[PATCH rtems-docs] user/raspberrypi: Fix typo
Niteesh G. S.
niteesh.gs at gmail.com
Thu Mar 19 08:52:44 UTC 2020
Thanks for pushing it.
-Niteesh.
On Thu, Mar 19, 2020 at 11:47 AM Christian Mauderer <
christian.mauderer at embedded-brains.de> wrote:
> Hello Niteesh,
> thanks for finding and fixing that. It's a very small patch and no one
> objected in the last days. So I pushed it.
> Best regards
> Christian
> On 16/03/2020 15:42, G S Niteesh Babu wrote:
> > enable-uart should be enable_uart in config.txt
> > user/bsps/arm/raspberrypi.rst | 2 +-
> > 1 file changed, 1 insertion(+), 1 deletion(-)
> > diff --git a/user/bsps/arm/raspberrypi.rst
> b/user/bsps/arm/raspberrypi.rst
> > index 72889a5..c26f4b5 100644
> > --- a/user/bsps/arm/raspberrypi.rst
> > +++ b/user/bsps/arm/raspberrypi.rst
> > @@ -46,7 +46,7 @@ Make sure you have these lines below, in your
> ``config.txt``.
> > .. code-block:: none
> > - enable-uart=1
> > + enable_uart=1
> > kernel_address=0x200000
> > kernel=kernel.img
> embedded brains GmbH
> Herr Christian Mauderer
> Dornierstr. 4
> D-82178 Puchheim
> Germany
> email: christian.mauderer at embedded-brains.de
> Phone: +49-89-18 94 741 - 18
> Fax: +49-89-18 94 741 - 08
> PGP: Public key available on request.
URL: <http://lists.rtems.org/pipermail/devel/attachments/20200319/2aed5f35/attachment.html>
