[PATCH] rtems: Add support for building with Clang/LLVM
Tue Mar 17 05:50:39 UTC 2020
On 17/03/2020 03:09, Chris Johns wrote:
>> That follows the rtems/waf (new build system) convention by default.
> Do you mean the work Sebastian is doing? If you are, it currently might but that
> work is not finished and it may change, partially to make it consistent with
> this package. This has not been discussed.
We discussed the way to find tools during the waf configure phase. See
bottom of this email:
https://lists.rtems.org/pipermail/devel/2019-December/056291.html
Maybe I misinterpreted your steps 1. to 3. In the waf configure output
you see the absolute paths of the tools. So you can check if they are
the right ones.
URL: <http://lists.rtems.org/pipermail/devel/attachments/20200317/bc9a2f12/attachment-0001.html>
