[PATCH v2] Start conversion tests to using pytest.
Amar Takhar
amar at rtems.org
Mon Mar 16 04:21:29 UTC 2020
error.py:
- Check for exceptions and error messages.
path.py:
- Test params and setting module variables.
macros.py:
- Test class with setup and shared module access.
host.py:
- Check host specific settings using simple regex for formatting.
- String check on exception.
rtemstoolkit/conftest.py | 37 +++++++++++++++
rtemstoolkit/darwin.py | 5 --
rtemstoolkit/error.py | 10 ----
rtemstoolkit/freebsd.py | 5 --
rtemstoolkit/host.py | 14 ------
rtemstoolkit/linux.py | 5 --
rtemstoolkit/macros.py | 24 ----------
rtemstoolkit/netbsd.py | 5 --
rtemstoolkit/path.py | 17 -------
rtemstoolkit/solaris.py | 5 --
rtemstoolkit/tests/__init__.py | 0
rtemstoolkit/tests/test_error.py | 39 +++++++++++++++
rtemstoolkit/tests/test_host.py | 64 +++++++++++++++++++++++++
rtemstoolkit/tests/test_macros.py | 66 ++++++++++++++++++++++++++
rtemstoolkit/tests/test_path.py | 79 +++++++++++++++++++++++++++++++
rtemstoolkit/windows.py | 5 --
16 files changed, 285 insertions(+), 95 deletions(-)
create mode 100644 rtemstoolkit/conftest.py
create mode 100644 rtemstoolkit/tests/__init__.py
create mode 100644 rtemstoolkit/tests/test_error.py
create mode 100644 rtemstoolkit/tests/test_host.py
create mode 100644 rtemstoolkit/tests/test_macros.py
create mode 100644 rtemstoolkit/tests/test_path.py
diff --git a/rtemstoolkit/conftest.py b/rtemstoolkit/conftest.py
new file mode 100644
index 0000000..3e1ec80
--- /dev/null
+++ b/rtemstoolkit/conftest.py
@@ -0,0 +1,37 @@
+# SPDX-License-Identifier: BSD-2-Clause
+# RTEMS Tools Project (http://www.rtems.org/)
+# Copyright (C) 2020 Amar Takhar <amar at rtems.org>
+# Redistribution and use in source and binary forms, with or without
+# modification, are permitted provided that the following conditions
+# are met:
+# 1. Redistributions of source code must retain the above copyright
+# notice, this list of conditions and the following disclaimer.
+# 2. Redistributions in binary form must reproduce the above copyright
+# notice, this list of conditions and the following disclaimer in the
+# documentation and/or other materials provided with the distribution.
+# THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
+# AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
+# IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
+# ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE
+# LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
+# CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
+# SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
+# INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
+# CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
+# ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
+# POSSIBILITY OF SUCH DAMAGE.
+import pytest
+from sys import path
+import os
+# Always find the parent directory of rtemstoolkit/ no matter where
+# pytest is run.
+def pytest_runtest_setup(item):
+ path_toolkit = os.path.dirname(os.path.abspath(__file__))
+ path.append(os.path.dirname(path_toolkit))
diff --git a/rtemstoolkit/darwin.py b/rtemstoolkit/darwin.py
index e780d1d..b9e17cf 100644
--- a/rtemstoolkit/darwin.py
+++ b/rtemstoolkit/darwin.py
@@ -76,8 +76,3 @@ def overrides():
defines['_build_arch'] = defines['_host_arch']
return defines
-if __name__ == '__main__':
- import pprint
- pprint.pprint(cpus())
- pprint.pprint(overrides())
diff --git a/rtemstoolkit/error.py b/rtemstoolkit/error.py
index e3a43c1..697b0a6 100644
--- a/rtemstoolkit/error.py
+++ b/rtemstoolkit/error.py
@@ -55,13 +55,3 @@ class exit(error):
"""Raise for to exit."""
