[PATCH 2/2] Add a message to run 'pytest' to run rest of test suite.
Mon Mar 16 08:34:53 UTC 2020
On 16/03/2020 00:57, Amar Takhar wrote:
> On 2020-03-16 09:20 +1100, Chris Johns wrote:
>> Is pytest installed by default?
> No.  It's a separate package the Python has 'unittest' which is shipped by
> default.  For our usage pyttest is more flexible and will create concise code
> that is easy to contribute to.  The biggest reason is that it's more suited to
> our use.
 From the website pytest requires Python 3.5+ and PyPy 3. This is not a
problem for me in general. We still would like to be compatible to
Python 2.7, how can we run the tests in such an environment with pytest?
What is the relationship to the standard Python unittest module? Do you
want to write the tests with unittest and run them with pytest?
URL: <http://lists.rtems.org/pipermail/devel/attachments/20200316/20ca1450/attachment.html>
