[PATCH 1/2] Convert host checking to pytest.
Chris Johns
chrisj at rtems.org
Mon Mar 16 00:48:07 UTC 2020
On 16/3/20 11:02 am, Amar Takhar wrote:
> On 2020-03-16 09:30 +1100, Chris Johns wrote:
>> Hi,
>> This looks good. Thank you for making the switch to pytest.
>> Are you planning on moving all the exist "chris hacked" tests to pytest?
> I don't know probably not I don't have the time this was to get someone started.
That is understandable. Are the patches available in your personal repo?
>> If so I am wondering how you will stage the change? This size patch is perfect
>> but I am concerned we may have some done and others not when the release branch
>> is made if we push them in pieces?
> I don't see that as a problem personally this is why I added the message.
I am fine with pieces being pushed after RTEMS 5 has branched. My concern is
only related to the pending release. It is only a couple of weeks away if that.
> The pytests are more comprehensive even if they don't all get converted going
> forward we should be using pytest and anyone wishing to contribute can convert
> them.
I agree and starting this happening is a great contribution. Thank you.
> I've done 4 examples that should cover all our use cases for the rest of the
> code. Converting the rest is pretty easy and I'm available to help anyone who
> has difficulty.
Yes and again thank you.
