[PATCH] rtems: Add support for building with Clang/LLVM
Hesham Almatary hesham.almatary at cl.cam.ac.uk
Mon Mar 16 20:30:16 UTC 2020
Hi Chris,
On Sun, 15 Mar 2020 at 21:09, Chris Johns <chrisj at rtems.org> wrote:
> Hi Hesham,
> This is a great addition to rtems_waf, some comments below.
> On 16/3/20 2:56 am, Hesham Almatary wrote:
> >  rtems.py | 85 +++++++++++++++++++++++++++++++++++++++++---------------
> >  1 file changed, 62 insertions(+), 23 deletions(-)
> > diff --git a/rtems.py b/rtems.py
> > index ffb386f..f1ef4de 100644
> > --- a/rtems.py
> > +++ b/rtems.py
> > @@ -1,4 +1,5 @@
> > +# Copyright 2020 Hesham Almatary
> >  # Copyright 2012-2016 Chris Johns (chrisj at rtems.org)
> >  # Redistribution and use in source and binary forms, with or without
> > @@ -63,6 +64,10 @@ def options(opt):
> >                     default = 'all',
> >                     dest = 'rtems_bsps',
> >                     help = 'List of BSPs to build.')
> > +    opt.add_option('--rtems-compiler',
> > +                   default = 'gcc',
> > +                   dest = 'rtems_compiler',
> > +                   help = 'RTEMS compiler to use available options are
> clang and gcc (defaults to gcc).')
> >      opt.add_option('--show-commands',
> >                     action = 'store_true',
> >                     default = False,
> > @@ -104,15 +109,17 @@ def init(ctx, filters = None, version = None,
> long_commands = False, bsp_init =
> >          # Check the tools, architectures and bsps.
> > -        rtems_version, rtems_path, rtems_tools, archs, arch_bsps = \
> > +        rtems_compiler, rtems_version, rtems_path, rtems_tools, archs,
> arch_bsps = \
> >              check_options(ctx,
> >                            env.options['prefix'],
> > +                          env.options['rtems_compiler'],
> >                            env.options['rtems_tools'],
> >                            env.options['rtems_path'],
> >                            env.options['rtems_version'],
> >                            env.options['rtems_archs'],
> >                            env.options['rtems_bsps'])
> > +        print("RTEMS Compiler is " + rtems_compiler)
> Please use `conf.msg()`. See
> https://git.rtems.org/rtems_waf/tree/rtems.py#n248
> >          # Update the contexts for all the bsps.
> > @@ -176,9 +183,10 @@ def configure(conf, bsp_configure = None):
> >      else:
> >          long_commands = 'no'
> arch_bsps = \
> >          check_options(conf,
> >                        conf.options.prefix,
> > +                      conf.options.rtems_compiler,
> >                        conf.options.rtems_tools,
> >                        conf.options.rtems_path,
> >                        conf.options.rtems_version,
> > @@ -222,13 +230,19 @@ def configure(conf, bsp_configure = None):
> >          conf.env.RTEMS_ARCH_RTEMS = arch
> >          conf.env.RTEMS_BSP = bsp
> > -        tools = _find_tools(conf, arch, rtems_tools, tools)
> > +        tools = _find_tools(conf, arch, rtems_compiler, rtems_tools,
> tools)
> >          for t in tools[arch]:
> >              conf.env[t] = tools[arch][t]
> > -        conf.load('gcc')
> > -        conf.load('g++')
> > -        conf.load('gas')
> > +        if rtems_compiler == 'gcc':
> > +            conf.load('gcc')
> > +            conf.load('g++')
> > +            conf.load('gas')
> > +        elif rtems_compiler == 'clang':
> > +            conf.load('clang')
> > +            conf.load('clang++')
> > +        else:
> > +            conf.fatal('Unknown RTEMS compiler: ' + rtems_compiler)
> >          # Get the version of the tools being used.
> > @@ -388,7 +402,7 @@ def tweaks(conf, arch_bsp):
> >      if '-ffunction-sections' in conf.env.CFLAGS:
> >        conf.env.LINKFLAGS += ['-Wl,--gc-sections']
> > -def check_options(ctx, prefix, rtems_tools, rtems_path, rtems_version,
> rtems_archs, rtems_bsps):
> > +def check_options(ctx, prefix, rtems_compiler, rtems_tools, rtems_path,
> rtems_version, rtems_archs, rtems_bsps):
> >      # Set defaults
> > @@ -406,6 +420,12 @@ def check_options(ctx, prefix, rtems_tools,
> rtems_path, rtems_version, rtems_arc
> >      if rtems_tools is None:
> >          rtems_tools = rtems_path
> > +    # Check the compiler option is valid.
> > +    if rtems_compiler not in ['gcc', 'clang']:
> Key in compiler dict? See below.
> > +        ctx.fatal('Valid RTEMS compilers are gcc or clang')
> >      # Check the paths are valid.
