[PATCH 2/2] Add a message to run 'pytest' to run rest of test suite.
Amar Takhar amar at rtems.org
Mon Mar 16 19:17:32 UTC 2020
On 2020-03-16 09:34 +0100, Sebastian Huber wrote:
> On 16/03/2020 00:57, Amar Takhar wrote:
>     On 2020-03-16 09:20 +1100, Chris Johns wrote:
>         Is pytest installed by default?
>     No.  It's a separate package the Python has 'unittest' which is shipped by
>     default.  For our usage pyttest is more flexible and will create concise code
>     that is easy to contribute to.  The biggest reason is that it's more suited to
>     our use.
> From the website pytest requires Python 3.5+ and PyPy 3. This is not a problem
> for me in general. We still would like to be compatible to Python 2.7, how can
> we run the tests in such an environment with pytest?
It works on pytest using any Python 2.7+:
verm at peach# pytest-2.7 --version
This is pytest version 4.5.0, imported from
/usr/local/lib/python2.7/site-packages/pytest.pyc
verm at peach# pytest --version
/usr/local/lib/python3.7/site-packages/pytest.py
Python 2.x support is not going to go away for a while yet.
> What is the relationship to the standard Python unittest module? Do you want to
> write the tests with unittest and run them with pytest?
No, pytest uses an entirely different methodology.  This gives an OK overview of
the differences between the two:
  https://www.slant.co/versus/9148/9149/~unittest_vs_pytest
It's more suited to our requirements and the ability to do group fixtures is
fantastic for testing cross platform support among other scenarios.
Amar.
