[PATCH rtems-docs] user/raspberrypi: Fix typo
Christian Mauderer christian.mauderer at embedded-brains.de
Thu Mar 19 06:17:07 UTC 2020
Hello Niteesh,
thanks for finding and fixing that. It's a very small patch and no one
objected in the last days. So I pushed it.
Best regards
Christian
On 16/03/2020 15:42, G S Niteesh Babu wrote:
> enable-uart should be enable_uart in config.txt
>  user/bsps/arm/raspberrypi.rst | 2 +-
>  1 file changed, 1 insertion(+), 1 deletion(-)
> diff --git a/user/bsps/arm/raspberrypi.rst b/user/bsps/arm/raspberrypi.rst
> index 72889a5..c26f4b5 100644
> --- a/user/bsps/arm/raspberrypi.rst
> +++ b/user/bsps/arm/raspberrypi.rst
> @@ -46,7 +46,7 @@ Make sure you have these lines below, in your ``config.txt``.
>  .. code-block:: none
> -     enable-uart=1
> +     enable_uart=1
>       kernel_address=0x200000
>       kernel=kernel.img
embedded brains GmbH
Herr Christian Mauderer
Dornierstr. 4
D-82178 Puchheim
Germany
Phone: +49-89-18 94 741 - 18
Fax:   +49-89-18 94 741 - 08
PGP: Public key available on request.
