[rtems-examples PATCH 2/2] Replace deprecated CONFIGURE_LIBIO_MAXIMUM_FILE_DESCRIPTORS with CONFIGURE_MAXIMUM_FILE_DESCRIPTORS
Wed Mar 18 04:56:46 UTC 2020
On 18/3/20 12:06 am, Joel Sherrill wrote:
> I should have said that I am OK with this patch and if the examples build with
> the the waf patch to the examples build system, I'm OK with that also.
The patch needs to have an updated rtems_waf to pull in the env var check I just
pushed.
> I am not comfortable reviewing the patch to the rtems waf infrastructure.
I am OK with this change.
> Sebastian, if you can push these, it would be appreciated. I'm about to head
> into meetings and won't possibly get to it before this afternoon.
I think we wait for a v2 patch.
> --joel
> On Tue, Mar 17, 2020 at 8:03 AM Joel Sherrill <joel at rtems.org
> <mailto:joel at rtems.org>> wrote:
>     The examples are released with each RTEMS version. The examples master
>     should track RTEMS master.
>     https://ftp.rtems.org/pub/rtems/releases/5/5.0.0/5.0.0-m2003/  includes a
>     mated rtems-examples.
>      --joel
>     On Tue, Mar 17, 2020 at 5:11 AM Vijay Kumar Banerjee
>     <vijaykumar9597 at gmail.com <mailto:vijaykumar9597 at gmail.com>> wrote:
>         On Tue, Mar 17, 2020 at 3:25 PM Sebastian Huber
>         <sebastian.huber at embedded-brains.de
>         <mailto:sebastian.huber at embedded-brains.de>> wrote:
>             Should the examples also work with RTEMS 4.10 or 4.11?
>         That's a good point. Should we sort out the examples that are not expected
>         to work on 4.10 and 4.11 (like lvgl example) and do this change only on
>         those
>         files?
>         _______________________________________________
>         devel mailing list
>         devel at rtems.org <mailto:devel at rtems.org>
>         http://lists.rtems.org/mailman/listinfo/devel
> devel mailing list
> devel at rtems.org