def __init__(self):
pass
- try:
- raise general('a general error')
- except general as gerr:
- print('caught:', gerr)
- try:
- raise internal('an internal error')
- except internal as ierr:
- print('caught:', ierr)
diff --git a/rtemstoolkit/freebsd.py b/rtemstoolkit/freebsd.py
index ed16140..6e40c34 100644
--- a/rtemstoolkit/freebsd.py
+++ b/rtemstoolkit/freebsd.py
@@ -97,8 +97,3 @@ def overrides():
break
return defines
- import pprint
diff --git a/rtemstoolkit/host.py b/rtemstoolkit/host.py
index 01aae07..67b006a 100644
--- a/rtemstoolkit/host.py
+++ b/rtemstoolkit/host.py
@@ -103,17 +103,3 @@ def label(mode = 'all'):
if mode == 'all':
return '%s (%s)' % (compact, extended)
raise error.general('invalid platform mode: %s' % (mode))
- import pprint
- print('Python\'s OS name: %s' % (os.name))
- load()
- print('Name : %s' % (name))
- if is_windows:
- status = 'Yes'
- else:
- status = 'No'
- print('Windows : %s' % (status))
- print('CPUs : %d' % (cpus()))
- print('Overrides :')
diff --git a/rtemstoolkit/linux.py b/rtemstoolkit/linux.py
index 21f6f97..15b8528 100644
--- a/rtemstoolkit/linux.py
+++ b/rtemstoolkit/linux.py
@@ -134,8 +134,3 @@ def overrides():
return defines
- import pprint
diff --git a/rtemstoolkit/macros.py b/rtemstoolkit/macros.py
index d8012e1..708107f 100644
--- a/rtemstoolkit/macros.py
+++ b/rtemstoolkit/macros.py
@@ -534,27 +534,3 @@ class macros:
def unlock_read_map(self):
self.read_map_locked = False
-if __name__ == "__main__":
- import copy
- import sys
- print(inspect.getfile(macros))
- m = macros()
- d = copy.copy(m)
- m['test1'] = 'something'
- if d.has_key('test1'):
- print('error: copy failed.')
- sys.exit(1)
- m.parse("[test]\n" \
- "test1: none, undefine, ''\n" \
- "name: none, override, 'pink'\n")
- print('set test:', m.set_read_map('test'))
- if m['name'] != 'pink':
- print('error: override failed. name is %s' % (m['name']))
- sys.exit(1)
- if m.has_key('test1'):
- print('error: map undefine failed.')
- sys.exit(1)
- print('unset test:', m.unset_read_map('test'))
- print(m)
- print(m.keys())
diff --git a/rtemstoolkit/netbsd.py b/rtemstoolkit/netbsd.py
index 1d9a11f..eab9353 100644
--- a/rtemstoolkit/netbsd.py
+++ b/rtemstoolkit/netbsd.py
@@ -90,8 +90,3 @@ def overrides():
break
return defines
- import pprint
diff --git a/rtemstoolkit/path.py b/rtemstoolkit/path.py
index b15164b..7b5f64b 100644
--- a/rtemstoolkit/path.py
+++ b/rtemstoolkit/path.py
@@ -430,20 +430,3 @@ def get_humanize_size(path, depth = -1):
return "%5.3f%sB" % (size, unit)
size /= 1024.0
return "%.3f%sB" % (size, 'Y')
- print(host('/a/b/c/d-e-f'))
- print(host('//a/b//c/d-e-f'))
- print(shell('/w/x/y/z'))
- print(basename('/as/sd/df/fg/me.txt'))
- print(dirname('/as/sd/df/fg/me.txt'))
- print(join('/d', 'g', '/tyty/fgfg'))
- windows = True
- print(shell('w:/x/y/z'))
- print(basename('x:/sd/df/fg/me.txt'))
- print(dirname('x:/sd/df/fg/me.txt'))
- print(join('s:/d/', '/g', '/tyty/fgfg'))
- print(join('s:/d/e\\f/g', '/h', '/tyty/zxzx', '\\mm\\nn/p'))
diff --git a/rtemstoolkit/solaris.py b/rtemstoolkit/solaris.py
index 79ddd75..1b265da 100644
--- a/rtemstoolkit/solaris.py
+++ b/rtemstoolkit/solaris.py
@@ -83,8 +83,3 @@ def overrides():
return defines
- import pprint
diff --git a/rtemstoolkit/tests/__init__.py b/rtemstoolkit/tests/__init__.py
index 0000000..e69de29
diff --git a/rtemstoolkit/tests/test_error.py b/rtemstoolkit/tests/test_error.py
index 0000000..0702ced
--- /dev/null
+++ b/rtemstoolkit/tests/test_error.py
@@ -0,0 +1,39 @@
+# are met:
+import pytest
+from rtemstoolkit.error import general, internal
+def test_general():
+ with pytest.raises(general, match=r"^error: test_general$"):
