Successfully built EPICS 7 with RTEMS 5 for mvme6100
Gedare Bloom
gedare at rtems.org
Wed Mar 18 18:21:40 UTC 2020
On Wed, Mar 18, 2020 at 11:40 AM Mritunjay Sharma
<mritunjaysharma394 at gmail.com> wrote:
> Hi everyone,
> As a part of working on ticket #3835 (BSP Buildset for EPICS), this is to inform the community that after a lot of research, help from RTEMS and EPICS community and https://epics.mpg.de/index.php?n=Software.EPICSRTEMS?userlang=en, I was able to build EPICS 7 for RTEMS 5 for mvme6100 (powerpc-rtems5).
> After this, my development environment is almost completely set up with RTEMS, rtems-source-builder and epics7 (taken from https://github.com/hjunkes/epicsBaseOwnPlayground/tree/7.0 ). While going through the entire process, I learnt about the changes to be made in epics7/configure/os/CONFIG_STATUS.Common.RTEMS and also encountered few errors while the 'make' process, however, it got fixed by commenting line 325 to 329 in '/home/mritunjay/development/rtems/5/powerpc-rtems5/beatnik/lib/include/rtems/confdefs/libio.h':
> // #ifdef CONFIGURE_FILESYSTEM_ENTRY_DEVFS
> // CONFIGURE_FILESYSTEM_ENTRY_DEVFS,
> // #endif
> I would like to know more on why this behaviour occurred. Is it a bug? Or something else?
Include some of this detail in your proposal. I don't have time at the
moment to delve into details.
Next step would be to identify a target you can build EPICS7+RTEMS5
with simulator support. This one is challenging since AFAIK there
haven't been any successes in that regards. Find out what are the
blockers and maybe you can work on those.
> I wanted to test it but I am facing issues in connecting with tftp server when I run 'scp bin/RTEMS-beatnik/libComTestHarness.boot root at epics:/var/lib/tftp'
> The following error was encountered:
> /usr/bin/ssh: /lib/x86_64-linux-gnu/libcrypto.so.1.0.0: no version information available (required by /usr/bin/ssh)
> ssh: Could not resolve hostname epics: Name or service not known
> lost connection
> I was wondering what can be the reason behind this, please help me fix this.
Test it how -- do you have a powerpc MVME6100 board?
I'm guessing whoever gave you that scp command line has a board with a
local /etc/hosts entry for 'epics' pointing to some local IP address
they connect to their board over.
Welcome to the world of cross-compiler development and testing. :)
https://docs.rtems.org/branches/master/user/hosts/index.html#development-host
> Also, what are the next steps? I am working on the GSoC proposal currently and since the current ticket #3835 is a shorter project, I have to add certain similar sub-tasks within the GSoC timeline as suggested by @Gedare Bloom :
> "* compile CFS by hand, create an RSB "recipe" to build it, then
> integrate it with vertical buildset configuration.
> * create vertical buildsets for PC, Raspberry Pi, and other boards.
> ** EPICS community uses many powerpc boards so adding something there
> would be good."
Identify what might be potential simulator targets for you to use, and
look at how easy they are to build with RSB. If any are missing
support, work on adding them. If any are broken, poke into why.
psim is a good powerpc simulator, although it may not have enough
support for running epics--I haven't looked.
For EPICS it is best to get something working in qemu so that you can
run some networking. So I'd look at some qemu simulator targets and
check what is their status and whether you can build and run anything
for RTEMS on them. After that, can you build/run any RTEMS networking
applications?
Does the EPICS7+RTEMS5 stack still using cpukit/libnetworking, or is
it able to use libbsd? That is an interesting question to find out.
> I would like to have suggestions on resetting the timeline as I work on refining the proposal for GSoC based on Dr. @Gedare Bloom's suggestions.
For timeline the first step is to break down all the tasks to figure
out what you need to do to accomplish each of your goals. Then you
should try to estimate how long you (or mentors) think each task will
take, and use that create your plan. (Estimating time is notoriously
difficult, but do your best. If it comes in too heavy or light, that
is fine, you should put some activities in "Future Improvements" that
can be moved into your summer work in case you get through your
planned work faster than you expect; if you don't complete all your
planned work, we understand and will take everything into
consideration during evaluation. Do NOT think of your plan as a
contract: it is not, it is a guideline for your summer.)
> Thanks
> Mritunjay
