[PATCH rtems-docs] user/raspberrypi: Fix typo
G S Niteesh Babu
niteesh.gs at gmail.com
Mon Mar 16 14:42:06 UTC 2020
enable-uart should be enable_uart in config.txt
user/bsps/arm/raspberrypi.rst | 2 +-
1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/user/bsps/arm/raspberrypi.rst b/user/bsps/arm/raspberrypi.rst
index 72889a5..c26f4b5 100644
--- a/user/bsps/arm/raspberrypi.rst
+++ b/user/bsps/arm/raspberrypi.rst
@@ -46,7 +46,7 @@ Make sure you have these lines below, in your ``config.txt``.
.. code-block:: none
- enable-uart=1
+ enable_uart=1
kernel_address=0x200000
kernel=kernel.img
2.17.1
