[PATCH 1/2] Convert host checking to pytest.
Amar Takhar
amar at rtems.org
Mon Mar 16 00:02:55 UTC 2020
On 2020-03-16 09:30 +1100, Chris Johns wrote:
> Hi,
> This looks good. Thank you for making the switch to pytest.
> Are you planning on moving all the exist "chris hacked" tests to pytest?
I don't know probably not I don't have the time this was to get someone started.
> If so I am wondering how you will stage the change? This size patch is perfect
> but I am concerned we may have some done and others not when the release branch
> is made if we push them in pieces?
I don't see that as a problem personally this is why I added the message.
The pytests are more comprehensive even if they don't all get converted going
forward we should be using pytest and anyone wishing to contribute can convert
them.
I've done 4 examples that should cover all our use cases for the rest of the
code. Converting the rest is pretty easy and I'm available to help anyone who
has difficulty.
Amar.
