[PATCH v2] Start conversion tests to using pytest.
Mon Mar 16 06:01:10 UTC 2020
Thanks
On Sun, Mar 15, 2020 at 10:21 PM Amar Takhar <amar at rtems.org> wrote:
> error.py:
>     - Check for exceptions and error messages.
> path.py:
>     - Test params and setting module variables.
> macros.py:
>     - Test class with setup and shared module access.
> host.py:
>     - Check host specific settings using simple regex for formatting.
>     - String check on exception.
>  rtemstoolkit/conftest.py          | 37 +++++++++++++++
>  rtemstoolkit/darwin.py            |  5 --
>  rtemstoolkit/error.py             | 10 ----
>  rtemstoolkit/freebsd.py           |  5 --
>  rtemstoolkit/host.py              | 14 ------
>  rtemstoolkit/linux.py             |  5 --
>  rtemstoolkit/macros.py            | 24 ----------
>  rtemstoolkit/netbsd.py            |  5 --
>  rtemstoolkit/path.py              | 17 -------
>  rtemstoolkit/solaris.py           |  5 --
>  rtemstoolkit/tests/__init__.py    |  0
>  rtemstoolkit/tests/test_error.py  | 39 +++++++++++++++
>  rtemstoolkit/tests/test_host.py   | 64 +++++++++++++++++++++++++
>  rtemstoolkit/tests/test_macros.py | 66 ++++++++++++++++++++++++++
>  rtemstoolkit/tests/test_path.py   | 79 +++++++++++++++++++++++++++++++
>  rtemstoolkit/windows.py           |  5 --
>  16 files changed, 285 insertions(+), 95 deletions(-)
>  create mode 100644 rtemstoolkit/conftest.py
>  create mode 100644 rtemstoolkit/tests/__init__.py
>  create mode 100644 rtemstoolkit/tests/test_error.py
>  create mode 100644 rtemstoolkit/tests/test_host.py
>  create mode 100644 rtemstoolkit/tests/test_macros.py
>  create mode 100644 rtemstoolkit/tests/test_path.py
> diff --git a/rtemstoolkit/conftest.py b/rtemstoolkit/conftest.py
> new file mode 100644
> index 0000000..3e1ec80
> --- /dev/null
> +++ b/rtemstoolkit/conftest.py
> @@ -0,0 +1,37 @@
> +# SPDX-License-Identifier: BSD-2-Clause
> +# RTEMS Tools Project (http://www.rtems.org/)
> +# Copyright (C) 2020 Amar Takhar <amar at rtems.org>
> +# Redistribution and use in source and binary forms, with or without
> +# modification, are permitted provided that the following conditions
> +# are met:
> +# 1. Redistributions of source code must retain the above copyright
> +#    notice, this list of conditions and the following disclaimer.
> +# 2. Redistributions in binary form must reproduce the above copyright
> +#    notice, this list of conditions and the following disclaimer in the
> +#    documentation and/or other materials provided with the distribution.
> +# THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
> +# AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
> +# IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
> +# ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE
> +# LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
> +# CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
> +# SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
> +# INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
> +# CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
> +# ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
> +# POSSIBILITY OF SUCH DAMAGE.
> +import pytest
> +from sys import path
> +import os
> +# Always find the parent directory of rtemstoolkit/ no matter where
> +# pytest is run.
> +def pytest_runtest_setup(item):
> +    path_toolkit = os.path.dirname(os.path.abspath(__file__))
> +    path.append(os.path.dirname(path_toolkit))
> diff --git a/rtemstoolkit/darwin.py b/rtemstoolkit/darwin.py
> index e780d1d..b9e17cf 100644
> --- a/rtemstoolkit/darwin.py
> +++ b/rtemstoolkit/darwin.py
> @@ -76,8 +76,3 @@ def overrides():
>      defines['_build_arch']   = defines['_host_arch']
>      return defines
> -if __name__ == '__main__':
> -    import pprint
> -    pprint.pprint(cpus())
> -    pprint.pprint(overrides())
> diff --git a/rtemstoolkit/error.py b/rtemstoolkit/error.py
> index e3a43c1..697b0a6 100644
> --- a/rtemstoolkit/error.py
> +++ b/rtemstoolkit/error.py
> @@ -55,13 +55,3 @@ class exit(error):
>      """Raise for to exit."""
