[PATCH 0/1] Add Python development guidelines
Sebastian Huber
Mon Mar 16 15:10:55 UTC 2020
This is a first draft of the Python development guildelines for the
RTEMS Software Engineering manual.
For the static analysis tools flake8, pylint, and mypy you can use
configuration files. I would start with the default configuration. For
pylint, you can dump the default configuration with "pylint
--generate-rcfile". Should we use a particular pylint version to
generate configuration file for the RTEMS Project or should we just use
whatever a future version will use as default? I am not sure about the
mypy configuration.
How do we want to install the Python development tools? In the
rtems-qual repository I simply set up a virtual environment with a
simple Makefile:
https://git.rtems.org/sebh/rtems-qual.git/tree/Makefile
I think we should install specific versions of the tools to avoid that
different developers get different tool reports.
How could a waf integration look like?
Sebastian Huber (1):
eng: Add Python development guidelines
eng/management.rst | 1 +
eng/python-devel.rst | 136 +++++++++++++++++++++++++++++++++++++++++++++++++++
2 files changed, 137 insertions(+)
create mode 100644 eng/python-devel.rst
2.16.4
