Hello world and query about a project availability
Richi Dubey richidubey at gmail.com
Tue Mar 17 06:53:46 UTC 2020
Thanks for telling me about the copyright and licensing issue. I would
submit a new patch before the end of the day.
On Sat, Mar 14, 2020 at 4:52 AM Gedare Bloom <gedare at rtems.org> wrote:
> On Fri, Mar 13, 2020 at 2:04 PM Richi Dubey <richidubey at gmail.com> wrote:
> > Dear Dr. Bloom,
> > Please find my patch given below :-
> > From 296fa828fec7c3f99231b377c57ca20411564703 Mon Sep 17 00:00:00 2001
> > From: Richi Dubey <richidubey at gmail.com>
> > Date: Sat, 14 Mar 2020 01:33:02 +0530
> > Subject: [PATCH 2/2] Changed the hello world file
> >  testsuites/samples/hello/init.c | 43 +++++++++++----------------------
> >  1 file changed, 14 insertions(+), 29 deletions(-)
> > diff --git a/testsuites/samples/hello/init.c b/testsuites/samples/hello/init.c
> > index 34ded37c55..e29306e7c9 100644
> > --- a/testsuites/samples/hello/init.c
> > +++ b/testsuites/samples/hello/init.c
> > @@ -1,44 +1,29 @@
> > - *  COPYRIGHT (c) 1989-2012.
> > - *  On-Line Applications Research Corporation (OAR).
> > - *  The license and distribution terms for this file may be
> > - *  found in the file LICENSE in this distribution or at
> > - *  http://www.rtems.org/license/LICENSE.
> It is incorrect to remove someone else's copyright and licensing information.
> > -#ifdef HAVE_CONFIG_H
> > -#include "config.h"
> > -#endif
> >  #include <rtems.h>
> > -#include <tmacros.h>
> > +#include <stdlib.h>
> > +#include <stdio.h>
> > -const char rtems_test_name[] = "HELLO WORLD";
> > -static rtems_task Init(
> > +rtems_task Init(
> >    rtems_task_argument ignored
> > -  rtems_print_printer_fprintf_putc(&rtems_test_printer);
> > -  TEST_BEGIN();
> > -  printf( "Hello World\n" );
> > -  TEST_END();
> > -  rtems_test_exit( 0 );
> > +  printf( "\n\n*** Hello RTEMS 2020! Let's do something new :) ***\n" );
> > +  printf( "Hello Everyone\n" );
> > +  printf( "*** Bubyee ***\n" );
> > +  exit( 0 );
> Although you were successful, this patch includes a lot of unnecessary
> changes. When you work on code and do submit patches, you should
> minimize non-relevant changes.
> > +/* configuration information */
> > +#include <bsp.h>
> >  /* NOTICE: the clock driver is explicitly disabled */
> >  #define CONFIGURE_APPLICATION_DOES_NOT_NEED_CLOCK_DRIVER
> > -#define CONFIGURE_APPLICATION_NEEDS_SIMPLE_CONSOLE_DRIVER
> > -#define CONFIGURE_MAXIMUM_TASKS            1
> > +#define CONFIGURE_APPLICATION_NEEDS_CONSOLE_DRIVER
> > +#define CONFIGURE_USE_DEVFS_AS_BASE_FILESYSTEM
> >  #define CONFIGURE_RTEMS_INIT_TASKS_TABLE
> > -#define CONFIGURE_INIT_TASK_ATTRIBUTES RTEMS_FLOATING_POINT
> > -#define CONFIGURE_INITIAL_EXTENSIONS RTEMS_TEST_INITIAL_EXTENSION
> > +#define CONFIGURE_MAXIMUM_TASKS 1
> >  #include <rtems/confdefs.h>
> > +/* end of file */
> > 2.17.1
> > On Fri, Mar 13, 2020 at 12:54 AM Gedare Bloom <gedare at rtems.org> wrote:
> > > On Thu, Mar 12, 2020 at 1:23 PM Gedare Bloom <gedare at rtems.org> wrote:
> > > > Hi Richi,
> > > > Welcome. The "Improve the SMP Scheduler" will require strong C
> > > > programming skills before the summer. You will be expected to
> > > > demonstrate that during the proposal period. I'm the only likely
> > > > mentor for that project this year, and I haven't decided if I will
> > > > mentor any projects, or which project I might mentor if I do. So it
> > > > can be a bit risky to pursue that project, but if you are passionate
> > > > about it and have the required capabilities, then you should start to
> > > > prepare a proposal and convince me that I should mentor you :).
> > > > The project itself is a straightforward implementation from the
> > > > current skeleton of the scheduler. So you will want to also include
> > > > some "extension" activities in case you complete the scheduler
> > > > quickly.
> > > > You should add yourself to https://devel.rtems.org/wiki/GSoC/2020
> > > PS: thanks for the screenshot, please send your patch as well.
> > > > Gedare
> > > > On Thu, Mar 12, 2020 at 1:04 PM Richi Dubey <richidubey at gmail.com> wrote:
> > > > > Hey everyone,
> > > > > Could someone please tell me if this project
> > > > > (https://devel.rtems.org/ticket/2510) titled
> > > > > "Improve the SMP scheduler with arbitrary processor affinity support"
> > > > > still open? I went through the mpi-sws paper and I found the concept
> > > > > of implementing
> > > > > task's affinity to a processor to increase its efficiency really
> > > > > interesting. Can someone please help me with this?
> > > > > Thanks,
> > > > > Richi.
> > > > > _______________________________________________
> > > > > devel mailing list
> > > > > devel at rtems.org
> > > > > http://lists.rtems.org/mailman/listinfo/devel
