Hello world and query about a project availability
Richi Dubey richidubey at gmail.com
Tue Mar 17 06:48:17 UTC 2020
Dear Dr. Bloom,
I have added my name on the GSoC Tracking list and have shared a draft
proposal with you. Please suggest changes in my proposal:
https://docs.google.com/document/d/1bth9sh3qH2vMTks1yiGpZVskUcD-g5jED4a3zJx1Klc/edit?usp=sharing
Also, currently the extension ideas I have in my mind are following:
1) Add support for multiple criticalilty level for tasks, and work on
another scheduler which would takes into account criticality level and
the multicore system. For example: EDF-VD by Dr. Baruah as it is 100%
schedulable.
2) Add priority ordering for asynchronous task according to Audsley's
optimal priority ordering
(https://www.sciencedirect.com/science/article/pii/S0020019000001654)
Please let me know your thoughts.
Thanks,
Richi.
On Fri, Mar 13, 2020 at 12:53 AM Gedare Bloom <gedare at rtems.org> wrote:
> Hi Richi,
> Welcome. The "Improve the SMP Scheduler" will require strong C
> programming skills before the summer. You will be expected to
> demonstrate that during the proposal period. I'm the only likely
> mentor for that project this year, and I haven't decided if I will
> mentor any projects, or which project I might mentor if I do. So it
> can be a bit risky to pursue that project, but if you are passionate
> about it and have the required capabilities, then you should start to
> prepare a proposal and convince me that I should mentor you :).
> The project itself is a straightforward implementation from the
> current skeleton of the scheduler. So you will want to also include
> some "extension" activities in case you complete the scheduler
> quickly.
> You should add yourself to https://devel.rtems.org/wiki/GSoC/2020
> Gedare
> On Thu, Mar 12, 2020 at 1:04 PM Richi Dubey <richidubey at gmail.com> wrote:
> > Hey everyone,
> > Could someone please tell me if this project
> > (https://devel.rtems.org/ticket/2510) titled
> > "Improve the SMP scheduler with arbitrary processor affinity support"
> > still open? I went through the mpi-sws paper and I found the concept
> > of implementing
> > task's affinity to a processor to increase its efficiency really
> > interesting. Can someone please help me with this?
> > Thanks,
> > Richi.
> > devel mailing list
> > devel at rtems.org