+ raise general("test_general")
+def test_internal():
+ with pytest.raises(internal, match=r"^internal error: test_internal$"):
+ raise internal("test_internal")
diff --git a/rtemstoolkit/tests/test_host.py b/rtemstoolkit/tests/test_host.py
index 0000000..fb15a24
--- /dev/null
+++ b/rtemstoolkit/tests/test_host.py
@@ -0,0 +1,64 @@
+# are met:
+import pytest
+import re
+from rtemstoolkit import host
+def test_cpu():
+ assert type(host.cpus()) is int
+def test_overrides():
+ assert type(host.overrides()) is dict
+def test_label_system():
+ assert host.label(mode="system") is not None
+def test_label_compact():
+ assert re.match("^[a-zA-Z]*-.*-.*$", host.label(mode="compact"))
+def test_label_extended():
+ assert re.match("^[a-zA-Z]* .*$", host.label(mode="extended"))
+def test_label_all():
+ assert re.match("^[a-zA-Z]*-.*-.* \\(.*\\)$", host.label(mode="all"))
+def test_label_error():
+ from rtemstoolkit.error import general
+ with pytest.raises(general, match=r"^error: invalid platform mode: _nonexistent_$"):
+ assert host.label(mode="_nonexistent_")
diff --git a/rtemstoolkit/tests/test_macros.py b/rtemstoolkit/tests/test_macros.py
index 0000000..45d4abd
--- /dev/null
+++ b/rtemstoolkit/tests/test_macros.py
@@ -0,0 +1,66 @@
+# are met:
+import pytest
+from rtemstoolkit.macros import macros
+class TestClass:
+ @classmethod
+ def setup_class(cls):
+ import copy
+ import sys
+ cls.m = macros()
+ cls.d = copy.copy(cls.m)
+ def test_copy_failure(self):
+ self.m['test1'] = 'something'
+ assert "test1" not in self.d
+ def test_set_tests(self):
+ assert self.m.parse("[test]\n" \
+ "test1: none, undefine, ''\n" \
+ "name: none, override, 'pink'\n") is None
+ assert self.m.set_read_map("test")
+ def test_check_override(self):
+ if self.m["name"] != "pink":
+ raise Exception("error: override failed. name is %s" % self.m["name"])
+ def test_undefine(self):
+ assert "test1" not in self.m
+ def test_unset(self):
+ assert "name" in self.m
+ assert self.m.unset_read_map("test")
+ assert "name" not in self.m
diff --git a/rtemstoolkit/tests/test_path.py b/rtemstoolkit/tests/test_path.py
index 0000000..ee0ae24
--- /dev/null
+++ b/rtemstoolkit/tests/test_path.py
@@ -0,0 +1,79 @@
+# are met:
+import pytest
+from rtemstoolkit import path
+rtems_windows = pytest.mark.parametrize("windows", [False, True], \
+ ids=["Windows=False", "Windows=True"])
+ at rtems_windows
+def test_host(windows):
+ path.windows = windows
+ if windows:
+ path_str = "a:\\b\\c\\d-e-f"
+ else:
+ path_str = "/a/b/c/d-e-f"
+ assert path.host('//a/b/c/d-e-f') == path_str
+ at rtems_windows
+def test_shell(windows):
+ assert path.shell('/w/x/y/z') == "/w/x/y/z"
+ at rtems_windows
+def test_basename(windows):
+ assert path.basename('/as/sd/df/fg/me.txt') == "me.txt"
+ if windows:
+ assert path.basename('x:/sd/df/fg/me.txt') == "me.txt"
+ at rtems_windows
+def test_dirname(windows):
+ assert path.dirname('/as/sd/df/fg/me.txt') == "/as/sd/df/fg"
+ if windows:
+ assert path.dirname('x:/sd/df/fg/me.txt') == "/x/sd/df/fg"
+ at rtems_windows
+def test_join(windows):
+ assert path.join('/d', 'g', '/tyty/fgfg') == "/d/g/tyty/fgfg"
+ if windows:
+ assert path.join('s:/d/e\\f/g', '/h', '/tyty/zxzx', '\\mm\\nn/p') == "/s/d/e/f/g/h/tyty/zxzx/mm/nn/p"
+ assert path.join('s:/d/', '/g', '/tyty/fgfg') == "/s/d/g/tyty/fgfg"
diff --git a/rtemstoolkit/windows.py b/rtemstoolkit/windows.py
index 802263b..585cddf 100644
--- a/rtemstoolkit/windows.py
+++ b/rtemstoolkit/windows.py
@@ -132,8 +132,3 @@ def overrides():
'___setup_shell': ('exe', 'required', '%{__sh}')
return defines
- import pprint
2.25.0
