[PATCH 00/12] record: Add support for base64 and zlib compressed input
Sebastian Huber
Mon Mar 16 10:50:20 UTC 2020
Sebastian Huber (12):
record: Fix format
record: Guard config.h include
record: Format file header
record: Add INI file parser
record: Add support for user defined event names
record: Add option to print config default values
record: Add filter base class
record: Add base64 filter class
record: Add support for base64 encoded input
record: Add zlib filter class
record: Add support for zlib compressed input
record: Increase input buffer and alignment
trace/record/client.h | 98 +++++++++++-
trace/record/inih/LICENSE.txt | 27 ++++
trace/record/inih/ini.c | 284 +++++++++++++++++++++++++++++++++++
trace/record/inih/ini.h | 148 ++++++++++++++++++
trace/record/record-client-base.cc | 83 +++++++++-
trace/record/record-filter-base64.cc | 103 +++++++++++++
trace/record/record-filter-zlib.cc | 77 ++++++++++
trace/record/record-main-lttng.cc | 210 ++++++++++++++++++--------
trace/wscript | 14 +-
9 files changed, 972 insertions(+), 72 deletions(-)
create mode 100644 trace/record/inih/LICENSE.txt
create mode 100644 trace/record/inih/ini.c
create mode 100644 trace/record/inih/ini.h
create mode 100644 trace/record/record-filter-base64.cc
create mode 100644 trace/record/record-filter-zlib.cc
2.16.4