> > @@ -476,7 +496,7 @@ def check_options(ctx, prefix, rtems_tools,
> >      arch_bsps = filter(ctx, 'bsps', arch_bsps)
> > -    return rtems_version, rtems_path, tools, archs, arch_bsps
> > +    return rtems_compiler, rtems_version, rtems_path, tools, archs,
> arch_bsps
> >  def check_env(ctx, var):
> >      if var in ctx.env and len(ctx.env[var]) != 0:
> > @@ -682,22 +702,40 @@ def long_command_line():
> >              if hasattr(cls, 'hcode'):
> >                  derived_class.hcode = cls.hcode
> > -def _find_tools(conf, arch, paths, tools):
> > +def _find_tools(conf, arch, rtems_compiler, paths, tools):
> >      if arch not in tools:
> >          arch_tools = {}
> > -        arch_tools['CC']          = conf.find_program([arch + '-gcc'],
> path_list = paths)
> > -        arch_tools['CXX']         = conf.find_program([arch + '-g++'],
> path_list = paths)
> > -        arch_tools['LINK_CC']     = arch_tools['CC']
> > -        arch_tools['LINK_CXX']    = arch_tools['CXX']
> > -        arch_tools['AS']          = conf.find_program([arch + '-gcc'],
> path_list = paths)
> > -        arch_tools['LD']          = conf.find_program([arch + '-ld'],
> path_list = paths)
> > -        arch_tools['AR']          = conf.find_program([arch + '-ar'],
> path_list = paths)
> > -        arch_tools['NM']          = conf.find_program([arch + '-nm'],
> path_list = paths)
> > -        arch_tools['OBJDUMP']     = conf.find_program([arch +
> '-objdump'], path_list = paths)
> > -        arch_tools['OBJCOPY']     = conf.find_program([arch +
> '-objcopy'], path_list = paths)
> > -        arch_tools['READELF']     = conf.find_program([arch +
> '-readelf'], path_list = paths)
> > -        arch_tools['STRIP']       = conf.find_program([arch +
> '-strip'], path_list = paths)
> > -        arch_tools['RANLIB']      = conf.find_program([arch +
> '-ranlib'], path_list = paths)
> > +            arch_tools['CC']          = conf.find_program([arch +
> '-gcc'], path_list = paths)
> > +            arch_tools['CXX']         = conf.find_program([arch +
> '-g++'], path_list = paths)
> > +            arch_tools['LINK_CC']     = arch_tools['CC']
> > +            arch_tools['LINK_CXX']    = arch_tools['CXX']
> > +            arch_tools['AS']          = conf.find_program([arch +
> > +            arch_tools['LD']          = conf.find_program([arch +
> '-ld'],  path_list = paths)
> > +            arch_tools['AR']          = conf.find_program([arch +
> '-ar'], path_list = paths)
> > +            arch_tools['NM']          = conf.find_program([arch +
> '-nm'], path_list = paths)
> > +            arch_tools['OBJDUMP']     = conf.find_program([arch +
> > +            arch_tools['OBJCOPY']     = conf.find_program([arch +
> > +            arch_tools['READELF']     = conf.find_program([arch +
> > +            arch_tools['STRIP']       = conf.find_program([arch +
> > +            arch_tools['RANLIB']      = conf.find_program([arch +
> > +            arch_tools['CC']          = conf.find_program('clang')
> > +            arch_tools['CXX']         = conf.find_program('clang++')
> > +            arch_tools['AS']          = conf.find_program('clang')
> > +            arch_tools['LD']          = conf.find_program('lld')
> > +            arch_tools['AR']          = conf.find_program('llvm-ar')
> > +            arch_tools['NM']          = conf.find_program('llvm-nm')
> conf.find_program('llvm-objdump')
> conf.find_program('llvm-objcopy')
> conf.find_program('llvm-readelf')
> > +            arch_tools['STRIP']       = conf.find_program('llvm-strip')
> > +            arch_tools['RANLIB']      = conf.find_program('llvm-ranlib')
> Could this be defined in a compile dict?
Do you mean just the names of the tools being values?
> Why does llvm not require a path_list?
I didn’t want to restrict the search path to rtems-prefix only but rather
search from $PATH. That follows the rtems/waf (new build system) convention
by default. As you know, Clang/LLVM don’t need multiple builds for each
target/OS, but they have all backends for all supported architectures and
OSes with a single frontend. So putting a custom Clang/LLVM build in RTEMS
tools like we do with gcc didn’t make much sense to me.
> Chris
> > +        else:
> > +            conf.fatal('Unknown RTEMS Compiler')
> >          arch_tools['RTEMS_LD']    = conf.find_program(['rtems-ld'],
> path_list = paths,
> >                                                        mandatory = False)
> >          arch_tools['RTEMS_TLD']   = conf.find_program(['rtems-tld'],
> path_list = paths,
> > @@ -837,7 +875,8 @@ def _filter_flags(label, flags, arch, rtems_path):
> >            { 'key': 'includes', 'path': True,  'flags': { '-I': 1,
> '-isystem': 2, '-sysroot': 2 } },
> >            { 'key': 'libpath',  'path': True,  'flags': { '-L': 1 } },
> >            { 'key': 'machines', 'path': True,  'flags': { '-O': 1, '-m':
> 1, '-f': 1, '-G':1, '-E':1 } },
> > -          { 'key': 'specs',    'path': True,  'flags': { '-q': 1, '-B':
> 2, '--specs': 2 } } ]
> > +          { 'key': 'specs',    'path': True,  'flags': { '-q': 1, '-B':
> 2, '--specs': 2 } },
> > +          { 'key': 'target',    'path': True,  'flags': { '--target': 1
> >      flags = _strip_cflags(flags)
> devel mailing list
> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20200316/c3b8015c/attachment-0001.html>
