +def _find_tools(conf, arch, rtems_compiler, paths, tools):
>      if arch not in tools:
>          arch_tools = {}
> -        arch_tools['CC']          = conf.find_program([arch + '-gcc'], path_list = paths)
> -        arch_tools['CXX']         = conf.find_program([arch + '-g++'], path_list = paths)
> -        arch_tools['LINK_CC']     = arch_tools['CC']
> -        arch_tools['LINK_CXX']    = arch_tools['CXX']
> -        arch_tools['AS']          = conf.find_program([arch + '-gcc'], path_list = paths)
> -        arch_tools['LD']          = conf.find_program([arch + '-ld'],  path_list = paths)
> -        arch_tools['AR']          = conf.find_program([arch + '-ar'], path_list = paths)
> -        arch_tools['NM']          = conf.find_program([arch + '-nm'], path_list = paths)
> -        arch_tools['OBJDUMP']     = conf.find_program([arch + '-objdump'], path_list = paths)
> -        arch_tools['OBJCOPY']     = conf.find_program([arch + '-objcopy'], path_list = paths)
> -        arch_tools['READELF']     = conf.find_program([arch + '-readelf'], path_list = paths)
> -        arch_tools['STRIP']       = conf.find_program([arch + '-strip'], path_list = paths)
> -        arch_tools['RANLIB']      = conf.find_program([arch + '-ranlib'], path_list = paths)
> +            arch_tools['CC']          = conf.find_program([arch + '-gcc'], path_list = paths)
> +            arch_tools['CXX']         = conf.find_program([arch + '-g++'], path_list = paths)
> +            arch_tools['LINK_CC']     = arch_tools['CC']
> +            arch_tools['LINK_CXX']    = arch_tools['CXX']
> +            arch_tools['AS']          = conf.find_program([arch + '-gcc'], path_list = paths)
> +            arch_tools['LD']          = conf.find_program([arch + '-ld'],  path_list = paths)
> +            arch_tools['AR']          = conf.find_program([arch + '-ar'], path_list = paths)
> +            arch_tools['NM']          = conf.find_program([arch + '-nm'], path_list = paths)
> +            arch_tools['OBJDUMP']     = conf.find_program([arch + '-objdump'], path_list = paths)
> +            arch_tools['OBJCOPY']     = conf.find_program([arch + '-objcopy'], path_list = paths)
> +            arch_tools['READELF']     = conf.find_program([arch + '-readelf'], path_list = paths)
> +            arch_tools['STRIP']       = conf.find_program([arch + '-strip'], path_list = paths)
> +            arch_tools['RANLIB']      = conf.find_program([arch + '-ranlib'], path_list = paths)
> +            arch_tools['CC']          = conf.find_program('clang')
> +            arch_tools['CXX']         = conf.find_program('clang++')
> +            arch_tools['AS']          = conf.find_program('clang')
> +            arch_tools['LD']          = conf.find_program('lld')
> +            arch_tools['AR']          = conf.find_program('llvm-ar')
> +            arch_tools['NM']          = conf.find_program('llvm-nm')
> +            arch_tools['OBJDUMP']     = conf.find_program('llvm-objdump')
> +            arch_tools['OBJCOPY']     = conf.find_program('llvm-objcopy')
> +            arch_tools['READELF']     = conf.find_program('llvm-readelf')
> +            arch_tools['STRIP']       = conf.find_program('llvm-strip')
> +            arch_tools['RANLIB']      = conf.find_program('llvm-ranlib')
Could this be defined in a compile dict?
Why does llvm not require a path_list?
> +        else:
> +            conf.fatal('Unknown RTEMS Compiler')
>          arch_tools['RTEMS_LD']    = conf.find_program(['rtems-ld'], path_list = paths,
>                                                        mandatory = False)
>          arch_tools['RTEMS_TLD']   = conf.find_program(['rtems-tld'], path_list = paths,
> @@ -837,7 +875,8 @@ def _filter_flags(label, flags, arch, rtems_path):
>            { 'key': 'includes', 'path': True,  'flags': { '-I': 1, '-isystem': 2, '-sysroot': 2 } },
>            { 'key': 'libpath',  'path': True,  'flags': { '-L': 1 } },
>            { 'key': 'machines', 'path': True,  'flags': { '-O': 1, '-m': 1, '-f': 1, '-G':1, '-E':1 } },
> -          { 'key': 'specs',    'path': True,  'flags': { '-q': 1, '-B': 2, '--specs': 2 } } ]
> +          { 'key': 'specs',    'path': True,  'flags': { '-q': 1, '-B': 2, '--specs': 2 } },
> +          { 'key': 'target',    'path': True,  'flags': { '--target': 1 } } ]
>      flags = _strip_cflags(flags)