>      def __init__(self):
>          pass
> -    try:
> -        raise general('a general error')
> -    except general as gerr:
> -        print('caught:', gerr)
> -    try:
> -        raise internal('an internal error')
> -    except internal as ierr:
> -        print('caught:', ierr)
> diff --git a/rtemstoolkit/freebsd.py b/rtemstoolkit/freebsd.py
> index ed16140..6e40c34 100644
> --- a/rtemstoolkit/freebsd.py
> +++ b/rtemstoolkit/freebsd.py
> @@ -97,8 +97,3 @@ def overrides():
>              break
>      return defines
> -    import pprint
> diff --git a/rtemstoolkit/host.py b/rtemstoolkit/host.py
> index 01aae07..67b006a 100644
> --- a/rtemstoolkit/host.py
> +++ b/rtemstoolkit/host.py
> @@ -103,17 +103,3 @@ def label(mode = 'all'):
>      if mode == 'all':
>          return '%s (%s)' % (compact, extended)
>      raise error.general('invalid platform mode: %s' % (mode))
> -    import pprint
> -    print('Python\'s OS name: %s' % (os.name))
> -    load()
> -    print('Name      : %s' % (name))
> -    if is_windows:
> -        status = 'Yes'
> -    else:
> -        status = 'No'
> -    print('Windows   : %s' % (status))
> -    print('CPUs      : %d' % (cpus()))
> -    print('Overrides :')
> diff --git a/rtemstoolkit/linux.py b/rtemstoolkit/linux.py
> index 21f6f97..15b8528 100644
> --- a/rtemstoolkit/linux.py
> +++ b/rtemstoolkit/linux.py
> @@ -134,8 +134,3 @@ def overrides():
>      return defines
> -    import pprint
> diff --git a/rtemstoolkit/macros.py b/rtemstoolkit/macros.py
> index d8012e1..708107f 100644
> --- a/rtemstoolkit/macros.py
> +++ b/rtemstoolkit/macros.py
> @@ -534,27 +534,3 @@ class macros:
>      def unlock_read_map(self):
>          self.read_map_locked = False
> -if __name__ == "__main__":
> -    import copy
> -    import sys
> -    print(inspect.getfile(macros))
> -    m = macros()
> -    d = copy.copy(m)
> -    m['test1'] = 'something'
> -    if d.has_key('test1'):
> -        print('error: copy failed.')
> -        sys.exit(1)
> -    m.parse("[test]\n" \
> -            "test1: none, undefine, ''\n" \
> -            "name:  none, override, 'pink'\n")
> -    print('set test:', m.set_read_map('test'))
> -    if m['name'] != 'pink':
> -        print('error: override failed. name is %s' % (m['name']))
> -        sys.exit(1)
> -    if m.has_key('test1'):
> -        print('error: map undefine failed.')
> -        sys.exit(1)
> -    print('unset test:', m.unset_read_map('test'))
> -    print(m)
> -    print(m.keys())
> diff --git a/rtemstoolkit/netbsd.py b/rtemstoolkit/netbsd.py
> index 1d9a11f..eab9353 100644
> --- a/rtemstoolkit/netbsd.py
> +++ b/rtemstoolkit/netbsd.py
> @@ -90,8 +90,3 @@ def overrides():
>              break
>      return defines
> -    import pprint
> diff --git a/rtemstoolkit/path.py b/rtemstoolkit/path.py
> index b15164b..7b5f64b 100644
> --- a/rtemstoolkit/path.py
> +++ b/rtemstoolkit/path.py
> @@ -430,20 +430,3 @@ def get_humanize_size(path, depth = -1):
>              return "%5.3f%sB" % (size, unit)
>          size /= 1024.0
>      return "%.3f%sB" % (size, 'Y')
> -    print(host('/a/b/c/d-e-f'))
> -    print(host('//a/b//c/d-e-f'))
> -    print(shell('/w/x/y/z'))
> -    print(basename('/as/sd/df/fg/me.txt'))
> -    print(dirname('/as/sd/df/fg/me.txt'))
> -    print(join('/d', 'g', '/tyty/fgfg'))
> -    windows = True
> -    print(shell('w:/x/y/z'))
> -    print(basename('x:/sd/df/fg/me.txt'))
> -    print(dirname('x:/sd/df/fg/me.txt'))
> -    print(join('s:/d/', '/g', '/tyty/fgfg'))
> -    print(join('s:/d/e\\f/g', '/h', '/tyty/zxzx', '\\mm\\nn/p'))
> diff --git a/rtemstoolkit/solaris.py b/rtemstoolkit/solaris.py
> index 79ddd75..1b265da 100644
> --- a/rtemstoolkit/solaris.py
> +++ b/rtemstoolkit/solaris.py
> @@ -83,8 +83,3 @@ def overrides():
>      return defines
> -    import pprint
> diff --git a/rtemstoolkit/tests/__init__.py b/rtemstoolkit/tests/__init__.py
> index 0000000..e69de29
> diff --git a/rtemstoolkit/tests/test_error.py b/rtemstoolkit/tests/test_error.py
> index 0000000..0702ced
> --- /dev/null
> +++ b/rtemstoolkit/tests/test_error.py
> @@ -0,0 +1,39 @@
> +# are met:
> +import pytest
> +from rtemstoolkit.error import general, internal
> +def test_general():
