[PATCH] rtems: Add support for building with Clang/LLVM
Chris Johns
chrisj at rtems.org
Wed Mar 18 05:10:55 UTC 2020
On 17/3/20 4:50 pm, Sebastian Huber wrote:
> On 17/03/2020 03:09, Chris Johns wrote:
>>> That follows the rtems/waf (new build system) convention by default.
>> Do you mean the work Sebastian is doing? If you are, it currently might but that
>> work is not finished and it may change, partially to make it consistent with
>> this package. This has not been discussed.
> We discussed the way to find tools during the waf configure phase. See bottom of
> this email:
> https://lists.rtems.org/pipermail/devel/2019-December/056291.html
Oh we did, I am sorry.
> Maybe I misinterpreted your steps 1. to 3.
I am not sure if you have, I have not tested it.
> In the waf configure output you see
> the absolute paths of the tools. So you can check if they are the right ones.
The way rtems_waf works is due to the paths passed to the tool check? My reading
of Hesham's change is only the env path is checked for clang and this is what I
am questioning, i.e. does the --prefix, --rtems-tools etc work with clang just
like gcc?
I think we should be consistent what ever the specifics are and this should
before across different packages and for tools within a package.
