[rtems-examples PATCH 2/2] Replace deprecated CONFIGURE_LIBIO_MAXIMUM_FILE_DESCRIPTORS with CONFIGURE_MAXIMUM_FILE_DESCRIPTORS
Joel Sherrill
joel at rtems.org
Tue Mar 17 13:06:07 UTC 2020
I should have said that I am OK with this patch and if the examples build
with the the waf patch to the examples build system, I'm OK with that also.
I am not comfortable reviewing the patch to the rtems waf infrastructure.
Sebastian, if you can push these, it would be appreciated. I'm about to
head into meetings and won't possibly get to it before this afternoon.
--joel
On Tue, Mar 17, 2020 at 8:03 AM Joel Sherrill <joel at rtems.org> wrote:
> The examples are released with each RTEMS version. The examples master
> should track RTEMS master.
> https://ftp.rtems.org/pub/rtems/releases/5/5.0.0/5.0.0-m2003/ includes a
> mated rtems-examples.
> --joel
> On Tue, Mar 17, 2020 at 5:11 AM Vijay Kumar Banerjee <
> vijaykumar9597 at gmail.com> wrote:
>> On Tue, Mar 17, 2020 at 3:25 PM Sebastian Huber <
>> sebastian.huber at embedded-brains.de> wrote:
>>> Should the examples also work with RTEMS 4.10 or 4.11?
>>> That's a good point. Should we sort out the examples that are not
>> expected
>> to work on 4.10 and 4.11 (like lvgl example) and do this change only on
>> those
>> files?
>> devel mailing list
>> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20200317/6f3ab693/attachment.html>