> +    with pytest.raises(general, match=r"^error: test_general$"):
> +        raise general("test_general")
> +def test_internal():
> +    with pytest.raises(internal, match=r"^internal error: test_internal$"):
> +        raise internal("test_internal")
> diff --git a/rtemstoolkit/tests/test_host.py b/rtemstoolkit/tests/test_host.py
> index 0000000..fb15a24
> --- /dev/null
> +++ b/rtemstoolkit/tests/test_host.py
> @@ -0,0 +1,64 @@
> +# are met:
> +import pytest
> +import re
> +from rtemstoolkit import host
> +def test_cpu():
> +    assert type(host.cpus()) is int
> +def test_overrides():
> +    assert type(host.overrides()) is dict
> +def test_label_system():
> +    assert host.label(mode="system") is not None
> +def test_label_compact():
> +    assert re.match("^[a-zA-Z]*-.*-.*$", host.label(mode="compact"))
> +def test_label_extended():
> +    assert re.match("^[a-zA-Z]* .*$", host.label(mode="extended"))
> +def test_label_all():
> +    assert re.match("^[a-zA-Z]*-.*-.* \\(.*\\)$", host.label(mode="all"))
> +def test_label_error():
> +    from rtemstoolkit.error import general
> +    with pytest.raises(general, match=r"^error: invalid platform mode: _nonexistent_$"):
> +        assert host.label(mode="_nonexistent_")
> diff --git a/rtemstoolkit/tests/test_macros.py b/rtemstoolkit/tests/test_macros.py
> index 0000000..45d4abd
> --- /dev/null
> +++ b/rtemstoolkit/tests/test_macros.py
> @@ -0,0 +1,66 @@
> +# are met:
> +import pytest
> +from rtemstoolkit.macros import macros
> +class TestClass:
> +    @classmethod
> +    def setup_class(cls):
> +        import copy
> +        import sys
> +        cls.m = macros()
> +        cls.d = copy.copy(cls.m)
> +    def test_copy_failure(self):
> +        self.m['test1'] = 'something'
> +        assert "test1" not in self.d
> +    def test_set_tests(self):
> +        assert self.m.parse("[test]\n" \
> +                "test1: none, undefine, ''\n" \
> +                "name:  none, override, 'pink'\n") is None
> +        assert self.m.set_read_map("test")
> +    def test_check_override(self):
> +        if self.m["name"] != "pink":
> +            raise Exception("error: override failed. name is %s" % self.m["name"])
> +    def test_undefine(self):
> +        assert "test1" not in self.m
> +    def test_unset(self):
> +        assert "name" in self.m
> +        assert self.m.unset_read_map("test")
> +        assert "name" not in self.m
> diff --git a/rtemstoolkit/tests/test_path.py b/rtemstoolkit/tests/test_path.py
> index 0000000..ee0ae24
> --- /dev/null
> +++ b/rtemstoolkit/tests/test_path.py
> @@ -0,0 +1,79 @@
> +# are met:
> +import pytest
> +from rtemstoolkit import path
> +rtems_windows = pytest.mark.parametrize("windows", [False, True], \
> +                ids=["Windows=False", "Windows=True"])
> + at rtems_windows
> +def test_host(windows):
> +    path.windows = windows
> +    if windows:
> +        path_str = "a:\\b\\c\\d-e-f"
> +    else:
> +        path_str = "/a/b/c/d-e-f"
> +    assert path.host('//a/b/c/d-e-f') == path_str
> + at rtems_windows
> +def test_shell(windows):
> +    assert path.shell('/w/x/y/z') == "/w/x/y/z"
> + at rtems_windows
> +def test_basename(windows):
> +    assert path.basename('/as/sd/df/fg/me.txt') == "me.txt"
> +    if windows:
> +        assert path.basename('x:/sd/df/fg/me.txt') == "me.txt"
> + at rtems_windows
> +def test_dirname(windows):
> +    assert path.dirname('/as/sd/df/fg/me.txt') == "/as/sd/df/fg"
> +    if windows:
> +        assert path.dirname('x:/sd/df/fg/me.txt') == "/x/sd/df/fg"
> + at rtems_windows
> +def test_join(windows):
> +    assert path.join('/d', 'g', '/tyty/fgfg') == "/d/g/tyty/fgfg"
> +    if windows:
> +        assert path.join('s:/d/e\\f/g', '/h', '/tyty/zxzx', '\\mm\\nn/p') == "/s/d/e/f/g/h/tyty/zxzx/mm/nn/p"
> +        assert path.join('s:/d/', '/g', '/tyty/fgfg') == "/s/d/g/tyty/fgfg"
> diff --git a/rtemstoolkit/windows.py b/rtemstoolkit/windows.py
> index 802263b..585cddf 100644
> --- a/rtemstoolkit/windows.py
> +++ b/rtemstoolkit/windows.py
> @@ -132,8 +132,3 @@ def overrides():
>          '___setup_shell': ('exe',     'required', '%{__sh}')
>      return defines
> -    import pprint
> 2.25.0
> devel mailing list
> devel at rtems.org
