[PATCH 1/2] Convert host checking to pytest.
Sun Mar 15 22:30:30 UTC 2020
Hi,
This looks good. Thank you for making the switch to pytest.
Are you planning on moving all the exist "chris hacked" tests to pytest?
If so I am wondering how you will stage the change? This size patch is perfect
but I am concerned we may have some done and others not when the release branch
is made if we push them in pieces?
Minor comment below ...
On 14/3/20 10:28 am, Amar Takhar wrote:
>  rtemstoolkit/darwin.py          |  5 -----
>  rtemstoolkit/freebsd.py         |  5 -----
>  rtemstoolkit/host.py            | 14 --------------
>  rtemstoolkit/linux.py           |  5 -----
>  rtemstoolkit/netbsd.py          |  5 -----
>  rtemstoolkit/solaris.py         |  5 -----
>  rtemstoolkit/tests/test_host.py | 32 ++++++++++++++++++++++++++++++++
>  rtemstoolkit/windows.py         |  5 -----
>  8 files changed, 32 insertions(+), 44 deletions(-)
>  create mode 100644 rtemstoolkit/tests/test_host.py
> diff --git a/rtemstoolkit/darwin.py b/rtemstoolkit/darwin.py
> index e780d1d..b9e17cf 100644
> --- a/rtemstoolkit/darwin.py
> +++ b/rtemstoolkit/darwin.py
> @@ -76,8 +76,3 @@ def overrides():
>      defines['_build_arch']   = defines['_host_arch']
>      return defines
> -if __name__ == '__main__':
> -    import pprint
> -    pprint.pprint(cpus())
> -    pprint.pprint(overrides())
> diff --git a/rtemstoolkit/freebsd.py b/rtemstoolkit/freebsd.py
> index ed16140..6e40c34 100644
> --- a/rtemstoolkit/freebsd.py
> +++ b/rtemstoolkit/freebsd.py
> @@ -97,8 +97,3 @@ def overrides():
>              break
>      return defines
> -    import pprint
> diff --git a/rtemstoolkit/host.py b/rtemstoolkit/host.py
> index 01aae07..67b006a 100644
> --- a/rtemstoolkit/host.py
> +++ b/rtemstoolkit/host.py
> @@ -103,17 +103,3 @@ def label(mode = 'all'):
>      if mode == 'all':
>          return '%s (%s)' % (compact, extended)
>      raise error.general('invalid platform mode: %s' % (mode))
> -    import pprint
> -    print('Python\'s OS name: %s' % (os.name))
> -    load()
> -    print('Name      : %s' % (name))
> -    if is_windows:
> -        status = 'Yes'
> -    else:
> -        status = 'No'
> -    print('Windows   : %s' % (status))
> -    print('CPUs      : %d' % (cpus()))
> -    print('Overrides :')
> diff --git a/rtemstoolkit/linux.py b/rtemstoolkit/linux.py
> index 21f6f97..15b8528 100644
> --- a/rtemstoolkit/linux.py
> +++ b/rtemstoolkit/linux.py
> @@ -134,8 +134,3 @@ def overrides():
>      return defines
> -    import pprint
> diff --git a/rtemstoolkit/netbsd.py b/rtemstoolkit/netbsd.py
> index 1d9a11f..eab9353 100644
> --- a/rtemstoolkit/netbsd.py
> +++ b/rtemstoolkit/netbsd.py
> @@ -90,8 +90,3 @@ def overrides():
>              break
>      return defines
> -    import pprint
> diff --git a/rtemstoolkit/solaris.py b/rtemstoolkit/solaris.py
> index 79ddd75..1b265da 100644
> --- a/rtemstoolkit/solaris.py
> +++ b/rtemstoolkit/solaris.py
> @@ -83,8 +83,3 @@ def overrides():
>      return defines
> -    import pprint
> diff --git a/rtemstoolkit/tests/test_host.py b/rtemstoolkit/tests/test_host.py
> new file mode 100644
> index 0000000..4b1bf00
> --- /dev/null
> +++ b/rtemstoolkit/tests/test_host.py
> @@ -0,0 +1,32 @@
> +import pytest
> +from rtemstoolkit import host
> +import re
> +def test_cpu():
> +	assert type(host.cpus()) is int
This is using tabs, please use spaces.
> +def test_overrides():
> +	assert type(host.overrides()) is dict
> +def test_label_system():
> +	assert host.label(mode="system") is not None
> +def test_label_compact():
> +	assert re.match("^[a-zA-Z]*-.*-.*$", host.label(mode="compact"))
> +def test_label_extended():
> +	assert re.match("^[a-zA-Z]* .*$", host.label(mode="extended"))
> +def test_label_all():
> +	assert re.match("^[a-zA-Z]*-.*-.* \\(.*\\)$", host.label(mode="all"))
> +def test_label_error():
> +	from rtemstoolkit.error import general
> +	with pytest.raises(general, match=r"^error: invalid platform mode: _nonexistent_$"):
> +		assert host.label(mode="_nonexistent_")
> diff --git a/rtemstoolkit/windows.py b/rtemstoolkit/windows.py
> index 802263b..585cddf 100644
> --- a/rtemstoolkit/windows.py
> +++ b/rtemstoolkit/windows.py
> @@ -132,8 +132,3 @@ def overrides():
>          '___setup_shell': ('exe',     'required', '%{__sh}')
>      return defines
> -    import pprint
